Had ordered a AT4 with duramax and 20" wheels with  most of the packages  as options ordered since January.  Had this same truck with a 6.2L since the beginning of November on order and never had anything happen with that, so I switched to the duramax.  Finally said today my build date is scheduled the 1st week in March.  Hopefully this holds true, who knows from then how long it will take to actually get the truck?
Mine is being built same week. 6.2 custom trailboss.
Dealer ordered my Slt with 6.2, max trailering and slt premium plus 2/8.  Told me yesterday that target production week is 3/1/21. I was surprised how quick I have a target week considering some others stories.
Just spoke with my dealer yesterday.  Should have the truck by mid March.  Would have had it sooner, but my original order included running boards which are all on constraint.  They asked to resubmit the order Feb. 1 without and it went through instantly.  Assuming no shipping issues, could have it as early as next week.
I put my order in on Jan 6th, found out it was built last week(week of Feb 15th).  No accurate ETA, I'm guessing early April.
Black AT4, 5.3 and the AT4 Value package.
I ordered my AT4 on December 8th up here in Canada. Picked it up today. Was about 11 weeks including Christmas.  The high clearance running boards did not come with it, they are on back order.
Wondering if I can get some input on pricing. Particularly pricing in Canada.
I'm looking at a 2021 AT4. MSRP is $65000 CAD. I'm able to get someone to sign for GM employee pricing which takes off $5900. Dealer says they can't go lower than GM Employee pricing and can't stack discounts on top of GM Employee pricing. Any truth to this?  I'd like to see another 2K off with 0% financing.
Just curious what kind of deals you guys got.
I submitted a claim to GMC Customer Service in an attempt to get an ETA on High Clearance Steps that did not show when my AT4 arrived. It’s been 16 days. I offered to  take a credit to go get a different set boards. Crickets. ?
I can’t speak to employee pricing. I get fleet pricing. So it was about $5000.00 off MSRP. And I was also told that I couldn’t get the Costco rebate as they can’t “stack” discounts.
I used GM pricing, lease loyalty, GM CARD cash, 500 area market deduction. Also would have been able to use the Costco 1000 if my truck had been delivered before it expired!
Bottom line the dealer Will tell you anything to keep the price up! Move on to another dealer ! Good luck
I appreciate the input guys. I'm wondering if being in Canada affects discounts. It seems like guys in the US get much steeper discounts than up here. However I will be talking to other dealers.
where in canada are you? that seems like a smokin deal to me
Just picked mine up yesterday.  Got here sooner than I expected.
Crew Cab RST  6.2 w/ standard bed  Satin Steel
Ordered Dec. 22   So 9 weeks, but that included the Christmas shutdown.
Lucky you I ordered dec 17th and truck is suppose to be built this week
I keep chatting with chat online and one of them said yesterday it was built
however i talked to another one today and said its scheduled to be built this week
Online chat does not have the most up to date info and it is best to reach out to your dealer.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
