6 hours ago, truckguy82 said:
I’m pretty sure most of that is from modification of torque management, not the power increase.
I believe that.  I really notice the amount of power my ECM pulls during shifts in my '18, and the amount of time that power is pulled seems overly excessive.
That being said, I don't know if I would completely get rid of TM during part throttle shifts.  If I was concerned about the best WOT performance I could get out my truck, I would only reduce or eliminate TM at WOT.  But I think leaving it stock or lightly reduced at part throttle would probably promote transmission longevity.
Has anyone every tried getting a 2014 truck updated with a 2018 truck tune? I have a 2014 and often rent 2018/2019 trucks for work. They sure seem to be a little snappier and get better mileage than mine. I assume the 2014 tune is very conservative. I don't really want to do an aftermarket tune. I have done programmers, mail order, and custom tunes in the past with mixed results. Most aftermarket tunes don't work well in -40 weather.
Jimmy, your 2014 truck uses a 12692067 part number E92 ECM (or a different/older part number that has been superseded by 12692067).  The AC Delco online parts catalog says the 12692067 E92 ECM was used in 2014-2016 GM trucks (as well as some other vehicles in that similar year range).  2017 trucks got a newer E92A ECM, p/n: 12692068; and 2018 trucks got an even newer E92B ECM, p/n: 12692069.  I do not think your 2014 E92 ECM will accept programming written for an E92B ECM; but even if it did - there is a question of whether the other computer modules in your truck (especially the TCM in the trans) will work correctly with 2018 programming in the ECM.  While the TCM in your trans may accept 2018 programming, I doubt every other module in your truck will accept the same; and my concern is there may be compatibility issues with your IPC, BCM, and other modules in your 2014 truck.
I am curious as to why you say most aftermarket tunes don't work well in -40 weather.  What issues are you experiencing in -40 weather with the aftermarket tunes you've tried?
Edited by SinisterZ71
Good to know Sinister. Maybe a 2016 is as new as I could do. Its seems every first model year chev is a little more tame and conservative than the few years that follow.
I have had issues with cold start enrichment in various temperatures. Really hot and really cold. Rough ideal, poor starting, mild shaking, a bit of black smoke on startup. Also some odd shifting characteristings when doing heavy duty towing. Little stuff but still important to me. I have tune 5 other vehicles that I have owned previously.
I would like to know if the tune for the 2016's is better or different than the 2014 trucks. Surely some of the dyno tuner guys would know this. They probably get the best gains on 2014's.
2016 tunes have a different OS (operating system) than 2014 uses, so I'm not able to directly compare the two tunes within the custom tuning software I use.  But just looking at the main spark tables between a 2014 L83 pickup and a 2016 L83 Tahoe (I don't have a stock 2016 pickup file on hand to look at), I can tell you there are significant differences between these two tunes - and that's just in the main spark table.  Now keep in mind that your 2014 engine may not like the 2016 timing maps because of differences in exhaust or induction systems between the two years and such.  So I wouldn't just plug the timing table values from a 2016 tune into your 2014 tune and run them without at least keeping an eye on scan data to make sure you weren't getting any KR (ie: giving the engine too much timing advance where it can't use it).
Wow Sinister, that is some specialized information I would never have been able to get otherwise. That does partially legitimize my opinions on the poor 2014 tune. Could the 2015 even be better and more compatible?
The 2015 L83 pickup tune I have appears to have identical timing advance values to the 2016 L83 Tahoe tune.
I should note that while the 2015 and 2016 L83 tunes I have show the engine being given more timing advance at light loads, these also have LESS timing advance at heavier loads than the 2014 tune I have.  So running a 2015 or 2016 spark map with your engine may result in a loss of performance.  The difference in the heavier load portion of the main spark table is about 2.5 deg (meaning your 2014 engine is being given about 2.5 deg more timing advance than the newer engines were).  Interesting...
