2016 regular cab, purchased new 3 months ago (10/1/2016). So I stumbled on to this thread last night and read it start to finish. I live in extreme South Texas - it snows here about once every 100 years. Rust no problem, right? Wrong - extreme high temps and humidity and lots of salt air. No problem - keep the truck in the garage overnight and a good carnauba wax job. Never thought to worry about the frame. So I crawled under last night, after reading all these threads, and yep, some bare spots, with metal exposed. Probably the result of rocks/pebbles on caliche roads. I was surprised at just how thin the wax coating is. No, I'm not taking it to Chevrolet - as someone suggested the only way to do this is sand, prime, and some black enamel paint in the affected areas. But this changes everything - no underneath power hose sprays like a used to to with my Jeep after beach running. I'd crawl under the thing and scrub/wash the frame. That will pull the wax off. This changes everything - I'm 71 and continually sanding/painting the frame is going to get old very fast.
I'm not new to Chevrolet - been driving their pickups and old style Blazers since the 1960's. Had to deal with the surface rust on the body, but never frame rust until a 2004 which I had purchased used, sight-unseen, from PA. My sister, who lives up there, had checked it out, said the body was perfect. I guess she never crawled underneath it. When it got down here - large chunks of frame rust started to peel off. Spent a lot of time scarping the thing, then undercoating it. I attributed that to the PA climate. Never dreamed that the frame wax was over bare metal, so never thought that was an issue when I bought my 2016. It doesn't take a Ph. D. in automotive design to realize that wax over a bare metal steel frame isn't the greatest for long term longevity. When did GM start this process - I'm thinking with the 1999 or 2000 models.
Most owners don't crawl under their vehicles and check things out like we fanatics on these forum do. I was really happy with my new 2016 (no vibrations or any other problems) until this. It's going to be continual long term maintenance - much more involved than the twice a year clay bar and waxing I do to the body.
http://www.magnetpaints.com/underbody.asp
You could try this stuff instead of painting the spots. Just don't get it on your skin.
I suspect that as a result of CAFE standards and the ever increasing need to reduce weight the automotive industry chose the same solution that afflicted early 80s Japanese rust buckets-----changed percentages of carbon and other elements for stronger steel alloys which permitted thinner gauges and saved weight, but rusted much faster than the previous alloys.
Rusting is not new and occurred on all vehicles to a lesser extent until the 70s when automakers eliminated frames and went to unit bodies on passenger vehicles to reduce weight. Doesn't affect passenger vehicles now because their frame-less bodies permit the entire unit to be dipped in anti-corrosion compounds, primed, painted and clear coated. However, a simple coating of snot on truck frames doesn't offer much protection and the newer alloys rust a lot quicker than the older pre-centennial trucks.
Aside from common sense methods to prevent accelerated rusting, e.g. never parking a wet salted vehicle in a heated garage and flushing the frame, bumpers and tank areas with fresh water ASAP, one prophylactic measure that might help would be oil spraying. Oil spraying was common on all framed vehicles during their routine 3000 mile oil/filter and greasing prior to unit bodies, sealed fittings and extended oil changes and it does inhibit rusting on uncoated steel. More difficult to do nowadays because you have to be careful around disc brake areas whose discs are more susceptible to contamination than the drums on older brake assemblies.......temporary fix - but enough to hold until the next 3-4K oil change and does seem to help on the frame where the metal becomes exposed especially inside the frame, the weld and hole areas, in the rear spring shackle, and the sway bar areas. It certainly kept the frames of my Avalanches which used Mexican sourced crap steel frames covered with snot looking great and almost rust free compared to others posted on the Avy board. Two oil sprays so far on my year old Silverado and no rusting yet.
Even today the Japanese vehicles are rust buckets. Toyota just lost a lawsuit and is being forced to recall the Tacoma and Tundra due to severe rust rot. And their frames were painted.
I agree with you on strategies for dealing with rust. Oil/fluid film-like materials are the most effective way of preventing rust issues. I spray mine twice each year, both inside and out and it's worked well so far. Until more manufacturers are sued for rust issues, I dont see anything changing. Personally I want to see wax and e-coating go away in favor of an epoxy-based paint or coating.
Wife shopping at the local mall today - I get dragged along to suffer. Waiting in the courtyard I see a new GMC Canyon on display. So crawl under - no goop/wax/slop covered frame - looks like some kind of powder coated black enamel. Liked what I saw. No, not going to go from a Silverado to a Colorado/Canyon, but just wonder why they couldn't have give the same frame treatment to the Silverado/Sierra. We don't have snow/ice down here at the southern tip of Texas, but beach running is the same as salt on the roads up north. If I spray/clean the salt/sand it will remove the wax to be replaced by prepping/primer/painting. I intend to keep this vehicle for a long time so in the end it will be a painted frame, albeit bit by bit.
Perhaps they are trying it out on the little trucks before going to the big ones.
Just picked up my 2015 LTZ Z71 the other day. Im embarrassed to say it, but it never even occurred to me to look at the frame. What the hell is going on under here? Im trying to get an appt with the dealer nearby to clean it off. My pressure washer isn't getting anywhere. Spent an hour at like 1600 and only got about 90% off in a 1 foot area.
Edited by BigBadBruins
I crawled under my truck the other day to check something out, and noticed a small patch by my drivers side rear crew cab door that was starting to rust. I contacted my local dealership and they have me scheduled on Monday to bring it in. They said it could be two things: 1) The "known issue" of the flaking of the factory spray on stuff, which they said they will fix or 2) they didn't actually spray on the rust inhibitor under my truck, like I paid for and they said they did.
Is there a way to tell the difference between whatever they spray on under the truck as a rust inhibitor versus the factory spray on stuff? Just curious if I can tell at quick glance. I'd be very pissed off if I paid for a service they didn't even perform.
Edited by SilveradoSaver
For those who get this done under warranty, which warranty exactly are the dealerships saying its covered under? 3 year 36k bumper to bumper or is this part of the corrosion warranty? My 2014 could use a touch up in a lot of spots and was going to call the dealership tomorrow and see what they say. Currently it has 35k so its under the 36k mile warranty but its getting close.
I just double checked my paperwork and unfortunately it didn't specify. I recall looking into the detail of the corrosion warranty though and did not see the frame included. So, if I were you I'd get it right away. You are getting close! Also, you will likely only get one chance for them to fix this. Make sure they do it exactly as the TSB says which includes removing the bed. My dealer had redone mine twice and it still get peeling off and rusting out. And they didn't remove the bed. I found spots where they has just sprayed over the rust too. Nothing is more frustrating to see than that. I went off on the manager and he just ignored my complaints.
The wax coating and a the pressure washer are not the best idea as it will strip it off.
I just go under and hand wash. Kept the frame on my 2014 looking like new.
I dropped my truck off this morning for them to take care of this. I was glad to hear them mention the truck would be sent to a company to be properly cleaned under neither prior to re-applying whatever coating is under the truck. They could have just taken the lazy way and I wouldn't have a clue... Until the issue re-appeared again.
Just picked up my truck from my local GM dealership to deal with the flaking undercoat/rust issue. Not only did they clean it and respray the entire underside of the truck, but they also re-sprayed the interior fabric protection as well. There was nothing wrong with this, but they decided to do it. Thought they handled this issue very well. They think the flaking/rusting may have started when someone put the truck on a hoist while the spray had initially just been applied; could have been at the dealership or factory, they don't know. Doesn't matter - They made things right!
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
