Now that owners are taking delivery of the new 2019 Chevy Silverado and GMC Sierra, I thought a quick reference guide to common routine maintenance items would be beneficial to us all. If you have information that you'd like suggest be added to this topic, just post below and I'll update this first post with any and all new/updated information.
2019 Chevy Silverado & 2019 GMC Sierra Routine Maintenance Quick Reference Guide
Digital Owners Manuals
2019 Chevrolet Silverado: 2019_Chevy_Silverado_Owners_Manual.pdf
2019 GMC Sierra: 2019_GMC_Sierra_Owners_Manual.pdf
Oil Changes
2.7L(L3B)
  • Capacity: 6.0 Quarts
  • AC Delco Oil Filter: PF66 / 55495105
  • Drain Plug Size: TBD
5.3L(L84) & 6.2L(L87)
  • Capacity: 8.0 Quarts
  • AC Delco Oil Filter: PF63E / 19330000
  • Drain Plug Size: 15MM or XX Torx
Engine Air Filters
  • With High Capacity Air Cleaner: A3244C / 84121219
  • Without High Capacity Air Cleaner: A3246C / 84121217
Interior Filters
  • Passenger Compartment Air Filter: CF185
Wiper Blades
  • Drivers & Passenger Sides: 55cm / 21.7 Inches - GM Part Number 23417074
Spark Plugs
  • 2.7L L4: 12688094 / 41-106-IP
  • 4.3L V6: 12622441 / 41-114
  • 5.3L V8 & 6.2L V8: 12622441 / 41-114
Fuel Tank Sizes
  • Standard / Short Box (Gas & 4WD Duramax): 24 Gallons
  • Standard & Short Box (2WD Duramax): 22 Gallons
Automatic Transmission Fluid
  • 6-Speed: DEXRON-VI Automatic Transmission Fluid
  • 8-Speed: DEXRON-HP Automatic Transmission Fluid
  • 10-Speed: DEXRON ULV Automatic Transmission Fluid (GM Part Number 19352619/Canada 19352620)
Transfer Case Fluid
  • All Models: 1.6 Quarts
  • DEXRON-VI Automatic Transmission Fluid
Wheel Lug Nut Torque
  • All Models: 140 lb-ft / 190 N-m
  • Like 8
  • Thanks 7
If its okay to add:
3.0 Duramax(LM2):
Oil Filter - PF66 / 55495105
Engine Oil - DexosD 0w20 19370138
Fuel Filter - TP1015 / 23304096
Air Filter - A3244C / 84121219
Front Axle Lubricant:
Supplier RPO code SU4 - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
Supplier RPO code SU5 - 10-4122 / 19368514 Dexron Low Viscosity 75W-85 (GM)
Rear Axle Lubricant:
8.6" axle 3.42 gear - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
9.5", Ratio RPO GU5 3.23 gear, Supplier RPO code SU7 - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
9.5", Ratio RPO GU5 3.23 gear, Supplier RPO code SU8 - 10-4122 / 19368514 Dexron Low Viscosity 75W-85 (GM)
9.5", Ratio RPO GU6 3.42 gear - 10-4091 / 19300457 High Efficiency 75W-85 (AAM) - With 6 speed auto ONLY.  WT/Custom/CustomTB.
9.76" rear axle 3.42 gear - 10-4091 / 19300457 High Efficiency 75W-85 (AAM)
*Note.  Must ID the RPO codes to match proper fluids due to there being two different axle suppliers, GM and AAM.
Fuel Tank Sizes:
Long Box Gas - 28 Gallons
Brake Fluid:
DOT4 - 10-4086 / 19299570
Front Bulbs (Custom/WT/Custom TB):
Low Beam - H11
High Beam - 9005
Turn Signal/Marker - W21/5WLL
Fog Lamp - LED
Front Bulbs (LT/LTZ/LT TB/RST):
Low/High Beam - LED
Fog Lamp - LED
Front Bulbs (Sierra/SLE/Elevation):
Low/High Beam - LED
Turn Signal/Marker - 7444NA
Fog Lamp - LED
Front Bulbs (High Country):
Low/High Beam - LED
Turn Signal/Marker - LED
Fog Lamp - LED
Front Bulbs (AT4/SLT/Denali):
Low/High Beam - LED
Fog Lamp - LED
Rear Bulbs (WT/LT):
Stop/Turn Signal - 7443
Reverse - W16W
Marker - 194
License Plate - 194
Rear Bulbs (Sierra/SLE/Elevation):
Reverse - W16W
License Plate - 194
Rear Bulbs (High Country/LTZ/RST/Custom/Custom TB/LT TB)
Stop/Turn/Marker - LED
Reverse - W16W
License Plate - 194
Rear Bulbs (AT4/SLT/Denali)
Reverse - LED
License Plate - 194
*Note on lighting:  "Sierra" is the "base" trim (equivalent to WT).
Edited by newdude
edited axle info added gear ratios and note on one axle.
  • Like 5
  • Thanks 3
  • 3 months later...
