Jesse D:
Rough Idle in Drive
September 15, 2015
Some 2015 Silverado 1500, Suburban, Tahoe, Sierra 1500, Yukon models, Escalade models; 2014 Silverado 1500 and Sierra 1500 models equipped with 4.3L, 5.3L, or 6.2L engines (RPOs L83, L86, LV1, LV3) may have a rough idle and/or vibration at idle in Drive. This condition may be most noticeable following extended driving, while idling at a stop in Drive. It will not be present in Park, Reverse, or Neutral.
There will not be any DTCs with this condition. Use the CH-51450-A (Pico Oscilloscope) for diagnosis. With the tool’s accelerometer positioned on forward end of the seat track, the condition will show in the lateral/cross-car direction as E1.5 (1.5 engine order) in the range of 2–7 mg.
This rough idle condition may be improved by performing a motor mount adjustment procedure. The mount adjustment procedure addresses the normal idle characteristics of the Gen-5 V6 and V8 engines transmitted through ground-out in the motor mounts due to frame bracket positioning tolerances.
TIP: Perform the following procedure on both left and right engine mounts at the same time so there is no binding/twisting in the mounts.
Begin by removing the front wheels and wheelhouse liners. Loosen the engine mount bolts at three frame attachment points for both the left and right mounts. (Fig. 13) Also loosen the transmission mount to keep from putting it into a bind. Lift the engine so both mounts are off the frame approximately 10-20mm.
Install 3mm-thick spacers between the bottom surface of the mount and frame bracket, on the inboard side of mount. Do not use tapered shims. Use a small amount of adhesive to hold the spacers in place on the frame.
Installing spacers between the mount and frame bracket at the lower inboard location, (Fig. 14, #1) alleviates the ground-out in the mount at the upper outboard area. (Fig. 14, #2)
Lower the engine so the spacers are trapped between the mount and the frame and tighten the bolts. Tighten the center/upper bolt first; then the front and rear bolt. Torque the mounts to 50 Nm (37 lb.-ft.).
For additional information, refer to #PIP5211.
Do you have a PI or TSB number for this or where did you find this? Thanks
Sorry I just seen that its at the bottom, but where did you find it still?
Edited by Silverado 6.2
What is strange is that I have never heard of crappy tires causing come and go vibration problems. That tells me the trucks just don't have enough absorption in the body mounts with this new design. My truck still has some vibes that come and go based on tire temperature, never had that in a truck before.
Definitely the hardest part of trying to pin down the source. The vibration come and goes in it's severity but never goes away. I think tire temperature might play a part but sometimes its just as bad when it's hot as when it's cold. I think it might be a phasing issue. Sometimes the tires are in sync and the vibrations are at their worst after a while of driving and making enough turns they get to a point where the vibrations cancel each other and you just don't know where they are in relation to each other until you hit the freeway and see what kind of vibration you get. This would be an extremely difficult thing to test unless you have your own perfectly straight 5 mile stretch of super smooth asphalt to run up and down so you could clock the tires relative to one another and drive strait ahead.
I am to damn tight to buy a new set of tires right now but I will probably break down and get a set of AT LT tires within a year or so. When I do I will buy from a place the next town over that has a good road force balancer and they know how to use it from others I have talked to. Maybe the heavier tires will do a little bit better than the stock Goodyears.
Jesse, mine does the exact same thing. Sometimes it will idle somewhat smooth and then have a jolt and stumble etc. Drive me nuts being able to feel it at a stop light and if you open the hood like you did and put your hand on it, you can feel it even more ande actually see it happen like you're hitting the gas and the torque is twisting the motor.
One thing I did notice is that with the correct oil level mine seemed to idle much smoother. The last 2 times I have gotten oil changes (free) at the dealer they have overfilled it. Once I drained some out back to full, it seemed to do quite a bit better. Not gone but better.
Also wondering if the motor mounts are completely tight. I have found multiple bolts on my truck that are way looser than they should be. Ex: real axle u-bolts, should be at 78 ft-lbs from the factory and mine were no more than 40.
