Towing a Toy Hauler with 5.3L
Are you sure I haven't drove or towed with these trucks? Last time I checked there was a 6.0 and a 6.2 sitting in my barn. I have drove both the 6 and 8 speed 5.3 but do not own one although I am guessing I will order one for my next truck.
I do agree the 6.2 rips, the 6.0 is a slug in the HD but it is a big heavy truck, I figured the 6.2 would feel the same. I would love to see them pull the same load up the same hill in a test, guessing there wouldn't be much time difference.
I would love to see a gen 5 7.0 motor in the '17 HD!!! Still lots of love for the rock solid 6.0 though.
Pretty sure. Engines sitting in a barn don't account for much.... And I am sure no matter what the vehicle is being discussed you conveniently have one in your barn....lol. If you actually have done anything with either of them you have one sorry sack of a 6.2 to think otherwise honestly. Weight of the truck has nothing to do with engine output characteristics.... especially when you factor a 7000+ load into the equation. You can't make torque happen at a given rpm that it doesn't exist at.
Sent from my SM-G900W8 using Tapatalk
  • Replies 177
Odd, a 10 year old 3/4ton GM truck has 12.5in. disk brakes, have you bothered to see what the brake size is on the new 1/2ton...
I think we already know that you don't know the brake size of your truck or else you would not have posted that.
10 year old 2500's had 12.8" disks, front and rear. 2014+ 1500's have 13" front and 13.6" rear. Just in case you wanted to know what you were talking about.....
Based upon what? Wishful thinking? Looking at the dynos upside down? It's true they're rarely compared side by side in tests since they're in different classes, but they've both been tested a lot and you need to have your head buried pretty deeply in the sand to really think this. The difference in power is huge.
As one example, here the 6.0 ran the 1/4 in 17.0 empty:
http://blogs.cars.com/.a/6a00d83451b3c669e201a3fd41ac2d970b-pi
Here the 6.2 ran the 1/4 in 15.3 seconds with a 1750 lb payload!
http://blogs.cars.com/.a/6a00d83451b3c669e201b7c804a4b6970b-pi
And of course, people who have towed the same trailer up the same hills with both like the guy above have already told you how different they are.
My wife's 6.2 would destroy my 6.0 in just about any scenario.
What I would give to have the 6.2l option in a 2500HD....
I have the CAT scale tickets to prove it, towed at 16, 680 GCW from Los Angeles to Charlotte, NC this past summer. Steep grades up and down, never overheated, never locked up the brakes going down and never had a "shit I wish I had a bigger truck right now" moment. Trailer scaled @ 9600lbs.
Proper prep of the truck and trailer are critical when towing at "the line". The driver's skills, abilities and comfort level factor into what you're willing to do with your truck.
I have a propride WDH, it is a top-of-the-line WDH system. This may have also contributed to my trouble free experience for over 10k miles of towing so far. Good luck. BTW, I have a 3.73 5.3L.
Man, this is getting deep, and hysterical too!
Please, don't ever hook a stock Duramax to your trailer.
Heck, don't try it with a 6.2l either.
Suddenly "driver skill and abilities" become a even more of a joke, and truck and trailer prep is done by stopping at a Starbucks for coffee and a scone.
You simply set the cruise on 65 mph and enjoy the scenery.
Clearly butthurt because his 2500 can't fit into starbucks drive-thru. Lol
If they are within the towing and payload why do they need a 2500?? So 1500s are cruisers and if you want to tow a lawnmower you need a 2500?? Get real.
Sent from my Note 4 on Tapashit
IMO
1500 would probably do it but if towing a toy hauler regularly or for long distance I would want a 2500.
There is no doubt that a 5.3 can tow 9600 and your $2,000 WDH plays a HUGE part in that.
I researched ProPride and Hensley hitches extensively but ultimately decided in my case that I would be better off applying that $2,000 towards a 3/4 ton truck.
Can you give more information or a link to what you have? I'm going to be towing my tractor, a few times a year, which will weigh around 10,000lbs with tractor, implements and trailer and I want the best hauling gear that I can have. Safety and peace of mind mean a lot to me.
This is the Pro Pride http://www.propridehitch.com/
Hensley is similar. Both designed by the same guy.
Very expensive. I have a Equal-i-zer 4 point that works very well and is 1/3 the price.
I tow a 34' TT loaded weighs 8,200.
Ignore the dry weights of a trailer and plan on towing weight being the dry weight + carrying capacity. Keep the total trailer weight 80-85% of the truck towing rating.
Then you have to figure out what your tongue weight is. Figure about 15% of the trailer weight. This is where most 1/2 tons lack capacity.
I really doubt your truck will pull what you are thinking of.
I have a crewcab short bed with the 6.2 and Max Trailering being built right now. I think (really hope) it will pull 10000lbs since it's rated at 11800lbs.
How does someone determine what 15% of the trailer weight is? I don't have scales that are capable of that. I can move the tractor back and forth to get the weight distributed but how do I know when I've reached the right balance?
I tow trailers every day weighing between 4,500, and 10,000 lbs, and have for 12 years. My father has since 1975. In our family business we have both new 2500hd duramax trucks, and 1500 5.3l trucks. My biggest two concerns towing are not if the engine can pull but can the truck properly stop what I'm towing in just about every single situation, and in a Reese hitch trailer making sure the weight is distributed for a proper tongue weight. So make sure that the toy hauler at least has electric brakes on both axles.
But since power is what everyone is talking about I believe the more the better. This won't be popular probably but 5,000-7000lbs a 5.3l with 3.73 would be fine. 5,000-10,000lbs the 6.2l with an 8 speed works well. If you can swing a diesel than 10,000lbs, and over a duramax, or nothing for me.
Also being a tow hauler the wind resistance becomes a bigger issue for a smaller engine like a 5.3l in a half ton truck. Our 3/4 trucks really shine when it gets windy because they are designed to pull those loads better like that.
If it were me I'd get a 2500hd with the duramax, and enjoy the drives better with your family. I wouldn't even consider the 6.0l. I pulled our trailers test driving one and it stayed at 4,000 rpms the whole time.
What if I will only be pulling around 10K lbs 3 to 5 times a year and a boat that weighs around 5,500 lbs a few times a year? In your opinion, would that warrant stepping up to a 2500 diesel? I know people on here like their 6.0 2500 trucks and that is fine but if I'm going to get a 2500 I would only consider the diesel motor.
Last I checked, my truck is the same dimensions as a DC 1500.
My wife can get our dually and our 26' trailer through a Starbucks drive thru. I think you might be able to drive a 2500 DC too.
And yes, your last statement is correct, except for the " get real" part.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
