The two white pieces of plastic bind on the round tube they're attached too, you need to use super lube or some sort of grease on that tube.
projectsummit, any chance of taking a picture of the pieces of plastic and posting it? ironic that we are using the phrase "pieces of".
This says its for a cadillac, but it looks exactly the same as what I did.
http://sandyblogs.com/techlink/?p=2441
If you look under the front of the seat you will see two big white plastic retainers around a black bar, that's what you need to grease.
I took my seat out of the truck, removed the screws holding the white plastic pieces on and then lubed everything up. Before doing this I could push down on the seat with my hand and it would creak really bad, now its silent.
Edited by projectsummit
My 15 Silverado cc had the seat movement issue. I did the hose clamp fix and all has been well until now. It's starting to move again after 2 months. What now?
make sure you also have the little white round clip that's shown in the Sandy blog I shared above.
Put the clamps on mine and it's a world of difference. Seems firmer than it was from factory. Very happy with this "quick fix" for the shifting driver's seat.
No squeaks on mine yet, though.
Once upon a time, I had a 2014 GMC Sierra with this seat issue. Took it to the dealer/s many times and was always told either this was normal, or can’t find the problem. I’ve tried all the DIY fixes to no avail. I gave up on the truck and bought a new F-150 and have not looked back, and doubt I ever will. I was a loyal brand customer since 1988 and this experience destroyed that. However, my fight is not completely over, we own a 2015 Yukon Denali and like clockwork, the damn driver’s seat is starting to move just like the Sierra. Precision Engineering the commercial says, makes me want to puke every time it comes on!
Rant Over….
I had to PHYSICALLY walk into my local dealership to be able to talk to someone about the seat issue.
It takes me about a half hour to get home from work, and i played phone tag the other day with voice message recordings of service reps, hang ups, front desk girls etc, and was never able to speak to someone. Took almost my entire drive home...i was F-IN FURIOUS!!
Anyway, like i said above, had to actually walk in to dealership to talk to someone. I was told to bring the truck in and they could fix it in a day. Said they use "shims" to fix?? Also said his guy does them all the time and that hes getting real good at fixing the seat issues now(and laughed about it like it was something i should be glad about)
I Prob will also add the hose clamps too as a reinforcement...this seat moving is driving me insane...smh
Sorry, there are SO many pages in this thread now and I'm trying to schedule this with my dealer. I have the seat movement issue on my Sierra, can someone tell me the TSB number on the latest fix for this issue?? He was poking around on his computer for it and I'm trying to avoid having to stop in just to confirm the problem and get them to pre-order whatever it is they need in advance. Thanks in advance!
My dealer has ordered the parts to complete this repair on my truck next week. They are doing this under PI1376, which appears to be the latest TSB for this issue.
Well I had my seat repaired 3 times so far and I finally forgot about the movement until now. The other day I accelerated hard around a corner to get ahead of traffic and POW! goes my backrest. I have never heard such a thing in 30 years of driving.
This is definitely the worst interior I have ever owned and I can't wait to get rid of it! The Silverado is not what it use to be.
I have a 2015 slt crew cab....the seat started making that clicking noise around turns once in a while at about 1000 miles...now's its got about 2500 miles and its doing it constantly... It's so annoying and its to the point now I know what turns its going to do it while I'm driving before it even happens...its driving me crazy!
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
