Contacted BBB last week. Then next day GM calls wanting to know what they could do to help. 1 week later, Gm calls back and nothing they can do "it is at factory specs". Same as before. NO HELP! now I can not get the BBB to call me back to discuss the next step. I have called different times of the day, left messages and still have not received a call back. I guess I will need to contact a Lawyer at this point. Truck is still vibrating at 45-60 and I can not get anyone to look at it or work on it. Shame that I have to fight so hard to get something to work the way it is suppose to. Pay good money for a piece of JUNK.
call six on your side
I am in the same exact situation. I haven't contacted the BBB yet because I was hoping GM or my dealer would step up. The engineer said everything is operating within specs and once he said that basically no one would help any further. The dealership said the can't work on it anymore for this issue because GM wont pay for it and GM said they won't help may with trade assistance at all. I cant even take it to another dealer because it is in the system now for this issue. So basically as long as I own my truck and anything that has to do with vibration I am screwed. The service manager told me I should trade the truck for another brand or a 3/4 ton GM truck because these issues are inherent to the 1500 model. I was at the Ford dealer yesterday and have a deal worked out on a F150 but I just don't like it as much as my Sierra and it will cost me $5,000 to get out of mine and into a new ford. I think GM's solution to the problem is setting a set of specs wide enough to state all the trucks with issue are within spec because they just need to cut their losses somewhere with all the issues they are having right now. If they lose a few customers in the process they are okay with it. I'm not sure if it's worth my time and energy to proceed any further and that's what the are banking on. It really sucks because I love everything else about the truck.
File with BBB. It only takes a few minutes and will show GM you are serious. The link is in my sig. Whaddaya got to lose?
I'm gonna look into filing a class action lawsuit. If anyone is interested in being part of it let me know. I read almost all the pages in this thread and I'm surprised no one has done it yet. It's been 2 month since the dealer has had my vehicle to try to fix the issue.
I tried to go to another dealership but they told me since I didn't buy it from them I was sol. GM customer service keeps telling me they are waiting to hear back from their internal resource.
I'll be damned if I lose 5k on trading it in because GM doesn't want to address the issue.
I've already filed with BBB waiting to hear back.
Edited by sideoftheroad
My dealer has several vibrating trucks, I was the first to put LT tires on, and correct the vibe, they just put a set of LT bridge stones on another truck, and it smoothed it out. Seems that's the fix
I think the "lightweight" p tires give the best gas mileage, but can't handle the weight/speed for some reason.
My new 2014 sierra has a vibration issue that starts around 70 and gets worse the faster i go. The odd thing is it comes and goes and is worse on smooth asphault than on rougher roads. The steering wheel and pedal are fine but the seat vibrates pretty bad. I only have 1200 miles on the truck and havent had a chance to go to the dealer yet.
that's mine exactly
droppin it at dealer Monday for the shake and the driver seat butt heat not workin back is.. hope they resolve both love my truck got it set up just the way I like it
2014 GMC Sierra 1500 SLT Crew cab short bed 4x4 Z71 5.3L 3.42 axle ratio. (Vibration issue solved)
I purchase my truck a month ago. When I took it for a test drive got up to about 50 mph and it shook really bad, went right back to dealer and they said the tires were flat spotted and should smooth out in about a 100 miles if not they would replace them. So took it back down the road again and it was all ready alittle better. The build date on the truck was 4-14 so it had been sitting on a lot for about 7 months so made since to me. On the way home with the truck the vibration was not to bad almost seemed gone at times.After a few weeks had passed did some testing and on relly smooth road is where the vibration was the worst. My tire psi where all at 34 psi. The vibration was really bad from about 73 to 85. I called the dealer told them the problem and the shop foreman told me give it until 1,000 miles if not gone they would replace the tires. So a few days ago took it back to dealer with 1065 miles on it. They first did a road force test on the right front tire Goodyear wrangler sr-a P275/55R-20 that read 41lbs then the right rear 72lbs. They said forget took them off. I had already told them in advance that if it was the tires I wanted to replace them with a set of Michelin LTX M/S2 so they had already order them for me just incase. I told them I would pay the differance between the goodyears and the Michelin if thats what it took it cost me 107 dollars was glad to do that. My vibration is gone. If you really and try to feel a vibration on a smooth as can get road you might feel alittle if you really really try but as good as it gets to me. I think most of the the vibration issues are tires not to rule out some with drive line issues.In the beginning when it really shook bad on the test drive and it got better knew it was flat spotted tire on mine since it set on a lot for 7 months. Hope everone gets there sierra's and silverado's smoothed out. If GM would just admitted they have a problem with these crappy Badyear tires recall all of them if would solve a lot of problems
Edited by southern_sierra
New Michelins didnt fix mine. Glad for those of you that did get your truck vibration fixed that way, or fixed in any way.
