GM's 6.2-liter V8 Engine Honored By Wards Auto
John Goreham
12-12-2018
Wards has named the General Motors 6.2-liter V8 engine with Dynamic Fuel Management (DFM) to its  2019 Wards 10 Best Engines Award list.
“General Motors’ thundering 420-horsepower V-8 in the Silverado exemplifies how engineers continue to find ways to improve efficiency without giving up something in return. DFM determines 80 times per second exactly how many cylinders require fuel to meet power demands. And, incredibly, it uses as few as two cylinders to propel the full-size pickup down the highway,” says Wards' Senior Content Director Drew Winter. “The truly amazing part is the cylinder deactivation is imperceptible, so seamless that the only thing the driver notices is fewer stops at the pump."
Coincidental to the award, GM-Trucks.com has just taken delivery of a long-term tester with this very engine.
“Chevrolet first introduced its Active Fuel Management cylinder deactivation system in 2005, and Dynamic Fuel Management is a natural progression of the technology,” said Jordan Lee, Small Block chief engineer. “Dynamic Fuel Management enables only the cylinders needed to deliver the power you want, seamlessly delivering the best balance of power and fuel economy.”
The full list of Wards' 10 best engines is as follows:
3.0L (B58) DOHC Turbocharged I-6 (BMW X5)
6.2L OHV V-8 with DFM (Chevrolet Silverado)
5.0L DOHC V-8 (Ford Mustang GT/Bullitt)
3.0L DOHC TurboDiesel V-6 (Ford F-150)
2.0L DOHC Atkinson i-VTEC 4-Cyl./HEV (Honda Accord Hybrid)
120-kW Fuel Cell/Electric Propulsion System (Hyundai Nexo)
150-kW Propulsion System (Hyundai Kona EV)
2.0L DOHC VC-Turbo 4-Cyl. (Infiniti QX50)
2.0L DOHC Atkinson 4-Cyl./HEV (Lexus UX 250h)
3.6L DOHC Pentastar eTorque V-6 (Ram 1500)
I wish the AFM on my 2018 was "...imperceptible, so seamless..."
I did not notice the AFM the first few times I drove the truck, but after a little more time behind the wheel, I became much more aware of the switches.  I basically can't tolerate it for city driving.  The coarseness and surging is really annoying.
The "10 best engines" list includes 2 electric propulsion systems. :lol:
On 12/13/2018 at 5:16 PM, SILVER SLED said:
Too bad it’s not a readily available engine.
Readily available for advertising.
420hp! 460tq!
Finding one on your local lot? Not so much.
so seamless that companies make tuners and range make a device to deactivate the crap my 2014 was great until about 30k and now at 85k it leaps and vibrates so bad that i finally got a tuner and turned it off and i still have warranty left but i dont care
You will not be able to do that on the 2019's.  From what I'm told, the system is locked down tight.  No aftermarket tuning at all.
I believe the 6.2 is a very good engine overall.  In the Truck, and in the Vette.  They are fairly reliable but being a forum like this, we'll see the brunt of any issues they may have with people coming here to vent and look for help.  I would love to have a truck (Or vette!) with that engine in it.  You folks that have one, consider yourself very fortunate and enjoy them.
The primary reason I searched high, low, far, and wide for Clyde. The 6.2L V8 was at the very top of the required options list. Well worth the money :D
420hp! 460tq!
Found a lot of them in Silverado High Country's and then in LTZ Z71 in the Phoenix area when I was looking for a Max Tow equipped truck.  Likewise I found several in GMC Denalis.
I really enjoy ours, the acceleration and handling are heads above the GMC 2500HD Duramax.  The 6.2L has 110,000 and running great.  Happy it doesn't have AFM.  I only bought the GMC to go with a larger fifth wheel.  Feature wise it is an upgrade from the 1500.  We kept the 1500 for short trips and around the Phoenix valley.
The listed engine is the 6.2L with DFM new for 2019.  And it is much more seamless than my AFM trucks.  Great engine so far.  Only time will tell how it goes after some miles.  Paired with the 10 speed, I really like it so far.
you all seem to be discussing the previous engine with AFM.
T
On ‎2019‎-‎01‎-‎01 at 7:10 AM, Stonewood said:
I didn't know there was an available 6.0L  No complaints with my 5.3.
2500's are still running the LS family 6.0L from the 2000's called the L96. It is an iron block engine, while the ecotec 5.3 (L83) and 6.2 (L86/87) are aluminum block engines. Aluminum is not the best "work truck" block material, they prefer to use iron for hard use/towing applications. You can not get a 1500 with a 6.0L and you cant get a 2500 with a 6.2L. There is a new 2500 engine in the works for the 2020 HD's, rumor has it around 6.7L but that seems overkill to me.
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
