I had my dealer fix the seat movement issue and the fix lasted for about 2 weeks. It is now worse than it was when I brought it in...
Update...I just took the time to actually look at the fix and noticed the tab on the new retainer clip had popped out of place. It looks like it is going to keep happening so I am going to resort to the hose clamp fix.
Do you guy's not read the posts in this thread? Why don't you just do the clamp method fix and be done with it? No dealers, no down time and you don't have to worry about it being worse than before you brought it to the dealer. There's countless posts of members who have brought their trucks back to the dealer several times for this. Save yourself time, trouble and aggravation.
I agree, there are 51 pages of this mess, and I'm one of the dummies, that tried to let dealer fix and ended up with a ding in my left rear door at the dealer, did the hose clamp over a year ago and no more problems, and if it ever loosen up, I'll just retighten ........................I like ..............DIY
Edited by myunclepapa
The "seat slop" issue got me about eight weeks ago. I waited a couple weeks of never remembering to call my local dealer during working hours but, once I called, they set up an appointment for the following week. When I dropped it off mid day, mine was the second vehicle of the day to have the issue. They did dig into it and found the lower seat frame needed to be replaced. Took about 2 weeks to get the parts in and then they replaced it.
The seat is great now. Sure, I need to remove a plastic trim piece and install it properly but, at least my seat is fixed. The dealer didn't mess around with clips, shims, or any other sort of work around, they went right to the actual issue and replaced the faulty part instead of trying to band aid it.
Edited by Hozer
They didn't give me too many details about the diagnosis but I'd heard of the clips as an unsuccessful fix so I was just glad when they acknowledged something was faulty and actually needed to be replaced.
Is there a bulletin # for the seat on a 2014 GMC Sierra Crew cab?
Ok here we go again. Please read the posts in the thread. There is a bulletin but people have brought their trucks back to the dealers several times for this with no success and ended up using the clamps. Save yourself time, headache, aggravation, a dinged up door, seat poorly put back together and most times being worse than before it was brought to the dealer. DO THE HOSE CLAMP FIX.
Got my done at the dealer...they went by the bulletin and resolved it..so far so good almost 3 weeks now.....
You can "Do it yourself" and hoseclamp to your hearts content... but if the lower seat needs replacing, it needs replacing. The hose clamp won't work because the problem is the clip you have your hose clamp up against is broken. Instead of being able to replace that plastic clip, they have to replace the seat frame. You can usually tell if the clip is broken by lifting up on the seat, one side will go up quite a bit further than the other.
For what it's worth, I did the hose clamp fix on mine and about once a month the issue would return. Took it into a dealer once and problem solved for good. Had it on there for a while now and no issues. I understand people doing the DIY route as I did myself, but if there's a fix for a known issue, why not get it done? If for whatever reason it doesn't work then you should probably find another dealer.
The dealer did the hose clamp fix. It only works temporarily. The seat will eventually start moving again on you, they are poorly/cheaply made. The dealers generally suck about it. It looks like the seat issues will ALWAYS come back unless they replace the frame. How many people have this problem and the dealers have said it's normal? It's incredibly aggravating to drive with the seat moving around and the dealer saying it's normal -- the back and forth with the dealer.
I had the hose clamp in place, lasted about a month or two before it started slipping. Tried to tighten, but would still slip. Went to the dealer for a recall (15304) fix and asked them to change oil and take a look at the seat. They acknowledged the seat issue and the svc mgr said they have a fix, but it doesn't always work. At least he was being honest. They performed PI1183A http://oemdtc.com/12126/front-seat-lateral-movement-andor-click-type-noise-while-driving-2014-chevrolet-silverado-gmc-sierra
Seems solid so far, only time will tell if I need to go back to the hose clamps. Svc mgr said he could order new tracks but he is supposed to perform PI1183A first, and to let him know if it starts slipping again. Appears to be a newer than PI1376. Didn't see any shims mentioned and I do see that black-ish plastic retainer that's in the last picture of the instructions linked above.
Is anyone having trouble with the later '15's or is this just a '14 issue?
My '15 started doing it after around 2000 miles, brought it back to dealer and they fixed it changing the retainer clips, and some lubrication as per the bulletin. After all the reading I did about it, I was worried about the fix working but it seems to be just fine, no movement or noises....been a few thousand miles now
For those of you who have (in the opinion of others) "wasted" there time on a dealer fix for this problem, only to have it come back again. Here is a permanent fix. What is happening is the dealer installed retainer clip is popping out of the white seat hinge which is allowing the seat to move again. By installing a hose clamp around the retainer clip it will not allow it to pop out and it will still allow full range of motion on the seat.
A 2" hose clamp and 5 minutes should take care of the problem FOREVER!! (I hope)
*EDIT* After looking closer at post #762 above, it appears the dealer was supposed to install a zip tie around the retainer clip to keep it in place. In my case...they didn't...hence the need for the hose clamp.
Edited by tvette1993
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
