I recently completed my first oil change in my 2019 Silverado LT with a 5.3 V8.  After reading in the owner's manual that the capacity is 8 quarts, I put exaclty that into the engine.  I waited about 30 minutes for the oil to settle and read the dipstick, but the the oil level did not register on the dipstick.  The factory (or dealer) put enough oil in to register halfway up the dipstick, but they must have put 9 or 10 quarts in order to do this.  My question is what could be going on?  Do I fill the oil up to an acceptable level on the dipstick and run the risk of damage to the engine by running too much oil or do I just keep the 8 quarts and run the risk of running too little oil?  Did they give me the wrong dipstick?
Edited by hogrider815
Did you run the truck before testing dip stick so it primed the filter and the rest of the voided galleys
Edited by jaxcam02
One thought, I know fresh oil can look transparent on the dipstick...like nothing was on there even though there really is.
Only thing that makes sense to me based on your description.
Have you started it? If so, what does the pressure gauge show?
I find it very tricky to read the oil on the 2018 dipsticks. Particularly the 0-20 stuff when new because it is "water like in its transparency and thinness".
Also found that one side of the stick seems to read more accurately than the other. Meaning one side will show the level right at the high mark, and the other side will show oil another 2-4 inches up. I don't know if this is from scraping as it goes in and out, or what.
For me, I drain the oil. Then add 1.5gal/6qts. Run the engine until warm or a short drive. Let it sit over night. Read it in the morning, and fill as needed.
The only time I added all 8quarts/2gal called for, it read well over the top mark and I had to pump some out the dip stick.
Stop before you do anything else. Pull the stick out again and be sure it's completely dry, replace and let sit for 10 seconds on level ground.  Pull out the stick, if you don't see any liquid, drain the pan and monitor how much oil you see coming out.  Refill with 7 qts, should see a measurement at the bottom of the stick.  Better to figure out what's wrong with less oil than too much.
Edited by The Zip
Ok so I added 1/2 quart this morning and barely saw anything register on the dipstick.  I drove to work (about 30 min drive) and after work I checked the oil after it had been sitting all day. The dipstick not only registered the oil, but it was over the upper limit.  Will a 1/2 quart extra do any damage or do I need to drain some out before driving? I've attached a photo of the oil mark.
I changed my oil in my 6.2 tonight, it just hit the bottom of the dipstick with 8 quarts, I put 8.5 quarts in it after letting it sit, warming it up, then letting it sit again to settle and it’s about half way in the hash marks. I’m going to drive it tomorrow and check again and will add more if needed, I’m thinking per the dipstick it’s going to be 9 quarts.
I wouldn't think .5 quart over will do any harm.
These engines burn a bit off after a certain amount of mileage anyway.
My wife always told me to push it in a little further when checking her oil but I never could seem to get a "good reading".:P
That stated, 8 qts. hits the top dimple on my 2018 stick. As others have said, I don't add all 8 at once, add some to the new filter before install, start and run, check later and top off. I use both gallon jugs. None left over.
Edited by Capt Bob
  • Haha 3
Straight from the owner's manual:
Quote
Checking Engine Oil
Check the engine oil level regularly, every 650 km (400 mi), especially prior to a long trip. The engine oil dipstick handle is a loop. See Engine Compartment Overview for the location.
Warning: The engine oil dipstick handle may be hot; it could burn you. Use a towel or glove to touch the dipstick handle.
If a low oil Driver Information Center (DIC) message displays, check the oil level.
Follow these guidelines:
  • To get an accurate reading, park the vehicle on level ground. Check the engine oil level after the engine has been off for at least two hours. Checking the engine oil level on steep grades or too soon after engine shutoff can result in incorrect readings. Accuracy improves when checking a cold engine prior to starting. Remove the dipstick and check the level.
  • If unable to wait two hours, the engine must be off for at least 15 minutes if the engine is warm, or at least 30 minutes if the engine is not warm. Pull out the dipstick, wipe it with a clean paper towel or cloth, then push it back in all the way. Remove it again, keeping the tip down, and check the level.
8 quarts is all it should take if following GM's drainback before checking times.
Thanks for posting that, I just checked it again and it's been sitting for about 2 hours and it's right at the top of the hash marks. I put 8.5 quarts in it last night.
  • 3 months later...
I went for my free oil change last week and noticed they added 9 quarts. I will have to check the dipstick this afternoon after letting it sit for at least the two hours. Think I should probably take it back in. Maybe  I can get another free oil change :)
So I know this is an old thread but figured I’d chime in with my first oil change experience on my 2019 LT 5.3L (NBS). I have been changing my oil in all my trucks and vehicles since I was old enough to drive and have found that the amount going in is not the same every time. The dealer did my first change free at 7,000 miles. I just hit 13,000 and decided to do it again a bit early. (Still 6,000 miles between the last change.) I drove about 10 miles, let sit for 30 minutes and then drained. It took 7.5 quarts. I put in the extra half quart for the heck of it per GM’s spec and my dipstick read above the full mark. I ended up pumping the half quart back out this morning after letting it sit overnight. On level ground it reads just below the full mark on the hashed section of the stick. As others have said, it’s easier to add oil then take it back out. If it calls for 8 quarts,  add 7, drive it a few miles then let it sit to a cold start. Few hours or over night. Top off as needed. There is always a bit of residual oil that takes a while to fully reach the pan. Readings can be off if you don’t wait for it all to settle before draining. You wouldn’t think that a quart over is harmful but I have seen seals go bad pretty quick from overfilling the crankcase. Oil is a lot less expensive than an engine repair or replacement. IMHO.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
