On 6/26/2020 at 7:41 AM, Dearmosd said:
The joys of corporate American selling a decent product with faults and ignoring the thousands of American people and their hard earned money only to look forward and forget the past problems they left among their American population.
I wish I had spent more time investigating Ford over Chevy. Although stuck with a Chevy my next WILL NOT be a Chevy.
Fool me once shame on you but I will not get fooled again
lol and thats where your research stops on a Ford.  Do some more and youll see the only one that stands the test of time is Toyota by far the best engineered.
22 hours ago, Dearmosd said:
If Toyota make a size comparable to a suburban I would have looked at it but since they only make a Tahoe size Toyota was off the plate
Its called a Sequoia, I dont even know wth you're talking about but the Tundra is still the largest and heaviest 1500 on the road.
The Sequoia is comprable to a Tahoe not a Suburban
The Sequoia and the Suburban are full size Suvs with 3 rows of seating.
And so does the Tahoe, but the suburban has more cargo room than both Sequoia and Tahoe, hence the reason I got the suburban over the Tahoe
My truck is running smooth, knock on wood!  Really happy at all speed ranges. Axle shaft balance, new universal joints and an alignment some time ago.  Nervous about getting new tires soon, lol  prolly drive til these are bald don’t wanna mess anything up! At 81k
Buy Michelin defenders.
My 2017 with only 7000 miles on it now, is still doing what it has since day 1. The technician told me in May of this year that I should drive it harder and that it was something to do with it wanting to go or going into 4 cylinder mode. I notice the "vibration" or "hesitations" when I first start it up in the morning. I will notice it immediately as I start to accelerate and will notice it "bucking" or hesitating up to about 35 or so for the first 5 or 10 minutes and then it drives like a normal truck again. They told me in may that in 6 months I wouldn't notice it anymore (guess they were trying to brush me off). My thoughts are, if it actually had anything to do with the 4 cylinder mode then why don't I notice it after it warms up??  It is a 6 speed transmission and they tell me that Chev. has no service file bulletins on them and it is just for the 8 speed as far as changing out the transmission fluid to Mobil 1. I would like them to change it out to see if that makes the difference but they seem unwilling to. Does anyone have an email address or contact for someone that might care at Chevy?
On 7/20/2020 at 8:55 AM, flyingfool said:
trans vibes.. tc replacement time
Tc=? Torque converter?
what MPH point do you get the vibrations?
below 35mph
above 80mph
between 40-75 mph???
i only vibrate at 80 and higher, and i have  a suspision the poorly  paved roads are the culprit,   need to test smooth highway vs street paved, car pool lane vs  slow lane where semis travel. i feel the occilasions are being caused by the wave in the road surface,
Edited by flyingfool
if you want to take the road surface out of the equation , find a local shop with a dyno or a smog test dyno then spool it up to 90 mph
Mine did the same thing a couple weeks ago on my 17 Sierra cc 5.3 z71 4x4. Dropped it off at the mechanic and my transmission was completely shot, not even rebuildable. The problem started at the torque converter. Did a lot of research and turns out there’s a class action lawsuit against gm on these transmissions. $4,300 out of my own pocket. I’m pissed to say the least
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
