I'm having an Air Lift system installed January 12th. My truck doesn't have the notorious "Chevy Shake". So, can't comment on that. I'm having the install done for towing. However, I've talked to some people who've had the install done and they say that when driving about with no load and with a minimal amount of air in the bags, just enough to take the weight slightly off the rear springs, it reduces jounce that is common with leaf springs. If so, that alone will be worth the install as the soil here in the DFW area is black gumbo and expands and contracts significantly depending on rain and drought conditions causing the roads to buckle badly. Anyway, I'll give feedback on the system once I use it some, make a tow, etc.
Yeah mine said that in sorts and I called bullshit when I made him ride with me in an on the lot used 2012 and it was perfect! I do have something else I'm gonna try and that is to take a diff carrier with ring gear installed and check runout on the outer portion of the gear and then check balance. Some have stated the ring gear was their issue and gm did a gear change. Soooooo on to the next step. BTW i found that the out of round axle flanges that I just tested had over 18 grams of weight that i turned off of the axle that i trued up. That's a helluva lot!
RT
RT are you still having issues with vibration? I thought yours was resolved?
Happy New Year Everyone
Just to update everyone on the rumble strip vibrations I was experiencing. I got the truck back 2 days ago and so far so good. Here is what the dealer reported:
Road tested vehicle and found possible tire/wheel vibration. Removed all four wheels and road force balanced to find one tire out of range. This tire was replaced and then vehicle was road tested again. The vibration improved but was not eliminated. Checked for TSB's and none were found that directly addressed this concern. Contacted TAC and TAC suggested to utilize TBS PIP5149B. I followed all instructions of this TSB, checking for excessive spark retardation and connecting rod oil squitter condition. There were no conditions observed. TAC then directed me to utilize DOC ID#2102430 where I checked the operation of the control solenoid within the transmission. When commended to the on position, It registered full pressure and when commanded off it registered 0 pressure. After completing all tests found that TCM could not be 'pulse-width' tested, only command on or off. With these measurements we determined that the TCM was sending an erratic signal causing the torque converter to be commanded erratically. This caused potential damage to torque converter. Therefore, I replaced the TCM (Signal) and torque converter (damaged internally). Road tested vehicle; now operating to GM specifications with no vibration when tested under the original conditions.
I have also noticed that the "floating Tac" condition I had earlier is no longer present.
Brandon, I think you might be my hero!
Mine feels like rumble strips on occasion and my TAC bounces on occasion to with the cruise!
I'm going to take your diagnose into the dealer.
And drives perfect the rest of the time....
RT
18 grams? That's like a half ounce of "Pot" A 5,000 pound+ Truck with 1/2 ounce of pot on one side vs the other? Really, I am going to the garage to burn one because now I have officially heard it all. I can't comment any more on this sorry@
18 grams of weight on an axle flange translates to roughly 25lbf based on 2000RPM, which will increase exponentially as RPM increases
At 100-118 a little shimmy and up around 140 it was a pretty good vibration but after cutting the axles it's damn near perfect. The driveshaft truing fixed 96% of it. Sorry for getting pissy with the Pot smoker but I'm not taking this subject lightly, and further more someone questioning my competency as a 30 year Machinist kinda set me off a bit. As I stated in C6Bills post I will be checking the ring gear runout not that mine needs any more tweaking if it's off I will clean it up and if not i'm satisfied. Just trying to help everyone out guys.
RT
I knew the pot smoker couldn't figure that one out, it's some people you just can't reach! I worked at an automotive machine shop for 10 years and 4-7 grams on a connecting rod and crankshaft counterweight was ok by factory standards but not in the HP engine building world.
RT
I think most of us appreciate the information, RT. This problem sucks and I'm finding myself wasting roughly 2 hours a day researching. I'm still waiting on a GM engineer to get back to me.. Only thing that I noticed that differed from your experience is that my truck is perfectly smooth 55-60 MPH. So I'm wondering if i'm having a different problem than you. I have noticed the "floating Tac" that was just mentioned while driving down the road. Even at an idle it will bounce and my truck will shutter occasionally, which maybe another problem itself. I'm forwarding this information to my dealer as well.
Edited by Schmidt152
Same issue just at different MPH because of the 4 different gear ratio options we have.
RT
Could it also be the different gear ratios accompanied by different flange imbalances? In other words the same gear ratios vibrating at different speed because the flanges out-of-round varies?
Here's an update on my truck since it has been 2 weeks since I installed Yukon Gear rear axles. The truck has been shake free since installing them. I have driven on multiple smooth highways at 70+ mph and no shaking.
It sure could.
MRW412
That is awesome.... I really think we are narrowing this vibe down!
RT
Edited by 07Softail
Could you give more specifics about your symptoms? Describe the vibration and location in the cab? Was it more noticeable in the steering wheel or seats or just a vibration throughout the truck in general?
After reading about the ring gear fix, wonder if they were cut right to begin with, not runout but actual tooth to tooth contact? Maybe not hardened correctly, some softer spots?
Interesting topic to follow...
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