I’m looking into tuning and didn’t read a single page but this one, what do you think the reason is for GM to be retarding the timing on 2016’s?
i have an autocal from my duramax, I need to unlink it from ATP trucks, and give the info to blackbear, but I don’t have a laptop at the moment, I’d have to get a charger and battery . I know how to scan and load tunes on the efi live programs.
Is the Diablo i3  just as good or comparable with their canned stuff? I know it’s not as customized..I mainly want to hold gears longer, not be in 6th going 40mph around town, be lugging at 900rpms and in 4cyl. But I want more response, afm off, less tq mngmt,  firmer shifts, 93octane. Just wake it up and maybe get a little more juice out of it, I know the gains aren’t much on the dyno but the ass dyno, it’s night and day.
Truck is stock, I’m getting a corsa catback, keeping the stock intake which breaths fine, cai’s are a waste of money if you have no other mods done to the motor, longtubes with high flows are in the future after my tuning, no forced induction or cams in my plans, if I were to get into my motor I’d go with a supercharger.
Is going blackbear worth it for my uses over a diablo i3? Looking for real responses from people. From what I know myself, efi is the way to go, but I think with my mild case, diablo would be fine. Conundrum...
price difference isn’t shit because I have a autocal already.
Dude, custom tune.
if you had cold weather issues with your other tunes it was just a coincidence.
I’ve driven nearly every year and every motor of k2xx, they all feel the same.
a custom tune is night and day. The lazy throttle is the torque management. Nothing to do with ignition or fuel tables.
12 hours ago, truckguy82 said:
Dude, custom tune.
Custom tuning is night and day but you have to find someone who knows the gen V platform. My lazy throttle is almost completely gone and I have left torque management 100% stock.
My transmission also shifts a lot better and I haven't adjusted shift time or pressures yet.
Messing with torque management too much can ruin the transmission fast in these trucks.
There is a table in the ECM tune that basically sets up the throttle map.  It's called the Driver Demand Power vs. MPH. vs. Pedal Position table.  Basically what this table controls is the amount of actual throttle blade opening allowed per accelerator pedal position based on vehicle speed.  And the stock settings are very progressive (only allowing a smaller percentage of throttle blade opening at low acceleration pedal positions than what it does at higher accel pedal positions).  Think of this is GM's way of making sure customer's don't accelerate too quickly from a dead stop with low accelerator pedal applications.  Of course, this makes the engine feel like the throttle response is soggy.  Note that even with the stock settings, you're still being allowed full throttle blade opening when you apply full pedal, so you aren't actually losing any power output (unless traction control is kicking in, of course).
I revised this table in my truck to wake throttle response back up but it had a side-effect; the transmission seemed like it shifted too early at low accelerator pedal applications.  So I had to make some changes to my part throttle shift points to compensate as well.  But after doing that, I would say it was a drastic improvement in throttle response feel.  Gone was the usual lazy characteristics the truck had when trying to drive it easy.
There is also a tip-in torque limiting function which is controlled by a separate table which can be turned off as well.  I think this only kicks in if you are really driving aggressively and stabbing the throttle a lot.  I turned it off in mine and didn't notice much of a change, but I don't beat the living daylights out of my truck either.
I have an intune i3 8200 that I used to program my 2014 gmc.  Since I sold it, I reverted the truck to stock to unlock the tuner.  I gave it to my brother in law to use on his 2018 Silverado with a 5.3.  The tuner said it was incompatible with his truck tho.  Diablo lists this unit as compatible from 1999-2018.   Any thoughts?  Thanks.
We use EFILIve exclusively for tuning, but the compatibility issue might be because of the 17 and newer vehicles enhanced security, 8 and 10 speed transmission lock and so on. We tune with the AutoCal and all you would do is re configure it for the vehicle your going to use it on.  Are you able to re configure the diablosport?
So after reading about 600 posts in this thread, I sent Lew an email asking some questions, and will probably make the purchase at the end of the week for a diablew tune. There’s a lot of good info in this thread.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