AFA class action lawsuits, I dont know everything about them, but it always seems that when I hear about them being settled, the people who had actual damages are awarded pennies on the dollar, while the law firm representing the class action gets millions. Im not interested in making more lawyers millionaires while Im left feeling shorted.
Exactly what I did on my own as well
Hey everybody, *********************
I've recently resolved my shaking/ vibrating issue and would like to share my story to help out:
I have read through most of these pages before going to have my own new 2014 Silverado 1500 LT worked on due to significant shaking/ vibration at ~ 65-80+ mph. I first took it to the dealer and told them what was going on, came back a few days later to pick up. I asked if they fixed it, and they hesitated and said "I don't know, you tell me. It's a lot better." .... not what you want to hear. They say they did a Road Force Balance and found all 4 tires were out of spec. They claim to have put them back into or very close to spec. Anyways, I get out on the road and it's quickly apparent that the shake is MUCH worse. It was now shaking up and down and side to side. While driving down the highway at 70-75, one of the weights comes off the wheel and strikes the inner fender, which believe it or not actually made it ride better.
Needless to say, I am very upset. So upset that I'm physically sick. Feel that I have made a huge mistake by getting this vehicle and am now trapped with the payments. Next I do a quick google search and drive to an independent family owned tire shop and tell them about it. They ask what tires are on it and are not at all surprised by the issue. Goodyear Wrangler's are circular pieces of garbage. I get there and meet with them. They disclaim they don't really know what the problem is and don't want to sell us new tires only to have the same problem. So we decide to pull the wheels/ tires off and put it on the balancing machine. The owner invited me to stand with the technician and talk to him as he checked the balance. (not road force balancing, just normal balancing on a Hammerhead Technologies machine) The front left tire goes on the machine with current balancing weights still attached from the dealership. Guess what.... its 3oz off on the outside half of rim and 0.5-0.75oz off on the inside of the rim!!!!!! A total of 3.5oz off. They say the average person can detect 0.5oz and greater, so this thing was WAYYYYY off.
Not only that, but they had put weights all around the inside of the rim to counterbalance some of the other weights that are in the wrong spot. Tire guys say the weights are all supposed to be grouped together, otherwise you are just chasing bad weights and furthering the problem. All the tires were balanced poorly. While watching the tires spin on the machine, I could see, on every one of them, that they were not round. I'd say they had about a 1/4" to 3/8" or so of up and down difference/ bounce while spinning ( after fully balanced by tire professional). Technician and owner say that if it was a Michelin that was that much out of round, they would send it back for a new one because they are much better tires.
Fast forward balancing is done and I'm driving on same goodyear wrangler. Immediately better and very smooth at 65 and below speeds. Now has very very slight vibration, not a shake, at 75 mph and is quite smooth below that. Turns out it's the friggin' tires after all!!! The remaining vibration is due to the fact that THEY AREN"T EVEN ROUND!!!!!
A guy on here called Stex said it over and over again that you need to go somewhere else other than the dealership to get this done. He was completely right (even though he doesn't even have a Silverado lol) I wen't back and confronted the dealership about this. Apparently the guy at the my chevy dealership doing the balancing was just hired on, was a troubled teen, and was apparently using a poorly calibrated machine with no training.... Don't think the dealership is a place to have competent work done, that's for sure.
Now I have driven over 1900 miles on them and they have smoothed out a tiny bit more, but a small vibration is still present at 70-80 mph. It is very slight and almost not noticeable anymore. I expect it will disappear when I get new tires (Michelins hopefully). On smooth roads the truck is smooth, on rough roads the truck is rough. The thing is stiff so don't expect a glassy ride all the time. I hope this helps.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