Just thought I'd throw out an update on this. I just dropped my truck off, and brought this and a few other things up to my service writer:
-- the torque on the u bolts is actually now a recall, they have found on many vehicles that they are not tight enough. (released in the last few days)
-- there is a recall for some of the 4x4's, which at cooler temperatures, 4x4 kicks in automatically regardless of whether or not you keep it in 2wd (again released in the last few days) I put my truck in 4x4 leaving a job site today, and there was a squealing/ grinding type of noise. this is an indication you have this problem
-- there are a few other recalls, but he didn't get into them because my truck didn't qualify
I showed them some of my video's for the vibration and rough idle, so they now know how bad it is, and can't say that it wasn't replicated. We shall see what comes of this attempt, I highly doubt any of the issues I actually brought it in for will be fixed, but who knows.
ohh and they gave me a little Piece of Shit Impala LS as my loaner, I complained, but they said thats all they had.
What recall? AFAIK, there are no active recalls??
Do you mean TSB's or some other internal document?
Did they actually measure runout of the prop shaft, u-joints and check ring and pinion backlash?
The rear axle U bolts not being fully torqued is now a recall on some trucks, I believe the ones assembles in Mexico as mine was.
In addition there is a recall for the front wheel drive portion of the 4x4 trucks, in cold weather the 4WD kicks in automatically, on top of that, there is an issue with some where in 4x4 there is a squealing/ grinding sound, not sure what causes it, but its a part of that recall.
This info is coming from my dealer who already did the work on my truck.
I agree, I feel like the warmer the tires get, the worse the vibration
---UPDATE---
So I went to my dealer today to pick up my truck, instead we took out one of their loaner trucks and took that for a drive. it seemed substantially better than my truck, so they decided to have me keep it through tomorrow to see if I still think that after doing a fair amount of driving. I'll be picking up my truck after work and about 60 miles worth of driving, assuming I don't have to make a run to the supply house which is another 90 miles haha... I really do think that this loaner truck is a lot better than my truck, but there is still a little bit of a vibe, which is still unacceptable under any circumstances.
I guess I will see how my truck actually is tomorrow
Do ALL the 2015 Sierra 1500s have this problem?
If not, what percentage has it?
Must not be all...
http://www.gm-trucks.com/forums/topic/175832-how-many-trucks-dont-vibrate/
Percentage? Doubt anyone, at least here, will know. You will hear about how long this thread is but the folks with the problem have posted pretty prolifically here. Plus, it is only a small sample of all of the 1500s sold.
Edited by blifsey
This is a number that I don't think you can get with any accuracy. Some people may have it and not notice it, some it is very mild, some trucks might never see the speeds where the vibration occurs so they might have it but you'd never know. For me and others it starts right at 70 mph and up on smooth asphalt. Where I'm at the speed limit on the freeway is 70 mph and has just been repaved recently so I get to experience it everyday on the way to work and everyday on my way home. Do yourself a favor and get a RAM, If I could go back in time and do it over again I would get the RAM. My vibration problem didn't show up until about 2000 miles. So don't think just because the test drive went well that you're in the clear.
Based on my findings around 80% have some sort of noticeable vibration problem...most commonly the highway shake vibration.
I am not kidding when I say I test drove 12-13 Sierra and Silverado trucks, 2014-2015 (mostly 2015) and 10 of them vibrated.
Double cabs were by far the worst. Crew were also bad but better than double cabs...and the crew cabs had wide ranges of vibe intensities (the one I settled on I did not notice any vibes when I test drove the vehicle, but it eventually developed a vibe).
Hey guys been following this thread for a while. I've got a 2014 Silverado dbl cab lt z71 with the 70+ shakes. I recently picked up some wheels and tires on the internet went from the 18's to 20's well that was a mistake cause the shakes got worse. So I take it to the dealer for wheel alignment and road force the tires on my dime. Service writer asks me if I was having any problems and I. Explained the tire purchase and that I had vibrations and a slight pull to the left at highway speeds. So the tech does the job and then tells the service writer that the shakes are caused by my after market exhaust! Really......ugh! So long story longer. I was checking things in the front end and saw the
upper control arm bushings are all cracked. This can't be normal with only 13000 miles. I know if I take it back they'll say it was caused by my level kit. Any thoughts?
Well, I test drove 1. It drove/rode just fine so I bought it. Had never heard of this issue before purchase. So, based on my findings, 100% do NOT vibrate...
Same logic Mikegmi2 used..."based on my findings"
Surely you don't agree with his 80% do have vibration issues???
Edited by blifsey
I think he was just providing his honest experience based on a good number of test drives.
Edited by olddutchfarm
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