Adding some more to this if I may...
Wheel measurements (Chevrolet):  These will be listed by RPO code, brief description and trim, diameter/width and offset.
ORDER GUIDE FOR VISUAL REFRENCE OF WHEELS:  https://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2019&regionID=1&divisionID=1&type=0&vehicleID=21483&section=wheels&pagenum=1&butID=4
RD6:  Ultra Silver painted steel, 17x8, 24mm offset.  Standard on WT.
Q5U:  6 spoke Bright Silver painted aluminum, 17x8, 24mm offset.  Optional on WT, standard LT wheel.
PZX:  5 spoke split spoke (10 spoke total) Bright Silver painted aluminum, 18x8.5, 26mm offset.  Optional on LT, standard on RST and LTZ.
RD1:  5 spoke split spoke (10 spoke total) High gloss Black painted aluminum, 18x8.5, 24mm offset.  Standard on Custom Trail Boss and LT Trail Boss.
NZP:  5 spoke split spoke (10 spoke total) Bright Silver painted aluminum, 20x9, 27mm offset.  Standard on Custom.
RD4:  5 spoke split spoke (10 spoke total) Painted aluminum with machine face and Argent Metallic pockets, 20x9, 27mm offset.  Optional on LT and RST.  Same design wheel as NZP.
NZT:  5 spoke split spoke (10 spoke total) Painted aluminum with machined face and Gray accent pockets, 20x9, 27mm offset.  Optional on Custom Trail Boss and LT Trail Boss.
NZJ:  5 spoke split spoke (10 spoke total) Painted aluminum with machined face and Light Argent pockets, 20x9, 28mm offset.  Standard on High Country.
RD2:  5 spoke split spoke (10 spoke total) Polished finish, 20x9, 28mm offset.  Optional on LTZ.  Same design as NZJ.
RVA:  10 spoke Polished aluminum, 22x9, 28mm offset.  Optional on High Country.
Wheel measurements (GMC):  These will be listed by RPO code, brief description and trim, diameter/width and offset.
ORDER GUIDE FOR VISUAL REFRENCE OF WHEELS:  https://www.gmfleetorderguide.com/NASApp/domestic/proddesc.jsp?year=2019&regionID=1&divisionID=2&type=0&vehicleID=21485&section=wheels&pagenum=1&butID=4
RD6:  Ultra Silver painted steel, 17x8, 24mm offset.  Standard on Sierra(Base).
Q5U:  6 spoke Bright Silver painted aluminum, 17x8, 24mm offset.  Optional on Sierra(Base), standard SLE wheel.
UHN:  6 spoke Machined aluminum with Dark Grey Metallic accents, 18x8.5, 24mm offset.  Optional on SLE, standard on SLT.
RT5:  6 spoke split spoke (12 spoke total) Machined aluminum with Dark Grey accents, 18x8.5, 24mm offset.  Standard on AT4.
NZM:  6 spoke split spoke (12 spoke total) Polished aluminum, 20x9, 28mm offset.  Available on SLE and SLT.
RD3:  6 spoke split spoke (12 spoke total) Black gloss painted aluminum, 20x9, 28mm offset.  Standard on Elevation.
NZH:  6 spoke split spoke (12 spoke total) Machined aluminum with Carbon Grey Metallic accents, 20x9, 28mm offset.  Optional on AT4.  Same design wheel as NZM.
RTL:  6 spoke split spoke (12 spoke total) Multi-dimensional polished aluminum, 20x9, 28mm offset.  Standard on Denali.
Q7L:  18 spoke Polished aluminum, 22x9, 22mm offset.  Optional on Denali.
Side note.  RD6 and Q5U are shared between Chevrolet and GMC.  Same wheels, just different center caps.
Edited by newdude
  • Thanks 1
  • 1 month later...
Update:
3.0 Duramax LM2:
Oil Capacity - 7 Quarts
DEF Capacity - 5.3 Gallons
Adding Factory Tires related to RPO codes (GM calls OE spec'd tires "TPC Spec"). Will be as follows:
RPO Code - Tire size, Load index/speed rating, brand, style, sidewall.  Tires will be noted by brand but are shared.
CHEVROLET:
QBN - P255/70R17, 112S, General Grabber HTS, black sidewall.  Standard equipment on WT and LT.
QDV - P265/70R17, 115S, Bridgestone Dueler AT RHS, black sidewall.  Optional on WT and LT.
RC5 - LT265/70R17 C, 112Q, Bridgestone Dueler AT RHS, black sidewall.  Optional on WT, and LT.
QDF - P265/65R18, 114T, Michelin Energy Saver AS, black sidewall.  Standard tire for optional 18" wheels on LT, standard on RST and LTZ.
XCK - P265/65R18, 114T,Goodyear Fortitude HT, black sidewall.  Optional tire for optional 18" wheels on LT, optional on RST and LTZ.
QDS - P265/65R18, 114T,Goodyear Fortitude HT, white outline letters.  Optional tire for optional 18" wheels on LT, optional on RST and LTZ.
