Well, my truck went in for the first round with 1500 miles on it, vibration since new.  Vibration from 70-80 (worse at 75) and a "washboard" vibration slowing from 30 to stop.   They road force balanced and said both concerns were fixed...yeah...okaaay.  Round 2!
Well I'm a new owner of a 2014 sierra slt crew cab with 67k miles. I also am experiencing vibrations like most of you are. I am planning on swapping the shocks on this truck with some bilstein 4600s to see if that'll help or fix the problem. Could any of you lead me to the right part number so I don't order the wrong set. Thanks in advance and glad to be a part of the group.
My 2016 SLT Crew Cab started the shudder at 20,000 miles. Before that, no issues at all. Took it to the dealer who told me in plain English that it was an issue with the original fluid used in the torque converter breaking down. Explained that they would have to flush the torque converter 3 times, replace the fluid with a new hi performance type and do some computer re-programming. Drove 400 interstate miles the next day and the truck is like new again. It was handled under warranty and here is the actual wording from my service invoice: "Torque converter shudder, check as per DOC 4526930 RN PICO found 28 HZ shudder. As per DOC perform ECM/TCM update and fluid exchange and setup. Trans operating as designed. Trans in learn mode next 2-500 miles"  From all the horror stories about this issue that I had read I thought I was going to be starting the process for a Lemon Law claim. I seem to have come across a dealer that knew exactly what to do. May not be the fix for everybody but it sure worked for me.
Also looking at my leafs it appears that they aren't exactly straight. I'm new to vehicles with leaf springs so I'm not sure if that could cause the slight vibration I'm seeing at different speeds.
Is your truck a 5.3 6 speed or a 6.2 8 speed?
4 minutes ago, keysgmc said:
5.3, 6 speed
That's good news for me. I only saw the TSB for the 6.2 8 speed. Been to the shop 5 times, built a new driveshaft, replaced rear axles, 3 sets of shocks, 3 sets of wheels and tires etc. You just gave me a little hope.
Was there actually anything wrong with the rear differential? I seem to have all the vibrations cured except for one I think is coming from the rear diff or axle shafts.
Thinking about this shock too.  I’m on 4 Wheel Parts mailing list so receive their catalog periodically.  I talked to their local shop recently and was informed this is the correct shock for my truck considering want I want to achieve (smoother ride) and being it is stock and has no lift.  Price quoted was $96.99 front, $79.99 rear ea.  Total drive-away price, parts, labor, taxes, extended warranty was $864.33.  Seemed kinda pricey to me.  But, it’s been a looong time since I did a DIY shock replacement.  How do these prices seem to you.
The $864.33 seems steep to me for extended warranty aswell. I'm going to try some spring clamps on the leaf springs and see if it helps any and if not I'll pull the trigger on a set of 4600s
Yeah, agree, appears steep to me too.  I think there’s about three or four hours of labor in their calculation which seems excessive for a trained tech working on a vehicle up on a lift.  But, like I said, it’s been several decades since I’ve done a DIY on shocks.  And, I’m not starting again, lol!  About the spring clamps, I guess I don’t understand the theory behind them.  It seems to me that clamping the leafs down tight and compressing them against each other would make them even more rigid and thereby cause the truck to ride even rougher.  But, I believe I’ve seen in this thread posters who’ve claimed it works.  So, what do I know, nada!  Let us know how it goes for you.  If it improves your ride I might give it a try.
The rear axle hub flanges were out of round on my truck. You will need to pull of your wheels and brake rotors, spin the driveline and film your rear axles moving out of round and side to side. I took my video to Chevrolet and showed it to them, they started to tell me what a defective vehicle it was until I told them it was one of their trucks. Then they gladly replaced the axles, bearings, etc...
Bought my 2015 Silverado in Aug 2015. From the first day ,my truck had the shaking issue. I was told the tires had flat spots from sitting and that it will go away after I drove it awhile. Never did. I was told the 20" wheels do shake on these. Not true!. Was told it was the Continental tires. Went through Continental's hoops, and they blamed the alignment of the truck.So back to the dealer. They put it on a quick check alignment machine out front,and said its good. After 39000 miles and two and a half years of BS, I had enough. I looked on line and found GM complaint number and filed a case on the shaking.They had a GM consultant that works for the dealership ,work with me all day changing out wheels and tires and taking it for several rides. He put it back on the quick alignment machine out front again,and told me it was out a little but was within GM specs. When he printed out the alignment page I noticed it was barely within specs. In fact the camber in each wheel was at opposite ends of the spec.I had them do an alignment and no more shake. Even with the worn out tires the truck doesn't shake.Be forceful if you have to but make them check the alignment in the shop, NOT OUT FRONT, and ask for the print out of the alignment to see how close  it is to spec. After two and a half years, it worked for me, maybe you have the same problem. When I ask why it took so long to find. The GM consultant told me, under warranty work, the technician is only allotted 3/10 of a hour ( about 18 minutes) to trouble shoot a problem. GM only reimburse the dealership the allotted time, unless they find a problem. Then GM will pay for the repairs. If the dealership goes over the allotted time,and doesn't find a problem, the dealership has to eat the bill.Something no dealership wants to do, so they tell you they can't reproduce the problem and give it back to you.The fight over who pays the labor cost is between GM and the dealerships, and the vehicle owner gets screwed.Either by not fixing the vehicle, or trying to make you pay for the bill, even though you have a warranty.
EDIT: Just got off the phone with my local GMC dealership service center. Stated that shaking at speeds in excess of 75+ mph has been found to be the nature of the fully boxed frame unloaded. He told me he drives a 2015 Sierra 1500 with the same symptoms and searched high and low for a solution when he first got the truck. Found out that placing weight in the back resolves the issue. Has anyone tried this?
ORIGINAL MESSAGE:
2014 Sierra 1500 5.3L 4x4 3.42 w/ 49,500 miles
Jeeze. Just got my truck a few weeks ago and noticed the shake at speeds in excess of 75mph.
Lots of pages on this topic, lots of reading!
So far, the only solutions I can find are:
  • Driveshaft balance
  • Spring clamps
  • New shocks (Rear only? Seems to only cover the actual problem)
  • Torque converter (seems to apply to the 8-speed only)
I may be missing a few others, but I would love some sort of sticky that summarizes the solutions that have worked, and which engine/transmission/axle combinations it works for. Feel free to PM me your year, engine, drive train, transmission, and axle because I wouldn't mind compiling this info for everyone.
Almost at 800 pages of information here, there must be a solution.
Edited by Bill Reinhardt
Added conversation with GMC dealership
Kinda funny to say it effects a small amount of people in the same post as referencing an 800 page thread
Not sure where you guys came up with this small number of people thing
Well you got a point small numbers 800 Pages , yeah lots of problems. However, it seems like each truck has its own issues some other people share some other people don't experience and don't have the time or interest in helping anyone.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
