On 7/2/2018 at 10:50 AM, JBergen said:
I would really like to know where people are finding the Center Console unit itself! I want to swap out my 2016 Chevrolet Silverado Jump Seat for the Center Console but haven't been able to find one anywhere.
Thanks!
I called a salvage yard, and they checked around and found me one.
I’ve got a batch of Center Console harnesses that I’ve started today, will be working on tomorrow. I’ve got a handful of booked orders I’m shipping on Monday.
If anyone is looking to do this over the next two weeks, note that I’ll be on vacation on Thursday 7/12 - 7/21.
So - I’ll have a small handful of these harnesses ready for immediate shipment before I go.
Let me know! Thanks everyone!
i will need one!!
i will need one!!
Send me a PM and we’ll go through the validation and ordering process to get you one.
Hey Phil IAM interested in a pnp harness. I sent you an email it's on a 14 Sierra , not sure you you got it or not. I noticed it was like I emailed my self..not sure   if it's easier to  pm you on here or stick with email either way let me know.thanks!
Guys/Gals,
I have 1 more 16-Pin Center Console left for immediate shipping tomorrow.
After this is one sold, I’ll resume building more when I return from vacation on 7/21.
Thanks everyone!
***VACATION MODE***
I will on vacation on from 7/12 - 7/21.  All booked 16-Pin Center Console Harness orders have been shipped.  I used your PayPal email address of the outbound notification, so be on the lookout for an email from USPS.
Thank you all for the continued support!
I will have access to the inter webs so I will periodically monitor things.  LOL.  I will also be accepting orders while on vacation but won't be able to begin building until I return.  All booked orders will be processed in the order they came in.  If you booked/Paid for a 23-pin Center Console Harness, please ship it to my mailing address as indicated in the instructions.  This is a staffed mail box location.  I will work on those in the order the came in upon my return.
Thanks everyone!
-Phil
On 6/11/2018 at 4:18 PM, Rfg14silverado said:
Has anyone on here done the console mod to their trucks that have no hmi?
Edited by Mitchell95
Does anyone know if this center console comes with a lock compartment like the jumpseat console? Been thinking about buying one, but I like that feature of the jump seat console for storing valuable items
No lock compartment. You can buy a lockbox that mounts inside of the console but by itself it doesn't include anything like that.
Hey Paul
How do I get in touch with you to order one of the center console harnesses from you.
Sounds like you have a lot more stuff to offer that I'm looking in to doing on my truck. So will probably order more from you if it is easy to order.
Love the plug and play stuff as a former auto tech for the 3 major us auto makers what you are doing is awesome love it
Hi Phil,
how do I go  about ordering one of these harness for the console swap
Ian
Hey Paul
Thanks! I am on vacation, returning Monday 7/23. So my responses may be delayed. I also have a ton of orders I took in during vacation, so I’ll be quite busy working on those for the next 4-5 days upon my return.
PM and we can go over things as I am able to.
Thanks!
Phil
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