R3O - LT275/65R18, 110/113Q, Goodyear Wrangler Duratrac, black sidewall.  Standard on Custom Trail Boss and LT Trail Boss.
QAB - P275/60R20, 115S, Bridgestone Dueler Alenza AS, black sidewall.  Standard on Custom and High Country (2wd only), standard tire on optional 20" wheels for LT, RST and LTZ.
QAE - P275/60R20, 115S, Goodyear Wrangler Trailrunner AT, black sidewall.  Standard tire for optional 20" wheels on Custom Trail Boss and LT Trail Boss.
QAE - P275/60R20, 114T, Bridgestone Dueler AT RHS, black sidewall.  Standard tire for optional 20" wheels on 4x4 Non-Trail Boss trucks.  LT, LTZ and High Country.
XCE - P275/50R22, 111T, Bridgestone Dueler Alenza AS, black sidewall.  Tire used on High Country optional 22" wheels, and on all LPO 22" accessory wheels.
GMC:
QBN - P255/70R17, 112S, General Grabber HTS, black sidewall.  Standard equipment on Base Sierra and SLE.
QDV - P265/70R17, 115S, Bridgestone Dueler AT RHS, black sidewall.  Optional on Base Sierra and SLE.
RC5 - LT265/70R17 C, 112Q, Bridgestone Dueler AT RHS, black sidewall.  Optional on Base Sierra and SLE.
QDF - P265/65R18, 114T, Michelin Energy Saver AS, black sidewall.  Standard tire for optional 18" wheels on SLE, standard on SLT.
XCK - P265/65R18, 114T,Goodyear Fortitude HT, black sidewall.  Optional tire for optional 18" wheels on SLE, optional on SLT, standard on AT4.
QDS - P265/65R18, 114T,Goodyear Fortitude HT, white outline letters.  Optional tire for optional 18" wheels on SLE.
R3O - LT275/65R18, 110/113Q, Goodyear Wrangler Duratrac, black sidewall.  Optional tire for 18" wheel on AT4.
QAB - P275/60R20, 115S, Bridgestone Dueler Alenza AS, black sidewall.  Standard on 2wd SLE with optional 20" wheels, standard on 2wd Denali, standard on Elevation, available on SLT.
QAE - P275/60R20, 115S, Goodyear Wrangler Trailrunner AT, black sidewall.  Available on AT4 with 20" wheels.
QAE - P275/60R20, 114T, Bridgestone Dueler AT RHS, black sidewall.  Standard on Denali 4x4.  Available on SLE and SLT with 20" wheels, available on Elevation.
XCE - P275/50R22, 111T, Bridgestone Dueler Alenza AS, black sidewall.  Tire used on Denali optional 22" wheels, and on all LPO 22" accessory wheels.
Please take note on the two different tires used for RPO code QAE.  I have not been able to 100% identify which of each tire is used on which trims.  Those two are only going off the best of my knowledge/what I've seen on lots.
Edited by newdude
  • Thanks 1
3 hours ago, relevante said:
Mine was QDF on the order sheet and came with Michelin Primacy LTX, not the Energy Saver. Haven’t scanned the QR code yet.
Entirely possible.  GM just added an XFE package to the 2019 truck, and they may have added the Energy Saver in addition to the Primacy, or replaced the Primacy with the Energy Saver all together.  This could be just like the QAE 20" tire where there is two options for one RPO code, and it depends on the build of the truck.
Edited by newdude
  • 2 months later...
I am having trouble finding exactly what oil to purchase for my new 6.2 Denali first oil change.
I do see 8 quarts of oil, but unsure of weight required.
Anything unusual about oil change on these trucks?
Edited by RPaul
Any Dexos-1 Gen2 approved 0w20 will be plenty good and is the GM recommendation. Don’t need to turn this into another oil thread...I use Mobil 1, but anything meeting that Dexos Gen2 standard is fine.
Edited by OnTheReel
  • Like 3
  • 3 months later...
  • 1 month later...
Some good info here. At what mileage should the first service (oil/filters etc.) be at? My mileage minder got messed up, and the reminder sticker the dealer put on my windshield says 5000 miles, yet the manual has something about 7500 for first service. What is the correct mileage that will keep the warranty intact?
Scott
Bought a California 2020 AT4 1500; made in Mexico.
Headed to Canada for Christmas 2020.  What antifreeze comes in the block from the factory; what is it rated to?
What is the part number if one might have it?
  • 1 month later...
On 1/7/2019 at 3:54 AM, CadillacLuke24 said:
Those fuel tank sizes (I know, beating the dead horse) are ridiculous. Give us some range, damnit!
Just filled up my truck today (2020 Silverado LT 3.0L diesel) dash said 524 miles till empty.
  • 3 weeks later...
wiper part number is incorrect, i made the mistake and took the advise and order from part numbers above, they are not correct, the correct number out of my owners manual are 23387857 for 2019 high country
23417074 dont even come close to fitting look to be for 14/18 silverado and 19 ld
Edited by Kevin0311
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
