If the truck had been sitting for days before your test drive, it could just be tire flat spotting. Take the truck for an extended test drive and if still shaking after tire balance. Run, don't walk from the truck.
12 hours ago, Severado said:
Run away and don't look back.
Sent from my SM-G950U1 using Tapatalk
I agree.  I LOVED my 2016, it was beautiful inside and out.  But, after 50k miles it got so bad that it made me worry for future safety and I upgraded to the new 2019.  They're beautiful trucks, I miss mine, but don't miss the worry and the shake!
"Run away" might be good advice, ya just never know.  Sometimes my '16 Silverado with only about 30K miles on it will be smooth riding on the highway at 70-75 for 20 minutes or more.  Then the vibes will start.  Then sometimes it will vibrate as soon as I get on the highway.  Stealer man says the truck is fine, normal LOL.
I'll say this, if I were in the market for a used truck I would not by a 2014 - 2018 GM.  Too many are jinxed.
I would be cautious , but its a good bargaining leverage tool if its an 8 speed.  I have a 2016 with no vibes and Its got the 6 speed which seems to be the most reliable and oldest trans design.
since most 8 speeds need new torque converters , i would bet this is the main source of driveline vibration and NOT out of balanced tires or drive shafts, its the Bad TC , tell him to take $2000 off the price and take it to a good trans shop
Edited by flyingfool
I just put Falken Wildpeak AT’s on and they balanced way better than my duratracs ever would. I also had the new trans fluid put in my 8 speed for free from the dealer. This truck is the smoothest it has ever been.
i still think the Torque converters are causing all the vibrations in these trucks, I wonder if the new body style  still gets vibration complaints, if not  check the part numbers for the new model years torque converter, I bet it's been updated..
I dont believe the wheels, tires axles or drive shafts are out of balance. GM knows more but doesnt want to say cause the cost to fix an updated torque converter would be huge across all the K2xx trucks
I agree. I'm sure GMs army of engineers know what causes the shakes and like you believe the cost to correct the problem is why GM is thumbing their nose at us/those with shakers.  Great way to do business... fuk yer customers...
As far as comfort, I have my seat and steering wheel dialed in pretty well and it's nice'n comfy (other than the shake).  The one thing that does bug me though is the damn black cloth upholstery in the Silverado.  That's all I've seen, unless you upgrade to a truck with leather.  That trim level wasn't in my budget when I bought my '16 and likely will not be in the future. In fact, GM might not be in my future due to their shitty attitude towards the customer.
  • 1 month later...
I don’t have time to read all 842 pages on this thread. But I have an 18 5.3, 8 speed that only vibrates while towing my trailer, at around 74-78mph. Should I take it to the dealer or just deal with it? Only reason I’m hesitant to take it to the dealer is bc I’m hauling with it pretty frequently right now
If that's the only time you have noticable vibrations, congrats ... you don't have the shake. Have the dealer triple flush the transmission fluid and change the filter. Fill with Mobil One or whatever new fluid they have for it. My '15 had the shake. My '18 doesn't. Any vibes I experience now are tire and surface related. I'll address the tires in about 10k more miles and get the same transmission service I suggested to you shortly before/after.
My 2cents
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
