Well you had one pic up there and it looks like it's from a magazines so lol
Thanks, I used to work for the magazines, so that's a great compliment!
Here is a rear shot with the dog crate.
I can't believe you said that. The 900s are by far the best generation truck GM has made. I went from an 09 to a 2014(worst generation) back to a 2009 Avalanche.
800's 2500 series they are the bone that wouldn't break!
Check out ThisTruckSucks.com. It is a new website dedicated to the #GM #Chevrolet #GMC vibration issue.
That guy is on this website and has posted on this thread with his story several times
Yes he (I) is. I am very irritated that GM is ignoring this problem and I will not go away until they address it.
I absolutely loved my 900. It never let me down, easy to mod, never vibrated, even with 20" rims. Mine was not loaded as much as I would have liked. I went shopping, and brought home my '17. My '13 maintained it's value, too. I also love this one. It has all of the options I wished my other one had.
The 2013 GMC SIERRA Denali is the best truck one can buy in my opinion. The rear disks are a breeze to change and last forever, the perfect diff gear ratio, heated and cooled seats that are actually comfortable. I mean its by far the best truck for the money and they are harder and harder to find and maintain their value so well.
Well add me to the list. I put all terrain tires on my new turn at 2 k miles. All has been fine until I turned 14 k miles. Now The truck shakes and vibrating starting around 65 mph. Had it at tire shop all day and after multiple road force testing and even putting on new tires. Truck shakes and vibrates still. Dropping off at dealer next week. Crap.
I rented a 2017 Suburban this week for a vacation to Maggie Valley and man, this thing shakes exactly like my 14 truck that was bought back.. It starts to come in at around 72 and is at it's worst around 78. I haven't posted in this thread since I got into a 2500 because bc I haven't experienced this since. Quite disappointed to say the least... This is an LTZ 4wd, 5.3, 6 speed, 3.08. Between the shakes and the buffeting in the cab when it goes into V4 around 40 mph or so, I'd never even consider another k2 half ton anything!
I towed a trailer with my 2017 6.2 from MA to NH and on the way back home I started getting a vibration between 70-75 MPH. It comes and goes while towing. Only time I have felt any shake in a K2 is now. I have 12k miles on the truck. I have to investigate the trailer and make sure its not something with that since it only shakes while towing. Its not a consistent shake either.
OK, took my '15 in to a different and larger Chev dealer last Wed and passed along the history about the many trips to the
other dealer with many road force balances and same old standard canned response of "in specs". Stay tuned for the results.
Much has been discussed and many areas pointed out or parts changed on this vibration subject.
NOW...can a common comparison give us any new information?
Assembly plants...Ft. Wayne or Mexico (Mine is MX)
2WD vs 4WD (Mine is 4WD)
Reg cab vs Double cab vs Crew cab (Crew here)
Gear ratio...3.73-3.42-3.23-3.08 (Mine is 3.23 and shake still in the 72-84mph range)
Engine size...4.3-5.3-6.2 (6.2 here)
Wheel size...17"-18"-20"-22" (Mine is 20")
Tire Mfg...(Good Year LS-2 here)
Transmission...6-sp or 8sp (8-sp here)
Any other thoughts or ideas??????
Aren't there HDs with the issue?
Don't really know that answer Gassamax. Postings have been for the 1500 series as I recall.
Since nearly all the shake and vibration issues have been at the highway speeds of 70-85mph range
my take would put the problem starting in the rear end out to the wheel and tire itself since all gear ratios
are involved. The drive shaft, transmission, converter, etc. would spin at different speeds but the
shake stays in the same rpm range. Also the stock tire diameter (height) remains quite constant at
around 31" no matter which wheel size 17", 18", 20", or 22" is mounted.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
