A independent mechanic drove my truck and felt the shimmy shake!
Monday they going to check drive shaft and go from there. I remember Gm truck member RT’s words. “It’s the drive-shaft”!
we will see, I would be so happy if this is the case for my truck. Will post with results.
One thing i did come across when i was fixing my truck was a shop called TCS transmissions .
One guy that worked there had a 2016 sierra 1500 same as mine and had the "shake" .
He said there were a couple parts in the transmission (6l80e) that were garbage and that they caused the vibration .
He reportedly replaced said parts rebuilt his trans and put in some upgraded parts and there was 0 shake after .
Update on my vibratio, shimmy shaker.
Drive shaft out and u joints are spent. Spin balance tomorrow. The mechanic thinks my issue could be  faulty seizing u joints. But will balance anyway.
Test drive tomorrow.
*success*
spin balance driveshaft
new ujoints
alignment!
Such a relief!
large.01DA6C0C-D530-417D-BE02-13BA261200DA.jpeg.fb77fd1bb8b1dce67653bec6a1db54ef.jpeglarge.586AD5F9-3592-47DB-BE5A-0688DCB0A858.jpeg.a67c5633e04a69ecd8c192aa8ed59b7f.jpeg
Edited by Gofas
Edit photo
Hope that leads to a solution to your vibes.  Maybe it will, maybe not.  So many guys here have spent their hard earned cash on their new to almost new trucks, replacing so many parts on these fk'n trucks for only a slight improvement or most often no improvement/solution at all.  There doesn't seem to be a fix, at least that we know of.  Although a few I believe did win LOL.  The fk'rs at GM know what the fix is, but they ain't say'n.  Sure am glad we bailed them out.
I have been complaining bout my truck for most of it life and it’s vibes and shake at hi speed. Sick of no help from you know who I finally brought it to a independent mechanic and they figured it out in one quick test drive on the hwy.
and in my case it was faulty Ujoints on either side of the drive shaft. I have 70k on my truck now.
this is a cheap and easy parts swap so why not try it.  Several dealers the last years had no clue. no clue!  Notice cup of liquid in the video, that was my case as well. The faster I went the road the more it was evident.  I had lots of drive shaft clunk which I was told by dealer that it was normal.
Taking drive-shaft off to spin balance we found the joints to be bad.
I shared this info with local dealer. He pointed my before after alignment specs where in range in that paper.  But even tho, it took shake out at 72 on up. And driveshaft was the vibe that got worse 65 or so and up.  I am getting great  mpg’s Even with how I am driving fast all time!
* update it still drives good!*
Edited by Gofas
The rage!
I have a 2017 Silverado LTZ Z71 with 17,500 miles.  I recently started experiencing very similar rumble strip type vibration at freeway speeds.  It happens intermittently when going up a slight grade and/or gently depressing the accelerator.   I was driving up a steep grade recently and it shook violently - like somebody was rocking the vehicle side to side.  I checked 2X2 position, downshifted to M3, and still rocked - although slightly less violently.  It also seemed to lose power.
Does anybody experience rumble strips type vibration in the steering wheel at highway speed AND when driven it up a steep grade experience a violent rocking of the vehicle?
Was it resolved and if so how?
First time the dealer did a wheel balance - I had not yet experienced the issue with steep grade which obviously would not be a balance issue.  They said most of the issue was mostly resolved and to drive it for a while.  It was not any better.  Since then, I experienced the steep grade  violent shaking experience.  Something is seriously wrong.  I cannot trust the vehicle to drive over a hill much less tow something uphill.  Now it is back at the shop as I write this.  They called saying no problem could be found.  After explaining again and pleading my case, they asked me to authorized an extensive test drive overnight.  They say GM has nothing on this type of issue.
The first step will be getting the dealer to admit there is an issue.
Thanks for any help pointing me in the right direction.
