Update
Not the drive shaft.
The dealer doesn't know whats wrong and they are reaching out to GM Tech for answers.
Found out why transmission factory rest made no difference.... They didn't do it.
Edited by oneandzero
So, 5.3's do it, 6.2's do it, 6 speeds do it, 8 speeds do it, Z71's do it, LT's and SL's do it, different gear ratios do it, steel wheels or alloys do it. What is common to all of these trucks? From the front: Wheel bearings?, cv axles?, brakes?, struts (springs anyway)?, Transfer case(?), drive shaft?, rear axles and bearings?, rear ends?, rear brakes and springs.? are six cylinder guys having the same issues? I am intersted to see what the non road test, wheels off the ground results will be. I know my suspension pics up every crack in the road so, i am willing to bet that anything could be causing this right down to buffeting the underside of the truck and transferring through the cab. but then, i am just guessing
What is common? Questionable parts and assemblies built in China or Mexico to sloppy tolerances and with marginal quality control, super cheap OEM tires, and shoddy assembly quality. Mounted on a super stiff frame that amplifies the combined vibration and wobble effect of all these rotating parts.
And for GM to try to fix these trucks is a real operation "Polish the Turd". That is why there is no fix.
Edited by pm26
Ok. So are we thinking the same thing here? Not engine, not transmission, but is a rotating component? Which leaves front and rear axles and drive shaft. Could it be amplification of a problem through the stiff suspension? I guess with all of the different vibrations called out, i will stick with the 65-80mph one lol.
Also, if it isn't in the steering wheel, can it still be in the front end?
I would also think if it was in the front end it would make the steering wheel shake a lot more. I think it is in the rear somewhere but there have been some full rears changed with no fix but it could also be a bad batch of rear housings or axles.
I think they have to find a truck that does not vibrate and start trading parts with a vibrating truck and see if they can get the vibration to change trucks. I don't think it would take more then two days to go through just about everything one at a time.
This can't be that hard for them to figure out. It must simply be an expensive fix and until sales drop off, they are not worried. GMC sure had a lot of advertising for trucks during the NFL games this weekend. They don't seem worried.
They are not worried because it effects a very small percent of the trucks they produce. Mine still has a slight shake at 70 mph and some off and on vibrations at lower speeds based on outside temps. They have produced over a million of the K2 models now so a few thousand of them that vibrate is not going to phase them. I seen the same thing in the early 2000's when GM had a piston slap problem on some of the 5.3 engines. Forums were going nuts about it but in the end the issue was forgot about.
Edited by tnchevy
I'm just surprised the issue has been span across multiple years. If it was a bad batch or only in the initial production year, maybe i could understand. But for so many 2015s to have it as well, boy that's scary. Maybe this is truly a flawed truck.
Edited by Shimmy Bang Bang
Do you have this problem pm26? I think you have part of the problem in the stiff frame/mounts amplifying an otherwise minor vibration that may not have been felt in previous years but still may have existed. I don't know if suppliers have changed between 2013 and 2014 but if they haven't then what design changes were made. trucks have been made in mexico since 1994. Mine is made in Mexico and doesn't shake
Edited by Willshire
This is one reason that i can't see them looking the other way because of cost. If they new what the problem was they sure would have had it fixed in the next release. And now it looks like it might be in the 2016's also. I don't think it is only a 1000 or so trucks. Yes it might not be the majority but I bet it is close to half it's just not all trucks and SUV's get up to 65 or 70 mph that much on a regular basis. Something definitely changed from the 2013 models because I had a great ride in mine and wish I did not have to let it go. This has to be worked out somehow.
The only way to work it out is to start a BBB case, take your truck in for the amount of repair attempts you are legally required to do in your state, based on lemon law (4 in Michigan), file BBB complaint online, save ALL repair and service paperwork, tell BBB your truck still shakes after "final repair attempt", setup arbitration date, wait for GM to call 1-2 days before your arbitration date and admit defeat, get your money back or new vehicle. This process is 100% FREE, just takes a little time and leg work.
There are more details, but this is the only way to get out of this mess. I have (almost) gone through the entire process twice now. They fooled me into taking another truck the first time, not this time...I know better.
I test drove a dozen trucks when searching for my free replacement 2015...THEY ALL SHOOK ON THE HIGHWAY. All of them. I couldn't believe it. I ended up picking the smoothest of the bunch...which ended up getting worse as time went on.
