Nope, Just calling it like I see it. Thanks!
Same here....
I guess this is GMs way of doing a little damage control. Lol, what a joke!!
yep, its such a fake transparent attempt to deceive its comical really, but then what else can they do, they are not "really" trying to fix this, they are just bidding their time until they can sell off all the 14's and 15's and then move on to a different design for the 16's
Edited by keakar
I am a GSM for a Chevrolet/Subaru/Chrysler dealership. After going away from Chevy back in 09 to Ram I was tired of the poor quality control and just picked up a 15 Rally 2 Edition. I did a dealer trade as we didn't have one in stock, and drove an LT ext cab Chevy down. That truck rode like a dream. No vibes, shakes, nothing. Perfect.
I hop in mine and head back and what do you know, the dreaded vibes. It generally happens between 60-75 but has occured as low as 50 on random occasions. As with others here, it is not consistent (changes based on throttle input, load, etc). It's the worst a cruising speed though and can shake very bad through the wheel. I bring it back and have my shop do a road force balance which accomplishes nothing.
I ended up calling our dealer Chevy tech line today to see what they had to say and they mentioned they lowered the road force balance limit from 25 to 15. I doubt that's going to change anything but it's worth noting. He also mentioned that there have been quite a few rear ends replaced due to excessive lash that they felt were contributing to the vibration. That certainly seems plausible as it changes depending on load which could definitely point to that as a potential culprit.
kchaggins ... I have driven a '99 Silverado LT extended cab 5.3 3.42 Z-71 for 14 years and 300,000 miles... still own it and still rides like a dream. Replaced it with a new 2014 Silverado LT Double Cab 5.3 3.08 gears Z-71 and wish I never did. This truck shimmies, shakes, vibrates all the issues you see on these post. GM has "looked" at it more than several times, and found it to be 'driving as designed'. IF this is true, GM design engineers should be fired.
As a side note, I am starting to think some of the vibrations are coming from the transfer case. When switching into 4 Wheel Auto (at high speeds), there is gear noise and a high pitched "whining" that is very noticeable.
Either way, this could be an excellent truck. The vibrations just need to be figured out!
Thanks.
Editing post. I disabled AFM (v4) a few days ago and after my morning commute today I can surely confirm I still get the random skakes at higher speeds that come and go. The vibration I was feeling in the gas petal I thought at first seemed less intense with AFM off but after today I don't think it is. I also feel a steering wheel vibration more so than I did before my truck was in for service last week. Seems like maybe them remounting and rebalancing the tire could have made it worse. Somewhat frustrating. Does this amount of weights in the wheels fall into the normal range? attachicon.gif20150609_074813-1.jpg
I have 9 weights on the left rear wheel of my truck after a road force balance.
I have had my road forced balance but the tires and rims were never broke down.
I actually have a wheel that has 4 weights on the outside edge and 1 weight 180 degrees opposite on the inside edge, I was always under the assumption that weights should not be directly opposite each other
It looks like that's a total of 2.25 ounces which isn't too much, just looks like a lot because there is such a long strip. I believe anything under 3oz a wheel is pretty good, obviously the lower the better.
Actually, it's completely possible to need weights opposite each other when doing a proper dynamic (2 plane) balance. The machine measures the unbalance at 2 separate planes, in this case, the inside bead and outside bead. There can absolutely be unbalance 180 degrees apart, especially with cast metal like aluminum or definitely in rubber compounds like tires. In castings, porosity can form during the casting process. This results in air bubbles or voids, which of course are lighter then the base material. And hence, and unbalance presents itself. And, nothing to prevent the same thing from happening 180 degrees on the other plane. And when you add the tire to the wheel, well all hell can break loose!
That said, it certainly speaks to the quality of the tire, the wheel, and/or the balance machine operator. Because, there is also the possibility that the wheel had some unbalance on the outside bead and the tire some on the inside bead (as it was mounted). A proper sequence in Road Force balancing would actually detect that, and have the tire swapped around and mounted such as to cancel the wheels outer bead imbalance. At least as much as it could. And the rest, by weights.
So, there is more to it.
Mine was indeed a bent rim. Had to have happened before I bought it. I don't remember hitting anything that would have impacted it that much. Smooth riding now!
About 200 miles on new Firestones, brought it back in for shaking on highway. Wheels were allegedly taken off rims, re mounted and re balanced. Only took city roads home so unable to tell if the shaking is prevalent yet....I'm not optimistic.
Sent from my iPhone
Truck still in the shop they put brand new Goodyear sra still didn't fix it. Now putting all new shocks
I have a 2015 4x4 Silverardo 1500 regular cab, 8 ft bed with just over 2k miles now. Just after 500 miles, I started to notice a vibration right at 70mph. At 65 didn't notice at all, and at 75, started going away.
Brought to dealer here and they Load balanced and found two bad tires from factory. They replaced and I'd say 75% of the vibration has gone away. Thus making it shall I say less offensive.
Wade
How so? There is 5, 10, 30, 35 and 40oz weights, how do you come up with 2.25 oz?? He didnt specify what type he has on there. 3oz is excessive.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
