1 hour ago, dctackett10 said:
For those who swapped out the center consoles.  The clips from gm. They are priced at 2.25. Is that for the pack of 5 or each?  Do I need to add 5 or is it a pack of 5?
Also. When changing the console. Does the driver and passenger seat need to be removed or just loosen?
You just need to loosen all four bolts on the drivers seat you don’t need to remove it just move it a little to the side
29 minutes ago, Zelas said:
I just found this online. I paid 290 for mine with a hook up at a bodyshop. This is a better deal for those who don't want today shipping.
https://sdparts.com/i-24134630-genuine-gm-parts-84602302-center-console-upgrade-for-2019-silverado-work-truck-models.html?gclid=EAIaIQobChMI8bCHi6Xf4wIVlpOzCh1FMAVFEAYYBSABEgJOCPD_BwE
Yup. That’s the one I’ll be ordering.  But I want them clips from gm. But not for 17.50 shipping lol.   Gotta find them somewhere else after I order this console
The price for the clips is each and you need 5 of them.
All 4 of the bolts holding down the driver seat need too be removed so that the entire seat can be moved forward and back as required to get to the hardware of the center console and seatbelt attachment. There is a wire attached to the seat for something that prevents you from being able to completely removed the seat. No easy plug to just simply unplug and be able to remove.
The passenger seat can just be slid all the way back and then reclined to gain access to the side of the console.
Sent from my SM-G975U using Tapatalk
Well I found the center storage same price as the one from gm but with free shipping.
So I was was just going to order the clips from gm but they want 17.50 for shipping LOL.  Does anyone have a picture of the clips so I can see if local part stores have anything like them
I bought everything from my dealer hassle free. Might have paid a little more but there were no hidden shipping fees that I got slapped accross the face with at checkout.
Here is what I was quoted from my dealer.
Only tax was added to the prices.
Console
8464-7286 $438 +tax
Replacement clips
1154-9266. $3.46 each +tax
5 required
Rear wheel well liners
(Hardware kit included)
8426-3801. $150 +tax
I just purchase the 2019 Trail Boss ,custom, and love it except I can not understand  why they would not have ANY storage in the center console that folds into a jumpseat.!!!!! Anyone have any part numbers for a replacement? I want a center console with some storage......ugh.
Also, if anyone has added anything to the accessories I would be interested, i.e. extra USB, security system, DECK, tool box drawers for the bed.  Thanks!!
Dude! Read my post right above your post.
  • Haha 1
I just bought a 2019 Trail Boss last week and was dumbfounded that the armrest console doesn't open up for storage.  It reminds me of when you order cable or satellite tv. You want to get  a certain channel, so you have to order the next higher package with a lot of channels you don't want or need.  If I wanted an LT I'd have ordered it.  It's ridiculous that the center console of a custom level truck doesn't have storage.  I think the last truck that I had without center console storage must've been in the 80's.  Bad call G.M. / Chevy.
custom = cheap = lowest model available. it doesn't mean it was a custom built truck
I agree it is a piss poor decision to remove it, but that's why the truck was so cheap.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
