1 hour ago, Snoringbear said:
I’m guessing you’re dealing with torque converter shudder and not the dreaded Chevy Shake.  Ask your dealer to perform the TSB which is complete flush, filter change, refill with new type fluid and reflash.  Appears to fix most torque converter shudder problems.
:thumbs: Its booked in next week to have the eps reflast, so will get them to look at it again.
Video of what my truck is doing. So if you watch the rpm, it sorta blips. everytime it does that, you feel a shake. You can kinda hear everything rattle a bit. Cruise control is on, but doesnt have to be for it to do it. Seems almost like the tc slipping no?
just to  add, I dropped off the truck this afternoon and they gave me a 2019 Canyon. Night and day difference in driving that than my 2018 truck. Mechanic said to "be patient" then later clarified that they had a couple of Sierra's in for the transmission issue. We'll see what happens. I did ask about about the F150 on the lot :lol:
21 minutes ago, silveradosid said:
rosco did you notice that it is happening when the engine is switching to v4 mode my truck does the same thing everytime it switches and i get a vibration when it does it
Doesnt matter for me. I can run it in M7 and it still does it.
Truck went in today... Needs a TC. :thumbs:
5 minutes ago, wmadden said:
Not to bum you out, but I went through the same paces to include a new TC.  Still shudders:-(
yeah, Ive heard its hit n miss. Cross that bridge when I  come to it I guess
Hello all,
1st post for me, I have been reading the 800+ page saga of the Rear Vibration issue and appreciate ALL of the time and patience everyone has spent posting on here for others to read/learn/use.
I have a 2017 GMC Sierra 1500 Reg Cab Long Bed that has the vibration issue.
Image may contain: car
Its currently on its 3rd trip to the dealer as of today. My Service Manager told me that GM is aware of the issue and that for many it is a tire issue. He said the Specs for this series of trucks is very slim for the road force variation tolerance. He said that it calls for under 15 lbs or less and only certain manufacturers of tires can fit these specs. They are replacing my 20'' tires with Bridgestones today and will do the road force on all of them. He also said that with the long bed I will notice more road inadequacies than the short beds. I asked him if he thought Air ride would help and he said he would ask around about it and then I also asked if putting Bilstein 5100's on the rear would also help. He thought it already had them on it but another mechanic clarified they use the Rancho's.
I've done a LOT of research on this issue and one of GM's responses was "Suspension components and calibration will NOT provide a ‘sofa-on-wheels’ type of ride, and will NOT eliminate tire/wheel, propshaft, rear axle related inputs/disturbances; they are designed specifically to address the rough, harsh rough/harsh/stiff ride concern."
I also watched some of GM's training video's for the Hunter Eng video's as its possible some of the dealerships have been doing the road force without doing the force matching:
For the record I am not an expert or a certified technician, Just an idiot with a shaky truck that wants to get it repaired.
One of the guys at the dealership said I could always throw 2 sandbags in the back of the truck and that may help, my response: Is that under warranty and what's the GM part number for the Sandbag?
Will post when I hear back from them and have fingers crossed for a smoother truck on that first drive!
Joe
Hello all,
40322406_2251311261549126_8286774922412294144_n.jpg?_nc_cat=100&oh=c61347f8903673050af05add63c9b2a1&oe=5C50B883
Joe
Nice truck! Reg cab long bed is a great looking truck! I hope you get it sorted out.
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
