  • 3 months later...
Is it possible to get the ECM and TCM in my 2016 Silverado 5.3 reflashed to stock by anyone other than a dealer?  I changed the parameters using a Diablo Predator2 that, unfortunately, I lost when our home burned in the Camp Fire last November.  I need to return it to stock before I take it in for warranty work.  Thanks!
This is my exhaust:
-Speed Engineering LongTubes
-Dual X Pipes
-Dual Magnaflows
-3" Dual Exhaust
Sound:
I have a custom DiabLew Tune on my Diablo i2
I have had it for almost 3 years now, cero issues on my daily.
I have been on a Edge canned tune for a year now. CTS2 Evolution. I did the AFM delete and their trans tune. I liked how it drove. I am currently waiting on a custom tune from 5 Star tuning. This is will be on a SCT BDX tuner.
I told them to be aggressive with the tune as I truly want to notice a difference between a "real tune" and a "canned tune".
I will report back after some driving.
Just got my tunes back from Price over at 5 Star Tuning.
Wow.
I THOUGHT i was driving a "tuned" truck with the Edge CTS2...boy was I wrong.
I immediately felt a difference with throttle response. (this maaay be partial to me having the Edge Throttle booster, which sends different signals to the TPS to give a move throttle cable feeling) but I had this on before the tune and the throttle response was better than stock for sure, but now its amazing.
The 1-4 shifts upon stop and get up is phenomenal every gear stays in the 2000-2200 RPM range where torque is had. Then 5-6 drops down low as it should once I get up to speed.
WOT trans shifts hard and quick at 6K RPM! So rev limit got raised which is nice.
Freeway driving is a pleasure now as I dont have to drop down to 3rd to go anywhere, just give it some gas and it moves, even in 6th.
Dead stop to about 70 is quick for sure for only being intake tune and exhaust. Ill get a video and seconds hopefully soon.
Overall, couldn't be happier and money well spent, this truck is such a pleasure to drive now I can see myself owning it for 10 years +
Wow.
Have you done the paint stick mod on your throttle pedal ?
I haven't. I do know what you are talking about. I just haven't done it. I am not sure how much better my throttle response can be as of now as its pretty nice!
Are there any loose guidelines to adjust shift pressure?
mu truck shifts pretty sloppy and pretty harsh when I am getting on it, mostly 3-4, 4-5 shifts.
Overall just shifts really sloppy and confused.
All i I did was the 87 performance tune, plus 10 or 12 percent throttle response, turned afm off, and corrected tire size.
Also so I noticed going up steep hills in the mountains a few weeks ago it really had a clunky shift going down to first up a steep hill.
doesnt have the ass to get up hills on the nterstate without going down to fourth.
I hate to dog the truck. It’s beautiful and haven’t had any issues outbid it in 6 months. Just wish it would shift more smoothly
Edited by Bammer25
Do it, it will be even better
If anyone is interested.
I have a brand new SCT BDX #40490 to sell. I didn't end up using it. I have it listed on ebay right now.
I would list on here but I dont have 50 post yet.
I haven't heard of this. but now that I'm out from under a rock, Ill need to check this out!
however, Ill need to wait for my trigger finger surgery on both hands to heal...boy this is not easy to type!!
Nice vid on your exhaust!
Your gas pedal assembly has some play in it, so if you touch the Gas pedal, the whole assembly moves a bit instead of the pedal pivoting.
If you put a wood stick between the pedal assembly and the firewall, that stops the play and the throttle response is much sharper
Personally, I actually pulled a bit on the pedal so a bit larger stick could fit and the assembly had no play at all.
If you need anything about that, let me know lol
I peeked under my dash this morning just to see if I could do anything...I was able to loosen the 10mm nuts, but could not move the bracket. It was difficult due to stitches in my right palm and left thumb, so maybe it's just because I couldn't get a good grip on it.
I even tried to slip a piece of painter's stick, but could not get it to go behind the bracket...hence I tried to remove the bracket.
So...are there other nuts/bolts that need to be removed to get in the back of the bracket?
Seems like everyone is just slipping washers and pieces of wood behind the bracket, but I don't see how that can be done. I even lost a piece of wood behind the bracket, it fell down behind and I have no idea where it went...LOL!
Stitches come out next week Tues, so I plan on trying again, just not sure about removing the bracket.
I was going to pm you, but hopefully others that may be lurking will benefit from your answer.
On another note, did your wipers pick up the wax from your windshield?
I watched that vid as well, heck I drink apple cider vinegar with water in the morning as a wake up drink, makes a good tea! LOL!!
I used to do that back in the 90's on my cars, but eventually the wipers start to pick up the wax and starts skipping along the windshield. Haven't tried the Rain-X yet though.
I have found wax to be great, because it lasts more than RainX
RainX is great but fades in a few days. Vinegar removes water spots and contamination amazingly well
The wiper dont pick up wax, if you buff it off good once youre finished waxing it
I also clean the inside of the windshield an RainX it so its easier to clea
You dont need to loosen the pedal assembly, here is a video on it(Not mine, but is the same thing i did). The first video shows the pedal flex and in the second you can see where to put a piece of wood to bead it
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
