17 hours ago, flyingfool said:
drivie in m4 or m5 mode for a few days, this disables the v4 cylinder deactivation and will remove this as a variable  yes the v4 firing can cause a bit of a lugging motor at times... I also had vibes for a while and they went away or i just got use to them. I did switch over to the 18" z71 wheels too. i dont notice the vibes if they are there.
driving in M4 on the trans select will give the best shifts ,crisp and clean, M5 softens things up  a bit..
Do I find the M4 selection by touching on the - or the + on the lever for the pushing on the towing selector?? Sorry for my stupidity!
yeah shift from D all the way to M selection, kinda like shifting manually into low gear in the old days.  -/+ will set the last gear the trans can shift into.  i like M4 for stop and go city, and M5 for city driving but more open streets with less stop lights and traffic, then use D for on the highway to sip gas on 4 cylinders.
Edited by flyingfool
I'll give it a try. Still wondering if I just put it in the position for trailer hauling would that take it out of the 4 cylinder mode.
no, but it will improve the v4 performance if you use tow haul from my testing, it helps hold the v4 longer instead of falling back into v8 . i have been able to drive up a decent grade in tow haul and hold v4, but i do have 3.74 gears, yet most trucks come with 3.42 or something like that..
if the truck is new the first thing i would recommend is the thermostat delete, , lots of parts in the trans are plastic and rubber, doing this will keep it shifting like new for years to come. heat distorts all the parts in there. causes leaks and crappy shifts
  • Thanks 1
What is the thermostat delete?
its in the cooler line of the transmission, quick dirty fix is to take it out, and turn it upside down so its always open, or you can research it more and buy a kit that removes it completly.  stock trans temp is 200 F if not higher,  removed the t-stat and  it brings you down to 130-150 F, so your reliability of the trans is increased by at least a factor of 2X
  • Thanks 1
Interesting but since it is under warranty--I have a feeling GM wouldn't like the idea and may say since it was changed they can't warranty it.
I purchased my 2018 Chevy Silverado brand new in 2019. A year  later,  w/30,000 miles,  the  truck has the “Chevy Shakes.” The vibration/shimmering over certain speeds(50 +MPH) is unbearable. After doing some research I found I am not alone in this area. I have contacted an attorney and will wait to see how they handle this issue. UNACCEPTABLE!!!!
Just purchased a 2017 Chevy Silverado Z71 Redline edition with the 6.2 ltr (31K miles on it-certified) I bought the truck on 05-23-20 and am experiencing the vibration issues as described in this forum. It is intermittent and I am really worried I am going to get stuck with the nightmare that I can't wake up from. Due to the Memorial day holiday weekend, my credit union has not transferred the money yet. I have emailed the loan officer I was pre-approved from and have instructed him not to transfer the money until they have fixed the issues. I immediately notified the dealership of the issues (withing 24 hours of buying the truck) and got a call back this morning from the salesman. He states" those vibration issues are normal for those trucks, but we can fix it. You are certified and under warranty so you can take it to any Chevy store but we can take care of it". I have read countless stories on here of people having the issues under warranty just like me and either the dealers are performing band aid fixes that aren't permanent or dealer service departments are putting their hands up after multiple attempts to repair and stating "it is a normal amount of shake, deal with it".  Hard to image on JD power has the 2017 Chevy Silverado 1500 rated 4.5 out 5 reliability rating with this BS going on.
Suggestions on how to proceed?  My plan is to get something in writing from the dealership that protects me from them just stating "we think the shake is withing tolerance, we are done trying to repair it". I want to tell them I am not going to authorize my lender to release the money for purchase until you have fixed the truck but I am not sure my lender is going to go along with that. I purchased the truck in Missouri which does not have a 3 day return law so that sucks. I can always go the lemon law route as I do believe the shake does substantially affect the value of the vehicle but that sounds like a pain in the ass
Any help would be appreciated, never fails everything is built like ****** these days.
Edited by Bryan Glenn
LOl guys says it normal, its not. And they wont fix it its been discussed here to no end and there isnt a pinpoint solution. I think there was several guys here that had the engine shimmed, different drive shafts, rear end rebuilt and several sets of different tires and they still had some vibration.  Good luck with it, thats one of the few problems with them. Honestly, Id cancel the deal.  I had countless problems with my 2014
Edited by Pinnacle
If you can get out of the deal DO IT They cant fix it and they will give up on you I have been thru it Find one that does not vibrate
Good news, dealership just agreed to unwind the deal and take the truck back. Shame, love the power and feel of the truck (aside from the vibration issues). Good luck to everyone.
Anyone have any idea what truck out there is truly reliable. I feel like I can google transmission nightmares with everything but the Tundras.
Thanks
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
