your posts prove otherwise
Thank you. Never touched that crap in my life.
So what is your advice for those who are serious about buying a new GM truck? Cross their fingers and hope that for $ 45k they will get a good truck that does not vibrate?
::shrugs:: life is about choices and risks.. There are no guarantees in life, there is just life. personally though, I no longer buy new.
Well another week without my truck :nonod:
It's not the Dealers problem it's a GM PROBLEM in three day's the GM engineer had spent
with my truck, I or the Service Director really have no clue as to what Mr. engineer
did or anything as far as an idea as to what's causing the vibration issue :mad:
[Violent rhetoric removed to ensure reader safety]
I just got my truck back on Monday, VIBRATION FREE!!! Ive put just over 150 more miles on it (760 on it now) and no problems. I will say my dealer had recognized a problem with the vehicle and kept me informed with how they were going to fix it. They had to put some mileage (60 miles approx.) on it to run the Vibration Analyzer on it, which didnt make me too happy. Im just glad they repaired it and did it whithin a reasonable time. I wasnt happy that this happened right out of the gate from purchasing the truck BUT Im glad they were able to FIND AND FIX the problem.
They ended up putting a new ring, pinion, bearings and yoke in the rear diff. The truck drives smooth as glass now and I couldnt be more happier. This is how a warranty repair should be done. Out of all the posts Ive seen on here Im surprised at how many people havent had the same luck as me. Im glad it didnt go the way so many here have had it. Thanks, H!
It has been 6 weeks in the shop and the dealer has run the list of parts. I filed another BBB claim 3 days ago and today I began negotiating a trade. If you get any BS from the dealer go on-line to the BBB. GM has responded within 2 days and both dealers involved have JUMPED on the issue.
My local dealer is now saying they won't trade outside their own network, another call from GM should fix that.
Their network? Tell them you want to trade for a Ford. Can you get a buy back so you can buy what you want where you want?
If the vibration does not return in the next 10k miles i will believe that they fixed it.
Edited by pm26
Hi Guys, I bought a 2014 Silverado double cab z71 back in June. I First noticed the vibration about 3 months ago but it was very slight. This was only around 45 mph. Now the vibration starts at 45mph and goes to about 65. I have my first appointment with the dealer next week to look at the issue. Does anyone think it could be the passenger rated good years that cause the problem? I have read on a few other forums that LT tires reduced if not fixed the vibration. Im tiring to gather up as much info as I can before I head to the dealer. Thanks for the help
yet you are here on this site making light of the problems these trucks have, so by your own admission you don't know what you are talking about.
simply amazing, lmao
Son, I've been comming to this site off and on since a few months after this place was created, I've been a member of this site thru 4 GM trucks i've purchased and owned, each with their own set of problems, GMT-800s, and GMT-900s, yet there is always someone like you who pops up every once in awhile and cries and cries and cries about how bad their issue is and all that crap about paying $40,000+ for a vehicle and blah blah blah. Was I happy when I had issues with my trucks? No. Was I mad at GM? Sure. But when everything was said and done, it was my choice to purchase the vehicle and accept the concequences of doing so. Having annoying little things that pop up that may not be easily repaired, or even repaired period is one of those concequences. The only thing I am making light of are the cry babies like you who keep on crying and crying and crying and crying foul this and foul that and woe is me and all that other stupid childish crap. Give it a rest already.
:nopity:
:nopity:
And, yet I've been a member since:
Colossus
Member Since 05 May 2014
mm hmm. If i told you some of my previous names the Mods would certainly recognize me and could vouch for that. But seriously! nice try!
:tear:
:tear:
Well congratulations on using multiple names.
  • Hold the drive pinion stationary and move the ring gear back and forth.
  • Repeat the measuring procedure at each tooth around the ring gear.
  • The difference between the backlash at all of the measuring points should not vary by more than 0.05 mm (0.002 in).
  • If the difference between the backlash at all of the measuring points varies by more than 0.05 mm (0.002 in), inspect for burrs, a distorted case flange or uneven bolting.
  • If the difference between all the measuring points is within specifications, the backlash at the minimum lash point measured should be 0.08-0.25 mm (0.003-0.010 in) with a preferred backlash of 0.13-0.18 mm (0.005-0.007 in).
Checked it last night, measured between .005-.007". Had 1 tooth that was right at .008", the rest were right at .007" or alittle less.
Thanks for the advice.
So, you dont even have a dog in this hunt then. No 2014 silverado with or without problems?
Just couldnt resist coming into this thread and sharing your dissenting, uninformed, opinion?
To what end? Argument? Conflict? Are you a troll?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
