just curious what the attorney cost you (or should have cost you if it was free) because if the dealer offers a buyback, I want to know what the attorney and lemon law route costs to compare whats a better way to proceed.
if the dealer offers an out for like $1,200-$1,500 loss to get out of it then it might be a better deal then paying a lawyer and going through all that hassle
$0, the attorneys gets their fee from GM. Like I said, very simple process.
Just took my 2 month old Sierra Dbl 5.3 Texas back to the dealer (headed out of town for 10 days) to see if they can find source of 40-50 mph vibration and rattle from upper rear seat mount. Am coming to the conclusion that the problem is in the front end (motor mounts?), so told the service manager I didn't want them messing with the driveshaft or rear axle. (I could live with this for the next 5 - 10 years, though I'd prefer it be gone!) Accelerating from 40 to 50 the shake is barely noticeable, coasting down (esp. 4cyl. mode) much stronger. Steady 45 mph seems the worst. Anyone know if other GMs with the dual mode (4 & 8 cyl.) have noticed this vibration - at any speed?
Rear seat rattle should be gone with padding the upper mounts. Can't believe they didn't anticipate the problem!
Did u have the motor mounts changed?
ok, I got the truck back and they said they felt it but they didn't do anything at all to the truck because everything was normal and is working fine, this is what the service ticket said:
A CS FEELS HOP IN VEHICLE AT 40 MPH SEE HISTORY
0400 NORMAL OPERATION N/C
627 TEST DROVE VEHICLE AND FOUND COMPLAINT TO BE NORMAL FOR A SHORT WHEEL BASE TRUCK. CUSTOMER ALSO CONCERNED ABOUT WHEEL WEIGHTS ON OUTSIDE OF CHROME CLAD RIMS NEEDING TO BE REMOVED IF HE HAD A FLAT. INFORMED CUSTOMER THAT WHEEL IS CHROME CLAD AND THAT CHROME COVER IS NOT TO BE REMOVED BECAUSE OF IT BEING BONDED TO STEEL WHEEL. CUSTOMER TO RETURN TO DRIVE WITH DMA.
B RENTAL LOANER VEHICLE FOR ONE DAY
100 INTS N/C
C** C/S HE FEELS VIBRATION AROUND 60-70 MPH
0400 TIRES N/C
627 TEST DROVE VEHICLE AT SPEEDS NOTED WITH NO VIBRATION FELT. DID FEEL ROAD SURFACE AND EXPANSION JOINTS IN ROADWAY.
so in other words, they aren't going to fix anything
I have a bit over 2,000 miles on my '14. Plus the 5k miles I did on the company '14. So I've had 7k miles behind the wheel of identical 2wd 3.08 and 4wd 3.42 trucks. CC/SB, 5.3's. LT's. Both have a slight shake. In both trucks, I found that 35psi front and 33psi rear cold pressures helped out quite a bit. one idea that dawned on me is the driveshaft's on these trucks are 1pc, aluminum at that, and have no slip spline. So we have a 8' long aluminum pipe down there. I'd like someone to explain to me what happens in extreme temps and the thing is shrinking and down in 120F Florida expanding. The driveshaft should slip in/out a bit.
A 1 piece propeller shaft uses a splined slip joint to connect the driveline to the transmission or transfer case.
Was climbing around underneath my truck the other day looking around for possible culprits, and when I do I usually use the main drive shaft as kind of a monkey bar to slide up and down. This is the first truck I have owned to where I noticed the main shaft moves around. (Up and down, side to side) due to the transfer case on a rubber harmonic bushing. Could a low density rubber bushing (too soft) be allowing the prop shaft to lose some its centripetal center and what we are feeling is actually the front side of the shaft and transfer case vibrating? Anyone try removing the rubber piece and fabricate a solid mount yet? I've seen people putting cameras under their trucks and looking for axle movement but how about the tc/shaft connection?
They are going to clean up. My brother in law bought two Toyotas just before I bought my GMC. Not a problem one and no V4, not as good on gas or as quick as mine but pretty nice. Im a hard core GM guy thou, happy with mine so far. If it starts shaking its gone.
Everyone forgetting that the Titan will be an all new truck with this Cummins that Toyota is sourcing out from Cummins. Nissan and Cummins have been working on this engine for years. The Titan is a darkhorse like no other truck to date, watch out for this thing, the Cummins name sells itself and will be their main engine.
timfactor- motor mounts not touched yet. Rebalanced and rf and rotated the tires, no change in vibration.
Anyone else with this 40 - 50 mph vibration get it fixed?
Mine, after lots of parts changed out still shakes.
No one solution yet or a fix to this problem.
Transfer case mount is making a lot of sense as a culprit just saying.
I tend to agree, might be an alignment issue from poor drive shaft angles
reading about the calculations needed to realign things after lifting or lowering the truck I have to wonder if the factory setup angles might be wrong
I still don't believe it's a alignment thing because mine does it randomly at 75to77mph
Edited by JC84
Good day all, this is my latest update. I completed my GM Trade assist buy back today and no longer have my vibration but I do have a new 2014 Sierra as a replacement. I so am hoping that GM comes up with a fix because it isn't fair to have to deal with that kind of frustration. Good luck and I hopefully I don't have problems with the new one. Yes I did take it on a 25 mile interstate highway speed test drive and this one right now doesn't vibrate at all.
I have looked through these forums and can't seem to find the link for adding phone contacts to the radio favorites, does anybody know where thats at please? I can't remember how I did it.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
