Either the tire/wheel assemblies have excessive radial force variation, the rear driveshaft (propshaft) is out of balance or the right side engine mount needs to be shimmed 3 mm. Those are the only vibration issues that I have seen with a K2XX truck.
I don't understand what "shimming" a motor mount would accomplish? I can buy the driveshaft and radial force variance but the motor mount throws me.
Can you explain how that would make any difference?
Some trucks had a clearance issue on the motor mounts that required a shim to prevent the mount from grounding to the frame. Basically the two metal pieces on either side of the rubber isolator do not have large enough gap between them and they come into contact with one another. They put in a 3mm shim and it solves the issue. There's a few posts on here about it, but it is a separate issue from the high speed vibe. The motor mount shim eliminates vibrations felt when the truck is at idle.
High I have a 2015 Silverado 1500 CrewCab. It also has vibration issues.
The first service they did road forced balanced my tires. They were out of balance. That did not fix the issue.
The second service they put it on the picoscope. Then they changed my ring and pinion. And put the picoscope back on it said it was in range but it's had a vibration at 45 mph. I drove it and it was still vibrating the same.
Third time it's in for the vibration. They put it on the picoscope and said its in range again.
My question is what is in range and what is a good picoscope?
'14 dbl cab TX Edition radio froze (first time) yesterday. Nothing would make it work. Also noticed my android phone showed no signal (I was in an area where I should have had 5 bars). I did a restart on the phone and my truck's radio started working normally. Go figure.
I got the motor mount shims done about 10k ago. Still get the idle vibration.
Unfortunately even these trucks own shadow will make them vibrate. Why some do and some don't and it doesn't matter how many parts you throw at the ones that do is the million dollar question.
GM threshold spec is 22 milli G's
My 2015 XLT CC half ton is back in for service for the 2nd time in 22k miles. I bought it in April 2015. The damn things vibrated pretty much the whole time, but i drive my truck alot and didnt have time to take it on and get a loaner.
I did notice it will vibrate on a long hwy trip and stop vibing (is that even a word?) during the same trip with never stopping at any point. So damn odd and frustrating. Ive been looking at Fords but the trade in $ theyve offered is terrible. Not sure what my next step is. Im pissed. The loaner, 2016 XL supercab vibes a little. I def dont want another gmc truck.
SLT maybe?
Edited by longhorn_cop
How bad is the trade in value?
Nice looking POS. Hope you get it resolved to your liking.
Low $30s on trades. Sticker was $53 and walked out the door at $41 last April.
If you paid 41 and were offered low 30's a year later, that isn't actually horrible.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
