Have you checked driveshaft also.
RT
Yeah, I've replaced mine with an aftermarket aluminium unit. Put 150 miles on the truck today with the spare in place of the offender, amazing to finally have the vibration gone.
Hello Everyone,
I recently traded in my 2008 Sierra Denali for a new 2017 Sierra Denali which I’ve had for about two weeks now. The truck is a 4WD short bed with the 6.2L/8 speed and has factory 22” wheels with the Bridgestone Dueler AT tires on it. I have been noticing a vibration/shudder/rough feel which is felt mainly when decelerating under 40 mph all the way down to a stop (it is not brake related as this happens with or without braking). It feels like it is coming from the rear of the truck and can be felt throughout the cab. When I shift the truck into neutral when it's doing this it's perfectly smooth. I did mention this to the dealer and they wanted me to drive it for at least 500 miles and that is where I’m at currently. Just trying to get an idea of what may be going on here and causing this. Any input would be greatly appreciated.
Thanks
Hello Everyone,
Thanks
Sounds like the pinion angle is getting out of alignment or the rear gears are machined wrong.
Axles didn't help me. Found a bad wheel though. Which is odd since these were mounted on my Tahoe before I put them on my truck and I never noticed any vibration. Had the wheels balanced multiple times, no issues with a static balance had them balanced twice in the last 6 months without issues. A dynamic balance might solve the problem. Most likely will just replace them.
Good luck everyone!
What made you think to look at that particular wheel?
Edited by Austin66
I have a vibration 45 to 65 that comes and goes only when cruising using my foot or cruse control will not do it while costing it will start shutting for about 1 sec and stop then do it again it's like an endless loop I'm taking it to the shop next week is this what y'all are having problems with to ?
Did you check the Axles? I am pretty sure another poster has pinned it to the Axles......
Actually since I know you haven't read all 706 pages of this thread because if you did you would know that my vibes came from the stock driveshaft that was bent. I did true my axle flanges because they were not running true and did contribute to some vibrations just not a much as the drive shaft.
RT
Edited by 07Softail
Hello Everyone,
Thanks
You go back and beg for your 2008 back, just like me.
Not sure if this has been posted or not.... interesting read if you haven't seen it before.
http://vibratesoftware.com/nvh-app-the-chevy-chevrolet-shake-no-one-fix/
Very interesting! My first impressions when I first had the vibration start. Only variables i have is that when the truck was new it didn't vibrate. Very soon after within 100 miles of lifting it with bigger tires it started. I assumed pinion angle first and then wheel balance and so on... So Im wondering if this issue has a way of becoming a problem over time. Meaning the adjustment gets out of spec on its own. Ive been wanting to re-gear to 3.73 to compensate for the 34" tires and i might have them go over everything and see if anything else is out of spec. Another thought i have is the locker malfunctioning at higher speeds. Who knows
I didn't check my pinion preload when I did my gears but I can confirm there was no carrier preload, but actually slack that needed more shimming.
Vibration back above 80mph on my truck... ready for a trade in? Who knows, stay tuned!
Sent from my SM-N920V using Tapatalk
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
