Ok guys I have the same issue with my rally 2 with 4000 miles where do I start this sucks
Our 2014 Rally 2 is back in the shop as of this morning. They've road forced the tires a few times, changed all four tires, lubed something that wasn't done when it was built, rebuilt the rear differential, replaced the drive shaft. Luckily we have a dealer that is really working with us. It's been in the shop 5 times now. Biggest improvement was when they rebuilt the deferential. Still vibrates. Be ready to be in it for the long haul. Be nice with the dealership and they'll work with you. If this last trip doesn't fix it we'll be going the lemon law route. Keeping our fingers crossed! Good luck to you!
Ok, they pulled and balanced the drive shaft this morning, didn't fix it. They are now looking at the ring and pinion. Parts in tomorrow morning to make the changes. They told me it's defiantly something in the rear end that's causing the vibration.
Crazy thing is, I had zero vibration until about 12,000 miles. Then like a switch it started.
Hope they get it close enough by this Friday as I need the truck this weekend.
Very frustrating to pay this much for a vehicle and it's not 100%.
Looked at a Tahoe LTZ yesterday, might have to dump and run if this doesn't get fixed right.
We also have 22" rims and issues with the back. They completely rebuilt the differential (ring and pinion) and that's where we felt the best improvement. Both readings of the differential and the shaft we WAY off balance from factory. Pretty much the whole truck was built off spec, things weren't lubed where they should have been. I'm wondering what went on when they built ours. It's a Nov. 2014 build. They ordered a brand new shaft built within the last two months and installed that and we didn't feel much of a change after that. Still not fixed though, it's back at the dealer today and the 2015 LT Z71 with 500 miles they gave us as a loaner still has some vibration at highway speeds. We can't win! Edited by Bdkfl
I wonder how many people have had the body mount service bulletin applied (repositioning and retorquing) on their trucks and whether or not that led to a successful fix.
Shimmy, do you have the bulletin handy or happen to know the number? Thanks!
So did you try the body mount re-torque?
I loosened and tightened all of them one by one last night but don't know if it made a difference since I only have a 4 mi commute to work all back roads so haven't had it on the highway yet. I think tonight I'm going to loosen all of them, and the tighten in a diagonal pattern similar to how you would tighten lug nuts. Would love to have the service bulletin to make sure I'm doing the procedure properly. I would try loosening and driving it around a little to get it to resettle but that makes me a little nervous so I will try doing it stationary first.
Edited by hotrodz37
Yep was thinking the same thing. But that is what was told to me by the tech/engineer at the shop last week. I didnt know there was a bulletin, I am curious to see this as well. I seem to have the shake in the rear end of the truck. You can see it at 74-80mph in my Snuglid. Seems more like "Beaming" mor than anything.
My cab to frame bolts were torqued to 110 lbs from the factory. Lowered them to 70. Best I can say is it may have made a difference. Mine is a 2015.
Joe
Edited by jagabom
Hey all might be getting little bad data on the cab mount torque specs. Raptor instructions say 70ft lbs and westin says 95ft lbs. my buddy that is a gm technician will get back with me with what the service manual states
http://www.raptorseries.com/installation-instructions/1201-0026M_install.pdf
http://www.realtruck.com/shared/pdf/manufacturers/198/75-3023.pdf
Edited by JC84
3 main bolts on each side are 122 lb ft. Nuts at front are 52 lb ft. As per GM Service Info.
Edited by tbarn
I just read on another site that the middle one is 35 lbs. Thanks JC84 for checking it out for us.
Joe
I second that - Thanks JC, appreciate it! They are definitely 70+lbs each. I checked all of mine yesterday that hadn't been touched since it was new and I put the torque wrench on them before I loosened them and they all clicked at 70ft/lbs. might be more but definitely not under 70. Hope to get some good info soon!
Also, I found the cab mount settling procedure. Seems pretty involved:
Cab Mount Settling Procedure
Warning: When settling the body cushions, do NOT separate the frame from the body more than is necessary. Possible personal injury and damage to multiple parts may result if you do not follow the guides outlined below:
Intermediate steering shaft—Do not allow the shaft to extend more than 25 mm (1 in).
Fuel tank filler hose—Do not stretch the hose excessively.
Tail/Turn signal lamp wiring/rear lamps junction block—Leave slack in the wires
Park brake cable—Leave slack in the cable.
Body ground straps—Leave slack in the wire
The technician should first loosen the fastener located at the center of each body mount (6 for a regular cab, 8 for crew and double cab).
Using a large angled pry bar, lift up the cab body slightly to settle / relax it. Perform this at each mount location one at a time.
Repeat this cab mount settling process twice, to confirm the mounts are settled / relaxed.
Visually verify that the cab to box alignment is correct before re-torquing all mounts to specification found in Service Information, body repair, frame and under body section.
Hate to hear about your problems and while the shaking sucks how does that show that the truck was "not reliable". Did it break down on you or something?
No it didn't leave me stranded and I didn't give it the chance to. Them not knowing what's causing all these truck owners the same issues. ... to me screams unreliable.
Like I said ... I liked my truck...my experience along with many others on this topic has been apparently different than yours.....and I'm glad for you.
JC, I was thinking last night. Do you think your vibration could have been from the steps themselves vibrating in the wind, and when you took them off it fixed it? Just a thought, but hoping it was the actual re-torquing of the body mounts that did it (hoping for my case anyway).
I was thinking the same thing. Couldnt figure out why he removed the running boards to re-torque.
I have a 2014 z71 that was bought back by Chevrolet as they claimed to fix the vibration I still have. I purchased knowing it had been an issue at 50 mph, but I was told the problem had been resolved.
I know the dealer I bought it from but would be more comfortable bringing it to another dealer to look at.
Any thoughts on this process?
I did sign an acknowledgementioned that I was made aware of the issue and that another year was added to warranty.
thanks. I did pay far less than market UT just want the vibration to
go away
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
    • That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
