I just got a 2018 SLT All Terrain and it developed the vibration. This is my second truck, (first was repurchased). Dealer has attempted to balance tires two times and it gets worse each time. Now it’s at the dealer and they tell me the front to tires belts are broken.
I have already opened a case with GM and formally requested a different brand in tires (Michelin) due to safety concerns.
Dealer is telling me they can only install SR-A 275-55R20.
Anyone have luck getting a different brand tire installed?
On the truck that was repurchased I saw it for sale and had Bridgestones installed and was a CPO with a clean title.
My dealer replaced my sr-a at 1000 miles due to flat spots. I requested Michelin's and told them I would pay the difference between the two. It was no problem.
My fear of doing this is it absolves GM of any responsibility if the symptoms are still present.
I've had my truck for a little over a month.  I'm loving it (for the most part).  However, my truck has had some vibration at highway speeds.  I'm on vacation, and before leaving, I dropped my truck off at the dealer.  It has about 1300mi on it, and I had done a test ride with the service manager a couple weeks ago.  At that time he noted that on torque lockup it started up.  They texted me today and say that it is going to need a new torque converter!  They went to order the part and found they had one in stock.  So, hopefully upon my return, it will have been replaced and the problem resolved.  Crossing my fingers.
A "CPO" or a "CPOS"?
They can try to blame the tires, but using different tires than OEM (assuming they are same size and load rating as the OEM) in no way affects the vehicle warranty.
Today is day 50 and still not fixed and a new milestone.  I suggested the dealer try another brand of tires but GM will only replace
with same make and size as installed at the factory, in this case the GY 275x55x20's.  About 7 months ago after 5 trips to 3 different dealers and no help
I bought a complete set of 4 factory 18" wheels and tires from a 2016 Tahoe with 4500 miles on them to do my own troubleshooting.
Had them balanced and installed and lo and behold the shake was still there although some what less but at same speed and
from the rear (never had a problem from front-smooth as glass).  So evidently problem is not tires or wheels.  DUH?
Want to post a challenge...Can anyone top my 50 days continuous at a Chevrolet service department for the shake/vibrations without a fix?
To be continued....
To be continued....
Yeah....try 3 months, they did eventually buy mine back though.
WOW, 3months!  Should that be the case with myself and/or others in a buy back situation what did
GM use for the truck's value numbers?  KBB, NADA, or a mutually agreeable price?  Just want to be prepared
should that happen in my case.
Thanks in advance.
Figured I would post here in case anyone was wondering whether or not the '18 trucks had the issue or not. Bought my truck on July 27th. It's a 2018 1500 LT Z71 with 18" wheels,6 speed and 3.42 rear end. My previous truck never had the shake even running a 7 inch lift and 35's and now I have a brand new $50k truck that rides worse than my lifted truck. Drove the truck on the highway 4 days later and there was a vibration that felt like an out of balance tire. Called dealership and they said put 500 miles on it and then take it in because it could be flat spots. Figured it was probably the tires because I had been working the deal on this exact truck for over a month so it had been there for a bit. Took it in, they did a road force balance and said technician didn't feel vibrations. Picked it up and it actually feels worse so now it begins. Seriously regretting going back into a silverado after the issues on my '14 but that's my fault for not liking other trucks. Do anyways, just using this to document a bit because I'm not dealing with this by any means and I won't take it from the dealership until it is fixed. Feels like mine is milder than others have experienced but it is so annoying that I end up driving with the radio off trying to pinpoint where it's coming from. Sucks when I drive 100 miles a day on highway and cruise between 70 and 85, right where it shakes. Attached some videos below of my truck.
Thanks in advance.
Well they try to lowball you first and charge some bs mileage charge which made it worse than trade in value. Then they told me full MSRP and sent me a check that was 10 grand short of that, guess they thought I would take money and run. I got the email where they stated full MSRP and told BBB I was going to get a lawyer, 3 days later they gave me MSRP.
Edited by Chad2815
Thanks for the info Chad.  Picked up my truck yesterday (53 days) and shake still there after many new parts and tires replaced.
Now back to GM and if needed BBB.  Service manager just the middle man and did what the GM engineer told him to do.  Like to
have some time alone with that so called idiot.  Service manager would not give me the engineer's name or number.
I go by the motto...."If all else fail, let common sense prevail".
My truck is a 2015 so if a buy back happens no doubt a deduction for year and mileage be involved.  Have some numbers from
KBB and NADA for starters.  Glad to hear you ended up with a MSRP settlement.  Gives me some ammo to work with.
Note to Eric...Pursue the lemon law by contacting your state's Attorney General on your new 2018.  I found out the time limit
in my state was 18 months for the lemon law so had to go the BBB route.
I had a 2016 Silverado crew Z71 4x4 and it was smooth as glass til I was in an accident this spring when the truck had 28000 on it. To replace it I got a 2016 Sierra slt all terrain double cab and it has the shakes. Oddly enough, I have it around 42-48 mph then again at 75+. I'd be thrilled with the truck if it didn't have the slower speed shake. I never drive that fast lol. I had a PICO scope done and the dealer told me they have a truck on the lot (brand new) that shook worse. Going to take it back in and kindly ask them to check again with me on the ride so I can make sure I'm satisfied with their test. If it shakes worse I'll have them road force balance the tires and go from there to get it smoothed out.
Omg, is my truck stuck in v4 mode now, ****.n A! it sounds like I have clogged injectors. hopefully this is all it is. I find out after tomorrow my tech at Chevrolet is going to clean em as well as drain difs and trans flush. wish me luck!
Edited by Gofas
Hey gang,
   Not sure where this post will show up, but add me to the list of 2018 Silverado 4WD owners with the "Chevy Shake"...grrr. Pointed it out to the salesman while test driving. Contacted him after taking it home that the vibration was still there. I have had it back to the dealer twice now for the issue and will be in for the 3rd time tomorrow. The dealer has load balanced the wheels (20"), tried different wheels, balanced the drive shaft and sent one set of "pico" readings to Tech Support. They have spun it up on the hoist with wheels on, wheels off, suspension hanging and with vehicle on stands. Apparently, tomorrow another set of pico readings will be taken and sent to Tech Support. I haven't owned the truck for 30 days yet. Very concerned to say the least, especially after reading of all these similar complaints with very little fixes. My guess is diff or tranny. This truck has the 6spd automatic and like one post I read, seems to click through the gears way to quick.
   I live in Canada and am unsure of next steps or best direction for handling this. I have contacted the customer complaints and spoke to a representative or as they call them, ambassador to enter a case report. The dealer has been documenting through work orders and case submission to Tech Support. What do I need to do to cover my own rear-end?
Bakerman65
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
