So the second Sierra we drove was worse than the first. Both driven at highway speeds and immediately noticeable. This is going to be a fun new adventure.
does that mean your not taking a replacement?
On to dealership No. 2 - third test drive in a 2015 Sierra today - result: vibration. Going to try one more and then I don't know. We have to see with GM what they want to do. But we can't afford to pay them 4k to have them buy back the vehicle.
Just curious, I wonder how much all of you that went and traded in brand new trucks, what was your loss? I had a 2014 Ram and unfortunately did not like it enough to keep. TIA!
When it was all said and done I Was out just a tad over $200 .00. And remember GM had my Silverado
for almost two months and put on over a 1,000 miles.
I got my Ram before I settled with GM, as I needed a truck. I went from a basic W/T 1 with a few goodies and
quite a few aftermarket items I could not remove because GM could not find a truck that did not vibrate.
MSRP to MSRP I ended up with a Ram Tradesman with all of the equipment as a LT Silverado for roughly
$3,800 less and ended up buying it for much less as the truck already had a 90 day floor plan on it.
Are you making note as to what tires are on the GMCs?
All 20" goodyears. They are all Sierra SLTs. On to the fourth Truck.
Interesting, Wranglers are listed as the original equipment on Silverado's but one of the things done to mine was replacing Wranglers with Eagles.
Try test driving one with 22" bridgestones.
My buddy has one with 22's and bridgestones. I'll try getting with him and take it for a test drive and see if it vibrates
SLT's should all come with Goodyear wrangler SR-A. They are literally the cheapest tire you can buy in 275/55r20 that isn't some off brand Chinese manufacturer.
Edited by projectsummit
And the ones that GM buys from Goodyear are even cheaper... Apparently the OE tires are sub-standard to retail tires I've heard before from 3-4 different tire stores :dunno: . I'm having to wait over a week to get a full new set of tires from a "different supplier". They should be in tomorrow, I informed the service manager that I will not accept or sign for the truck until I'm satisfied.
I'd believe this! my SR-A's were very cheaply made, they had little rubber pieces sticking out of them all over the place as if the rubber mold used to make them wasn't tight enough. I've noticed also that the older version of the SR-A's with white side walls seemed to be much better quality.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
