I had my dealer fix the seat movement issue and the fix lasted for about 2 weeks. It is now worse than it was when I brought it in...
Update...I just took the time to actually look at the fix and noticed the tab on the new retainer clip had popped out of place. It looks like it is going to keep happening so I am going to resort to the hose clamp fix.
Do you guy's not read the posts in this thread? Why don't you just do the clamp method fix and be done with it? No dealers, no down time and you don't have to worry about it being worse than before you brought it to the dealer. There's countless posts of members who have brought their trucks back to the dealer several times for this. Save yourself time, trouble and aggravation.
I agree, there are 51 pages of this mess, and I'm one of the dummies, that tried to let dealer fix and ended up with a ding in my left rear door at the dealer, did the hose clamp over a year ago and no more problems, and if it ever loosen up, I'll just retighten ........................I like ..............DIY
Edited by myunclepapa
The "seat slop" issue got me about eight weeks ago. I waited a couple weeks of never remembering to call my local dealer during working hours but, once I called, they set up an appointment for the following week. When I dropped it off mid day, mine was the second vehicle of the day to have the issue. They did dig into it and found the lower seat frame needed to be replaced. Took about 2 weeks to get the parts in and then they replaced it.
The seat is great now. Sure, I need to remove a plastic trim piece and install it properly but, at least my seat is fixed. The dealer didn't mess around with clips, shims, or any other sort of work around, they went right to the actual issue and replaced the faulty part instead of trying to band aid it.
Edited by Hozer
They didn't give me too many details about the diagnosis but I'd heard of the clips as an unsuccessful fix so I was just glad when they acknowledged something was faulty and actually needed to be replaced.
Is there a bulletin # for the seat on a 2014 GMC Sierra Crew cab?
Ok here we go again. Please read the posts in the thread. There is a bulletin but people have brought their trucks back to the dealers several times for this with no success and ended up using the clamps. Save yourself time, headache, aggravation, a dinged up door, seat poorly put back together and most times being worse than before it was brought to the dealer. DO THE HOSE CLAMP FIX.
Got my done at the dealer...they went by the bulletin and resolved it..so far so good almost 3 weeks now.....
You can "Do it yourself" and hoseclamp to your hearts content... but if the lower seat needs replacing, it needs replacing. The hose clamp won't work because the problem is the clip you have your hose clamp up against is broken. Instead of being able to replace that plastic clip, they have to replace the seat frame. You can usually tell if the clip is broken by lifting up on the seat, one side will go up quite a bit further than the other.
For what it's worth, I did the hose clamp fix on mine and about once a month the issue would return. Took it into a dealer once and problem solved for good. Had it on there for a while now and no issues. I understand people doing the DIY route as I did myself, but if there's a fix for a known issue, why not get it done? If for whatever reason it doesn't work then you should probably find another dealer.
The dealer did the hose clamp fix. It only works temporarily. The seat will eventually start moving again on you, they are poorly/cheaply made. The dealers generally suck about it. It looks like the seat issues will ALWAYS come back unless they replace the frame. How many people have this problem and the dealers have said it's normal? It's incredibly aggravating to drive with the seat moving around and the dealer saying it's normal -- the back and forth with the dealer.
I had the hose clamp in place, lasted about a month or two before it started slipping. Tried to tighten, but would still slip. Went to the dealer for a recall (15304) fix and asked them to change oil and take a look at the seat. They acknowledged the seat issue and the svc mgr said they have a fix, but it doesn't always work. At least he was being honest. They performed PI1183A http://oemdtc.com/12126/front-seat-lateral-movement-andor-click-type-noise-while-driving-2014-chevrolet-silverado-gmc-sierra
Seems solid so far, only time will tell if I need to go back to the hose clamps. Svc mgr said he could order new tracks but he is supposed to perform PI1183A first, and to let him know if it starts slipping again. Appears to be a newer than PI1376. Didn't see any shims mentioned and I do see that black-ish plastic retainer that's in the last picture of the instructions linked above.
Is anyone having trouble with the later '15's or is this just a '14 issue?
My '15 started doing it after around 2000 miles, brought it back to dealer and they fixed it changing the retainer clips, and some lubrication as per the bulletin. After all the reading I did about it, I was worried about the fix working but it seems to be just fine, no movement or noises....been a few thousand miles now
For those of you who have (in the opinion of others) "wasted" there time on a dealer fix for this problem, only to have it come back again. Here is a permanent fix. What is happening is the dealer installed retainer clip is popping out of the white seat hinge which is allowing the seat to move again. By installing a hose clamp around the retainer clip it will not allow it to pop out and it will still allow full range of motion on the seat.
A 2" hose clamp and 5 minutes should take care of the problem FOREVER!! (I hope)
*EDIT* After looking closer at post #762 above, it appears the dealer was supposed to install a zip tie around the retainer clip to keep it in place. In my case...they didn't...hence the need for the hose clamp.
Edited by tvette1993
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