Stop spending your own money on guestimate fixes. Stop spending your own money on new tires. Get the BBB involved, and get yourself out of this nightmare of a purchase.
Where in my post does it sound like I have been trying either to get another truck or have been throwing money into my truck?
I know what to do with it, it is just I will have a hard time getting what I would need out of it to be able to afford a new (other brand) truck. My 2013 was a lease and so is my 2015. I still like the truck a lot it is just the vibration problem that is it's downfall. That is why I was waiting to maybe get into a 2016 but they might be in the same boat as the 2015's. I have not spent a dime on any changes because I can read here that so far NOTHING has worked. I feel the same way as to why someone would have a brand new $50,000.00 plus truck still under warranty and throw a bunch of their own money into it to try and get it figured out. I guess some just have a whole lot of expendable cash.
Mine is mexico and shakes
Is it rattle your teeth or make it hard to see shake? Or is it a mild "tire out of balance" type shake? Mine has a very slight vibration but it is currently caked in snow so i chock it up to that for now
this is probably the best way to show it.... my truck kinda shakes. I have a phone holder that plugs into the cigarette outlet, and even without a phone in it, it rattles around
Has anyone removed the front airdam to check for a high speed flapping? The vibration that only appears over 70 mph (unlike the "tiny rumble-strip" that appears around 40 to 50 mph) could be wind resistance related....?
No air damn my vibe is 76+ mph, also get a slight vibe while decelerating 50-35. Also have a 2" level if that changes anything
    • Looking up on the web you can the information that would seem obvious. You asked engine components to do more. You get more wear. The answer is they can last just as long but required more maintenance. Apparently having to change lifters, cam and associated components are maintenance or repairs. In some research the normal life span of valve train components are 80-100 miles with 3-5K miles oil change. So the next logical conclusion would be cost per mile. I use that analogy with my wife all the time with vehicles. My Odyssey is approaching 170K. The cost per mile will go up at 200K with maintenance. Looking at a low cost car. A K-4 with a 10-10 warranty. Selling my Ridgeline that’s about to hit the same maintenance milestone. My argument becomes not only I get worry free driving. But at no cost increases. Because I take the money from my Ridgeline and maintenance savings and other potential savings. I’m driving for free. So tying it with a bow. It makes you wonder. Is this a grand conspiracy by the auto makers? Raise the potential maintenance high enough. Buyers by extended warranty to 100K miles. Do the minimum maintenance required. Trade in at the warranty end. How long should they last? That question is what keeps people up at night. The answer is much more complicated than it used to be.
    • Could you cite your source on this?  I cannot find any reference to the US secretly taking the oil.  I find references that the US helped oil tankers move through the Strait of Hormuz, but nothing about what you're stating.
    • Same thought, also the everything doesn't have the details real photos do (talking about the noise in the photo)
    • Since the media YOU and your buddies are programmed to watch failed to mention this, I'll fill you in.   Trump admitted today that we've grabbed 150 MILLION barrels of oil from the Iranian tankers locked in the Strait by our Navy. We turned off their transponders, took them out to sea in the dark of night since they have zero radar capabilities anymore, offloaded every drop onto another vessel, and put them back by morning so no one was the wiser. That oil has been en-route THROUGHOUT the entire conflict.   Main reason he admitted this is to let even guys on our own side who joined leftists in complaining about the prices that he hears us all, and has taken steps to make sure this didn't spiral into a BAD situation ... just like the mainstream media has been PRAYING would happen, just so they could gloat. Amazes me how these people are rooting for the destruction of THEIR OWN HOME, just to make a President they don't agree with or like look bad! That's next level TDS!   I know your not capable of giving our President the benefit of the doubt, again due to your deep programming, but THIS is why oil never hit $150 a barrel as predicted by your programmers, AND the reason oil continues falling. Like I said before, Trump's got a plan, and this is proof of it. By the end of his term, we're going to be in GREAT shape for a change!   Since I just spent $3,000 this week on #2 heating oil and gasoline, the war most certainly is ending! 🤣   https://mxmnews.com/article/ba359ac9-2711-4851-92de-187f2400f2dd?breaking-trump-cancels-iran-strikes-deal-now-approved-by-all-parties
    • No leaks. Replaced the condenser 3 years ago. Problem was found to be caused by the A/C blend door actuator. Just replaced it and it's blowing out the cold air it used to when I bought it.