Edited by docjsb
Mine just started... There is a GM Service Bulletin on how the dealers are suppose diagnose/trouble shoot the issues.  Several fixes, just depends on what vibration is occurring.  I did do a search on "rumble" on the thread and some lucky persons corrected the issue with transmission flush.  Still doing research...
It appears GMC Service Bulletin 16-NA-175 for the transmission shake / shimmy / rumble / shudder is only for the 8 speed transmissions. I have the 6-speed.
Does anyone have experience with the 6-speed?  Does the tranny flush help?
Took my 2016 Silverado Double-Cab 4x4 (65K miles) in this morning for the infamous "shake".  Driving home from taking my daughter to college on Sunday it got so bad I had to stop to make sure I didn't have a loose tire or something.  Long story short, dealer said the Torque Converter has failed, it needs to be replace along with several other parts (know issue with a TSB).  Issue is they have another truck with the same issue that has been waiting several weeks for parts.  My dealer has been great, providing a loaner, etc.  My frustration is with GM, they have a known problem and parts are on an extended back order.  Dealer said its covered under my Certified Pre-Owned 100K powertrain warranty, however I won't have "my truck" for several weeks.  Filed a complaint with GM they said a Senior Advisor will get back to me and my dealership if they are able to help.  I have been a Dodge guy all my life, bought the Silverado in June of 17 with 18K miles, based on this experience guess I will have to look at other brands for my next truck.  Sorry to vent.
Don’t be sorry about venting, all of us have been there. I have owned 4 gm trucks in the last 10 years and 3 of the 4 have had major problems. Just bought a 19 after having a shaking 14 and my 19 has been in the shop for two weeks with 700 miles on it for other problems. Not sure why I’ve stayed loyal but definitely going to a different brand with the next truck, and most likely will be trading my new one in within the next few months. Don’t know how gm keeps putting out garbage and still has customers.
For some reason mine started only after the brake recall fix. If you are calling rumble strip the same thing as the lines on the shoulder to let you know you're veering out of your lane then yes. With 87K on my 2017 Sierra I am wondering why it only started recently. Other than that the only issue with my truck is the same as everyone else POS 8-speed .
Damn the 19 has issues too? Not a good sign at all. Although I'm dissapointed with my current 8 speed, I was hoping the 10 speed would be fine and have had my eyes on an AT4; however, based on the F-150 class action lawsuit on the 10-speed and the fact that GM and Ford collaborated on that, it's just a matter of time before GM owners start experiencing the same clunky shifting, hesitation that apparently is plaguing the new F-150.
Guess after this its time for my 3rd Nissan Titan.....lowest selling truck, but now that they're making a sunroof again I'll be ok with them.
'16 Sierra Denali 6.2 8 spd, shook from day 1 brand new. I accounted it to the 22in wheel and tires. Shook between 40-60 mph on the freeway.
  Got a new '20 Sierra Denali 6.2 10 spd w/22in wheels and tires and it rides SO much smoother. Have not experienced the shaking.
Well, I too have a similar situation with mine...2018, 47,000 miles, owned since new, 6 speed. It doesn’t like hills on the highway; if I hit a hill going slow it’ll stutter and shudder it’s way up that hill. I now have to hit hills just right, with some speed and heavy throttle, otherwise I’ll get a shudder from the tranny. I did get a check engine light once - cylinder five misfire - but everything checked out and it quickly went out.
I have done two transmission services to this truck since new. Truck has been babied since day one...all highway miles. Not sure if it’s the torque converter or what...starting to think I made a mistake buying this thing.
I have a 2012 gmc sierra 1500 sle... took it to the mechanic for vibration issues at idle no matter what gear its in. He replaced the plugs and wires, maf sensor, fuel pump and hanger for the fuel tank. He also said the ac belt needed to be replaced and have the original gm gas cap put on which I'll do myself. The vibration is still there so my question is, will the ac belt cause vibration if its getting worn out since it's on the crankshaft?
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
