THis was my first thought
I second the above
I only have 1300 kilometres or roughly 900 miles lol. That's what I was thinking also about the rotors but this is brand new, and it doesn't feel like the normal shuttering when you have warped rotors, just feels like a small annoying vibration in the floor/frame kinda deal. Edited by 09rcsb
Pinion angle is bad while under breaking or ring gear tolerance maybe.
Yeah was thinking along these lines as well. The garage doesn't notice it.... it's so minimal I could live with it. But from my last truck to this I definitely notice it and it bothers me. Oh, what to do....I guess I'll go back to the shop and get them to check the angles and take it for another drive I guess, or wait until it gets worse...if it even does. I'll throw some weight in the back and see if it goes away, then I'll definitely know Edited by 09rcsb
Thought this was weird and worth sharing. My truck is actually doing OK now that I got 2 new tires that replaced 2 w/ RFB issues. But yesterday I was towing an empty single jetski trailer that must have had a serious out of balance or warped/old tire. Anything above 60 mph brought on a heavy shake in my truck.
What was weird about it was that the shake was in the steering column/shifter. Bad. Nothing really noticeable in the seat or center console.
Not sure I understand how towing a trailer (w/factory hitch receiver) would bring on a shake more towards the front of the truck.
Edited by Newly49
Find a gopro camera fasten it to the under body securely in place facing your trucks rearend. You will be surprised in what you will discover!
I bet there is some axle wraping happening. Brake issues are very possible, but I'm betting on something else as the culprit.
Keep us posted!
So in this video by Yukon, they show at the end how to check the preload. Would be interesting for a few of us to test this out and see what the preload is truly set at. There was a recall for some of our trucks indicating that the pinion nut was loose. Wondering if this spans a lot more trucks than the original recall. Would be killer if this is truly what the issue was and would explain why replacing ring and pinions and axles etc fixed it because when putting everything back together the preload was set when it originally wasn't from the factory. Sad if gm missed something this simple which I doubt. Hoping it's the fix for some!
https://m.youtube.com/watch?v=5cSWh1id9mY
Edited by hotrodz37
So in this video by Yukon, they show at the end how to check the preload. Would be interesting for a few of us to test this out and see what the preload is truly set at. There was a recall for some of our trucks indicating that the pinion nut was loose. Wondering if this spans a lot more trucks than the original recall. Would be killer if this is truly what the issue was and would explain why replacing ring and pionions and axels etc fixed it because when putting everything back together the preload was set when it originally wasn't from the factory. Sad if gm missed something this simple which I doubt. Hoping it's the fix for some!
Thanks for the video!!! So preload is checked when there is nothing in the differential but the pinion gear and yoke?
I read another article that says the best way to check it is with the driveshaft not attached, the wheels and tires off and the brake rotors off. Guessing the extra rotating mass throws it off.
Preload torque on the pinion nut is extremely light usually around 10-12 in-lbs. That's IN-LBS not ft-lbs. That being said too light of preload creates backlash problems and can usually be heard when decelerating.
Mine was fixed by correcting the rear axle backlash. Upon checking the original rear end they found the back lash to be all over the place. GM engineer approved a new rear axle. Prior to installing it the technician opened it up and found it was also all over the place on backlash measurements. He then replaced the ring and pinion in the new axle. Once installed the vibs were gone. It has been almost 2 years now and still no issues.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
