The vibration is in the aluminum driveshaft. I replaced mine in my 2017 LTZ 2WD with a steel two piece rated for a 3/4 ton truck. My truck has been smooth as silk at all speeds ever since. I'm approaching 10,000 miles on the driveshaft. Cost was under $800 from Performance Drivelines. Look them up and leave the Chevy Shake behind!
On 7/20/2018 at 12:28 AM, Pinnacle said:
you have it on your 18 with zero miles on it?
Very minor, but yes I believe it has some sort of harmonic vibration.  The 17 GMC was bad.
On 7/18/2018 at 1:02 PM, wmadden said:
Okay, so we're 797 pages into this thread and GM obviously isn't going to do anything to fix the problem... I have two vehicles, '17 Denali crew cab and a '16 Denali Yukon XL both with the shimmy/studder.  How many of you are planning to trade in for a '19 with the new design, or are you done with GM and going another brand?... and if so, what are you looking to move to?
Never buy a first year model which the 2019 Silverado 1500 is.  However, I my buy the 2020.  We shall see....
It sux that you have to fork out $800 to fix a problem that they are A: Aware of (based on the fact the settled with 1 truck owner for $13 and let him keep the vehicle, and one other owner they bought the truck back) and B: should be covered by the BTB warranty. Turns out, I took mine in last Friday morning only to have them tell me I was 150 miles over the warranty(36K they said could go to 39k and I was at 40,500) and would need $140 diagnostic. I also know the process and order of operations I would have to go through just to get to the point where they would finally either tell me "it's normal" or Lemon Law it. Is it worth it to stick it to them, or just trade it in for a different maker.
On 7/20/2018 at 4:32 PM, contenderv07 said:
mine doesn't start until it hits 70 mph, then until about 76 it starts to die down, but like someone else said, this shouldn't be happening to a 45k + vehicle, especially for how long they've known about it. I've got a 2018 with 1000 miles on it BTW
On 7/20/2018 at 12:32 PM, Roscopcoletrain said:
So is this a constant always at the same speed shake/vibration or does it come and go for people?
The consensus seems to be between 70 and 80 mph. Mine is at 70mph to about 75-76.
Going to initiate my extended warranty through my CU since the dealer told me I was 150 miles over the bumper to bumper. They must know they make crap otherwise they would have the Hyundai or Kia warranty of 10 years 100,000 and stand behind their product.
So it happens every time at roughly the same speed?  Its not something that shows up one day, gone the next?
No, it's pretty consistent across most of the threads.
On 10/29/2014 at 8:51 AM, Silverado-Hareek said:
Yes me. And I can't pinpoint the cause. I suspect the tires are the problem. I noticed it mostly back in the spring and then it went away around June. Since then I haven't had any vibrations at all except for 2 specific instances driving to work in September. The fact that it comes and goes and seems to be related somewhat to the outside temperature has me leaning toward the tires. How long it sits without being driven is possibly affecting it too. The truck drives great otherwise when I don't feel the vibrations in the steering wheel.
I will add though in general, with the stiffer suspension on these trucks, I personally feel more of the road than I did in my 2007 Silverado and that's after driving 3 different 2014's that didn't have vibration issues. So while there are vibration problems that people are experiencing, I think the combination of the stiffer suspension and the electronic power steering together transmit road imperfections to the driver and passengers more than the GMT900's did.
You can see my truck specs below my avatar. I have Goodyear SR-A tires that came with the truck. As soon as they're ready to be replaced, I'm getting either Michelin AT2's or BFGoodrich T/A KO's.
Well 4 years later, I can confirm it was my tires.  I just put on BFG K02's in load range E last week and installed bilstein 5100 shocks and so far the truck drives great.  The tires are a little heavier now and you can feel that, but I don't feel vibrations in the steering wheel like I did with the Goodyears.  Of course, this means that in my case it was the tires and not everyone has the same type of vibration.  I do still think there are multiple types of vibration problems out there related to tires, the driveline, etc.  But for the folks with stock tires that suspect the tires are the culprit of your high speed 60MPH+ steering wheel vibration, it's likely your tires.
Edited by Silverado-Hareek
You sir, got lucky. There are countless threads on here where people have changed one or more of their tires, rims, rear suspension, drive shafts and still have the issue.
I said screw it, and took it in this morning for a tire balance and they said 3 of them were way out of balance. I'll start there and see if it helps.
yea thats the bad part.... I just bought my truck and I'd hate to possibly spend 1k in tires, or 800 for a new drive shaft, etc.. without knowing 100% what it is.  I did get my road force balance yesterday and it did help SOME, but still....
I know it’s easier said than done but if you just got yours, a tire shop should give you credit for your existing tires since they can resell them
When I bought my truck, I bought new rims and tires for around $1400 and sold my stock rims and tires on offerup for $800, so it only cost me $600 for the upgrade.
Follow Up:
I took my truck to Firestone, since I was out of the GM 36k B2B Warranty, and paid $60 to have my tires balanced. Turns out 3 of them were pretty far out of balance. Since yesterday, It rides a lot smoother in the "Chevy Shake" speed range of 70-80mph.  I have a long road trip coming up this Friday and will report after I get back. Hopefully I am lucky that was it.
I guess I need to see how much discount tire would give for them. I'm assuming the sooner the better:lol:
I Don't see how you can say it was the tires since you replaced the tires and the shocks, have you put the old shocks back on to see if the VIB comes back with the new tires.
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
