How much is the BB tune vs. Diablo tune? I went on BB.com and it was for $900?? Seems very high for a computer tune. Is it something thats plug and play? Or does it take a long time to set up the tune myself?
Its about $600 for the Autocal. You can for the most part do it yourself to get files and logs. They do the actual tuning through email. Worth the $600 and time.
Chris is correct, $599 for the AutoCal. You must have been looking at the V2 which is $899.
Sent from my fone.
I did the BB EFILive Autocal for $600: http://store.blackbearperformance.com/EFILive-AutoCal-Tuning-System_p_8.html
Worth every penny.
Here is the process:
1) Order and receive the Autocal tool. 2-3 days shipping
2) Install software onto your computer that connects to the Autocal device
3) Plug device into your truck. Activate recording. Drive for 30 minutes to record your trucks shifting and details.
4) Use device to record engine and tranny config files (detailed instructions on site)
5) Email files to Blackbear along with requests (disable AFM, faster shift points, etc)
6) 2-4 business days later you will receive new tune files. Copy files to your device, plug device back into truck, and reflash the engine and tranny config (very easy)
From ordering to having your first drive with a new tune took me about 2 weeks. For $600, the change in how the tranny and engine perform in phenomenal.
Edited by Haus_Z71
Purchased a Diablo, be here in a few days. Hopefully do the trick for this rooky. Couldn't see spending the $600 beans, maybe down the road turn to BB.
I had the DiabloSport tune on my 2005 and now on my 2014 for a year now. Pretty happy with it. Not knocking BB because I've heard nothing but good about them but since you now own the DiabloSport tuner you can always save some money and get a custom DiabLew tune from Lew later on.
Got mine tuned today :)
Truck specs and tune please :-)
Oh sorry didn't see it in the lower corner of the image.
Edited by mjj
No worries man. It's a 2015 Sierra 1500 SLT 6.2 with Max trailering (3.42)
I'm unsure of the tuning program they used. They did my last truck and I was wicked impressed.
Josh
I tuned mine last night with the Diablo Intune and it makes a heck of a difference!!!!!!
I don't have mine yet, but did you select a specific tune for yours?
I used the Diablo flex tune and I currently have a tank of 93 in it can't wait to put some e85 in her
I also use the Diablo 91/flex tune. I keep AFM on, drove with it off for a month this summer and lost 1mpg. I have the throttle boost setting (I think that's what it's called) set at +6. For the transmission tune (TCM) I use the hard shift setting and I have torque management turned off. I've also been using E85 almost exclusively since I've bought the truck. Almost 20k miles on it and for a canned tune I've been happy with it, truck shifts better, more seat of the pants as they say feeling during acceleration, no complaints.
Is the Torque Management just on/off or do you get a slider? Sadly EFI Live they can't adjust it just turn it on or off. I'm curious if they are just doing the same thing EFI Live does by not letting the timing retard as much on shift. If that is the case, its pretty bad on the Tranny. I've been debating at some point possibly getting HP Tuners since you can actually adjust Tq Management.
I am also curious of this setting?
Read this whole thread, and I guess the consensus about the warranty deal is don't sweat it and just tune it. I've made my mind up to go with Black Bear's Autocal.
I was wondering if weather conditions, mainly temperature can make a difference when you do the data logging. Is there an optimum temperature range for doing this, or doesn't it matter.
    • I did shorter OCI"s for many years without an issue, fights sludge and wear IMO. Recently started using Amsoil, will not do the recommended/advertised miles between changes.
    • It definitely seems quite evident that emissions and fuel economy targets rule above the best case scenario of what the engines best health and life could be otherwise. Items like DI and turbo DI engines with their LSPI issues as well as cats being reduced in life if the proper levels of certain additives were allowed to be utilized and so something has to be compromised and as you point out that is the engine protection from sludge, acid and wear which isn't in the manufactures best interest regardless to worry about in this race to profits from higher sales and so if the engines wear out sooner the next sale is closer at hand.    I am hearing that its likely the two new 2027 GM half ton truck engines will call for a 0W-30 oil, now if that is an existing oil I would have to think so but we will see in the coming months. Sadly as you've pointed out to me, over the last number of years the push has been on to reduce the actual operating temperature viscosity within each designated viscosity grade so that 11.5 to 12 range for a 30 weight for example is more in that just above 10 range at 100c along with that temporary viscosity sheer dropping it even further down as per that "energy conserving" designation, not to mention how some oils are not as sheer stable as would be ideal and that mixed with a long OCI paints a picture with a little too much glitter shall we say !.    All that and the warranty gods scaring the vehicle owner into sticking with that watery wine or risk loosing their warranty coverage if they go and use an oil that is of a higher viscosity even if it meets the emissions and LSPI requirements and would never damage the engine but may very well allow for an engines longer life depending on engine use scenarios ... high ambient temps, towing etc that push oils to their limits.
    • Very true.   However.  GM did give those trucks with the single speed case Terrain Mode.  Terrain Mode mimics 4LO minus the gear reduction and torque capability.  It uses the ABS/braking system to perform the operation.  It also gives these one pedal driving (sort of) when in Terrain Mode via the active brake during throttle lift.     Does it have its limitations over a true 2 speed case?  Sure.  But it works.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
