i just dont see many catastrophic engine failures, and the chance is so slim, i'm sure i could social engineer GM into believing when the engine died it fried the ecu and gave it a wrong CVN code calculation. I do software development, and while it doesn't lie, there are many bugs and sometimes things just don't work right. It isn't as easy as flashed yes or no.
I would be interested in learning more about it though, sounds like chris white knows pretty well, but he seems to be a busy man.
The was a member Newn I think had an engine problem. It turned out to be a lifter, they claimed at first they saw a tune or something and harassed him for a while. They later relented and finally fix it. The point is I don't think there are many people that know what they are looking at when they are looking at the dealers. When it come to can tunes they dont run up to the edge like some custom tuners can. So when it comes to a can tune on a gas engine that's not S/C or T/C I cant see them really putting up much of a fight, unless there is a hole in the piston, maybe. Now the transmission and TM maybe. On my Hypertech can tune the trans hits pretty hard to the point that I put some TM back in. On the engine the 15 HP on 93, I left it alone, I get 25 HP on E85. So I can see where the can tune people would jump in and help a buyer on an engine deal they just aren't really putting a hurt on the engine anybody can see that.
yea but whats funny is some dealers actually sell tuners to fix things like wheel size. its pretty hypocritical, and if you look at diesel forums, everyone runs a tune. its kinda like anything in life, some people get screwed while some get everything with a smile. i usually have no problem with returns, exchanges, warranty, or even awesome deals.
I took my truck to the dealer for the recall updates and oil changes etc. they fixed the unwated transfer case into neutral and the peek in odomoter display one. Im winderin if they do updates like that while i habe my tune on if it erases the tune and puts the factory one back on? Cuz it shifts a little smoother and not clunking on low speeds now
Depends which diesel forums you read.
So I've read this thread back like 15 pages but I couldn't find an answer.
I own a 14' CCSB 5.3, I want better throttle response and for the truck to be a bit quicker. I would like to avoid self tuners since I don't want to invest over $1,000 for software and some dyno time at a tuner shop so I'm looking specifically into boxed tuners. From what I've read the Diablo tuners seem to be pretty popular, could I get some feedback from members who own either the Trinity or the In-Tune?
Also what are the main differences between the T-1000 and i-1000? The T-1000 is $529 vs $339. According to both product pages they both offer the same "20hp/25trq Performance" tune and the same adjustable perimeters.
Edited by WendysOrBust
boxed tune on the diablosport i1000 totally sucked. i could tell it shifted different and drove different, but not 400 dollars different. i purchased mine used for 200, so i didn't feel too worried about the money i was out.
after a week i got a custom tune from diablew and it was like a whole new truck. so all of this is to say get a custom tune if you get the diablosport.
What are the steps and process for getting a custom tune on a dialosport? Also what is the price?
5.3 or 6.2?
Does anyone know what computer the flash counter is in? Is the ECM, TCM or the BCM? My guess is it wouldn't be in ECM as if people are cracking into it to tune the motor they would get to the point of cracking the counter and tuning it to stay or at least be able to set it to where it was before you flashed a tune into it.
From what I understand both the ECM/TCM has flash counters in them.
Why can't new ecm's be used like on previous trucks?
Edited by BBRU
Just as tiger posted and for the very reason you want to use another ECM. I can promise you, GM engineers read these forums and find out every trick we know and implement ways to stop those tricks on the new vehicles.
on the new 2014 trucks the dealer can only program the truck the exact way that truck with that VIN came from the factory as, no more making changes after the fact with mods on the 2014+ vehicles.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
