THis was my first thought
I second the above
I only have 1300 kilometres or roughly 900 miles lol. That's what I was thinking also about the rotors but this is brand new, and it doesn't feel like the normal shuttering when you have warped rotors, just feels like a small annoying vibration in the floor/frame kinda deal. Edited by 09rcsb
Pinion angle is bad while under breaking or ring gear tolerance maybe.
Yeah was thinking along these lines as well. The garage doesn't notice it.... it's so minimal I could live with it. But from my last truck to this I definitely notice it and it bothers me. Oh, what to do....I guess I'll go back to the shop and get them to check the angles and take it for another drive I guess, or wait until it gets worse...if it even does. I'll throw some weight in the back and see if it goes away, then I'll definitely know Edited by 09rcsb
Thought this was weird and worth sharing. My truck is actually doing OK now that I got 2 new tires that replaced 2 w/ RFB issues. But yesterday I was towing an empty single jetski trailer that must have had a serious out of balance or warped/old tire. Anything above 60 mph brought on a heavy shake in my truck.
What was weird about it was that the shake was in the steering column/shifter. Bad. Nothing really noticeable in the seat or center console.
Not sure I understand how towing a trailer (w/factory hitch receiver) would bring on a shake more towards the front of the truck.
Edited by Newly49
Find a gopro camera fasten it to the under body securely in place facing your trucks rearend. You will be surprised in what you will discover!
I bet there is some axle wraping happening. Brake issues are very possible, but I'm betting on something else as the culprit.
Keep us posted!
So in this video by Yukon, they show at the end how to check the preload. Would be interesting for a few of us to test this out and see what the preload is truly set at. There was a recall for some of our trucks indicating that the pinion nut was loose. Wondering if this spans a lot more trucks than the original recall. Would be killer if this is truly what the issue was and would explain why replacing ring and pinions and axles etc fixed it because when putting everything back together the preload was set when it originally wasn't from the factory. Sad if gm missed something this simple which I doubt. Hoping it's the fix for some!
https://m.youtube.com/watch?v=5cSWh1id9mY
Edited by hotrodz37
So in this video by Yukon, they show at the end how to check the preload. Would be interesting for a few of us to test this out and see what the preload is truly set at. There was a recall for some of our trucks indicating that the pinion nut was loose. Wondering if this spans a lot more trucks than the original recall. Would be killer if this is truly what the issue was and would explain why replacing ring and pionions and axels etc fixed it because when putting everything back together the preload was set when it originally wasn't from the factory. Sad if gm missed something this simple which I doubt. Hoping it's the fix for some!
Thanks for the video!!! So preload is checked when there is nothing in the differential but the pinion gear and yoke?
I read another article that says the best way to check it is with the driveshaft not attached, the wheels and tires off and the brake rotors off. Guessing the extra rotating mass throws it off.
Preload torque on the pinion nut is extremely light usually around 10-12 in-lbs. That's IN-LBS not ft-lbs. That being said too light of preload creates backlash problems and can usually be heard when decelerating.
Mine was fixed by correcting the rear axle backlash. Upon checking the original rear end they found the back lash to be all over the place. GM engineer approved a new rear axle. Prior to installing it the technician opened it up and found it was also all over the place on backlash measurements. He then replaced the ring and pinion in the new axle. Once installed the vibs were gone. It has been almost 2 years now and still no issues.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
