Finally got my garage/workshop situated in a way that all I have to do is move my main workbench (on wheels) behind my table saw on the other side to get the truck inside so I can work on it late at night without being interrupted or bugging the neighbors.
It's great having a garage to work in - and park in, especially during inclement weather! Your set up looks good.
On 6/30/2019 at 2:01 PM, Marv88 said:
 It's not in the manual for the twk or vxi however I called JL and found you can in fact manipulate the software to perform that function like on the Mosconi dsp's. I'll post the process if you like when I get it done.
That would be awesome, thanks
Thanks and I agree it's great to be able to work inside!
Haven't had a chance to do it yet but Ill let you know as soon as I do.
Shined it up with the Jay Leno car care products I received for Father's Day. I've used lots of different products over the years with varying results and have to say so far I'm pretty impressed with his stuff (especially the tire and trim dressing)
Oops!
Edited by Marv88
I received a full set of floor mats for a double cab by accident from GM and they told me to keep them so I used the rear ones with zip ties to cover the "echo chamber" under the dash (this improves midrange clarity when you have kick panel or low door mounted mids).
Latest Audio upgrade is installing the Mercury Audio components I received from @Nasty . Most have probably not heard of this brand and neither had I until Nasty brought them to my attention. The company is out of Thailand and I was a little skeptical not having heard of them however they seem to win a lot on the Asian car audio competition circuit so I figured I'd give them a try.
This time around I used the Metra 6x9 adapters lined with Sound Skins deadener, made a recessed 13mm birch mounting plate to flush mount the mids and sealed front and back with foam weather stripping. Tweeters are installed in the stock dash location surrounded by thick foam.
Build quality as well as packaging are excellent IMO and I have about 25 hours of break in time so they are pretty well loosened up now. System is factory iob 7" headunit and JL Audio twk88 dsp running these active through a JL audio xd700/5v2 5 channel amplifier.
It was hard to find info online (the translated video I watched was difficult to follow with the thick accent of the narrator) and no manual or specs so I was basically flying by the seat of my pants. After much experimenting with crossover points along with basic phase/level adjustments and no eq'ing yet I find these to be an excellent sounding set of speakers "right out of the box".  Midrange is very natural sounding as I like it,  midbass is very articulate and easily keeps up with the fastest bass lines, soft dome tweeters are very detailed without any harshness even firing off the windshield and I'm sure they will be even better once I fine tune.  I like them better than the highly regarded Alpine SPX PRO's I previously had installed  and IMO they can compare favorably with many of the upper end speakers found on the market here as well as several "boutique" brands I have used.
  • 6 months later...
Got bored the other night during this shelter in place and built yet another subwoofer enclosure from a combination of 13mm and 18mm Baltic Birch plywood to scale from an actual Bowtie emblem. 709205017_2020-03-2917_42_08.thumb.jpg.7c5409a6ce45fc440d82ac531b6e27f1.jpg
  • 9 months later...
Haven’t done much to the truck in a  while other than install reverse, cargo, license plate LED bulbs and changed a few things in the audio system.
I previously did the diode mod to have the cargo lights come on in reverse but that didn’t help much with seeing behind at night while backing up however the LED bulbs made a huge difference.
I previously had the JL 13tw5 installed in an enclosure that spanned the entire rear wall but that was way more bass than I needed and I wanted to add a little more storage so I went back to my very first plan which was building a platform across the rear wall.
I used nutserts and rubber isolators to mount it to the rear wall at the top. I made a little mounting tab to use the jack tools mounting stud at the bottom and fashioned a little bracket to use another isolator mounted to the seatbelt mechanism stud.
Edited by Marv88
I kept the Mercury Audio components I got from Brandon aka Nasty here (RIP my brother ?) and was planning to use the Bowtie enclosure above with the ARC Audio ARC Series 8” but by going to the platform I found the passenger seat wouldn’t go back far enough and the jump seat would not open all the way so I just built a basic wedge from Baltic Birch plywood for behind the passenger seat.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
