Stabilitrak
Could you just unplug the "Yaw" (pitch) sensor and keep ABS? it used to be behind the cab on the GMT9's. That sensor is what detects the truck's sideways movement.
  • Replies 49
I have done the steering sensor unplug as mentioned earlier, that works for disabling stabilitrak only i.e. Traction control & ABS still function as normal.
Sent from my Moto Z2 Play using Tapatalk
2 hours ago, Mozzer said:
It says at the bottom of the page that turns off ABS as well
Yeah that button goes through the wheel speed sensor which would also disable ABS.  I like the steering wheel sensor option.  I may wire in a hidden switch so I can leave the plug plugged in and disable at will.
That's what I was looking to do but there are three or four wires on the plug so would either need a multiple throw switch or need to know if one is power/signal etc that can be switched to disable.
Oh gotcha.  I havent crawled under to look at it yet.  How easy is it to reach? Like, can I reach down and unplug while driving, or does it have to be a conscious decision before getting in?
Quite a small plug & above my shins right on the bottom of steering column so I wouldn't fancy messing with while driving.
Is everyone talking about the stabilitrak you can disable by holding down the traction control button after you disable traction control?
Literally you press the button once, it disabled traction control.
then you hold the button for 3-5 seconds and it disables stabilitrak.
At least it does in my truck.
Yes, the same one that comes back on automatically when you hit 35mph.
So, you're driving along, thinking you have turned Stabilitrak off, because you have.  You expect your truck to behave accordingly.  But, you inadvertently exceeded 35 mph since the last stoplight, and then nannies come and unexpectedly shut your fun down.  The unexpected intervention causes the driver to be startled, overreact, and crash, and die.  Ok, I'm exaggerating a bit at the end there, but I think you get my point.
gotcha, I live in FL so i never have to disable it unless in trying to play in the rain. Thanks for the info.
Yeah, I never notice it in the summer but in the winter on the logging roads here sometimes you can drive for 30 miles before finding a plowed turn around, so it is nice to disable Stabilitrak, floor the truck and spin around on the road. The only problem is Stabilitrak usually kicks at 90 degrees of your 180 degree turn. Now you are 7-point turning around between 2 snowbanks. All because GM knows how we should drive better than we do. I like the feature when I want it on, but when I select off, I want it off plain and simple. Can you imagine the freak-outs if you had this same issue on the Camaro or a Corvette? Another issue is that young kids learning to drive in these vehicles will never learn how to properly react to a slide or skid. if  they ever jump in a 98 1500 on winter roads they are going to kill someone.
They'll do enough damage in the Walmart parking lot after growing up with a self parking car [emoji51]
Just did mine! So the steering is lighter and less feedback. But not toooo bad.
d1c27d651f9aa6b9d3e9a4a86c27cddc.jpg5d62b4e77ccf9d38a8ec35f05966e85f.jpg2617280286addbc76122cad2ad725e9a.jpg
I too despise the permanent stability control.  There are situations, not just the fun ones, when drivers need all avaliable power.
I wonder if pulling that steering position sensor could adversely affect the operation of the SAB system.  The yaw sensor must communicate with both of them.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
