You can properly balance a tire all you want but if it is a crappy tire it will always be a crappy tire and will require more weight to get it to balance. The flaw with the truck is that it is too sensitive to any thing that may cause a vibration which is every moving part on the vehicle. It is what it is and good luck on your buy back.
I complete agree, I had my 2015 crew cab in for the vibration and they found two tires were out of spec and couldnt be balanced properly so they replaced them... and it only cost me $198 to get 2 new tires on a truck with 15k miles. Has anybody else had to pay for their tires they had to have replaced? They were even going to make me pay for the balancing. AND GUESS WHAT, it still vibrates! have another appoint for tomorrow.
I've gotten 3 out of the 4 replaced on GMs dime. I haven't had to pay for anything and it's at the dealer on it's 7th vibration related visit. 18,xxx miles.
Get your money back then find a new dealer.
I would never pay out of my own pocket for any part while the truck is covered under warranty, including tires. Get your money back and tell them what you think of their shady way of doing business.
I had a 22" Bridgestone tire replaced, it did help to reduce the vibration, but did not eliminate it. it was replaced under warranty
just dropped the truck off for the final repair attempt, after having to argue about getting a loaner. They finally got me a rental Dodge Journey from Enterprise.... good enough. however, because they took so long to get back to me after receiving the letter, they only have until Wednesday to fix the truck 100% and they won't even start until tomorrow since the service department closes at 6:00. Keep ya posted
How quickly didn't you notice the vibration and how bad was it?
Who said that Ford Rangers were built in Mexico? I believe all were built in St.Paul, MN.
filing a complaint at nhtsa.gov is a good step to take - this will shed some light on the scope of the issue & possibly bring a better response for others as well.
knowing your state's lemon laws is another good idea as certain guidelines must be followed to retain rights = proper notification, trying arbitration?, filing legal action...
being polite to all involved goes a long way to maintaining respect & helping to ensure a good outcome for all...
my 2015 suburban has been vibrating for some time. working with the local dealer has been interesting & hopefully will produce a good outcome to further the brand.
our first (2004) suburban did not vibrate and had 168,000 miles when we found a new happy home for it. the tires were never road force balanced & we bought replacements (stor brand) from pep boys.
not sure why our 2015 suburban is vibrating and hopefully a solution will be found - soon:)
i believe gm will do the right thing for owners, eventually.
I have:
-5 completed repair attempts, and am on the 6th and final attempt
-Called GM atleast 5 times
-Provided dealers with information I have found and posted here, as well as taken information posted here
-Filed a complaint with the NTHSA
-Contacted attorneys and the Massachusetts Attorney General about all of the conditions
-Been to 2 different dealers, one of which I will NEVER go to again
-Never once yelled or even raised my voice at any GM employee, well maybe one, but he was just a service adviser at the dealer I wont go back to, and it was because he was trying to argue with me about the radio losing the mids and highs, and the shake that they "could not replicate" being normal to the vehicle. then he had the balls to tell me to drive in "M5" to help reduce the vibration from the AFM (which is what really set me off).
I now have a huge binder full of all of the information I have collected and all of my repair history
I agree that:
-Filing complaints anywhere and everywhere you can will only help your case
-You should learn everything you can about your states Lemon Law, the rights you have, the procedure to retain your qualification etc.
-Document EVERYTHING (take notes of any and all conversations, if you have emails - print them, print all published articles and TSB's posted, keep all of your service and loaner documents etc.)
-If you can, avoid the BBB as an arbitrator, Businesses pay the BBB to use their name and logo for advertising purposes, they are not a government agency and are paid for by businesses
-Be Persistent, remember, the squeaky wheel gets the grease. call and call and call some more. get repair attempt after repair attempt until something is done
Unfortunately for all of you, I do NOT agree that GM will ever admit to the problem, or some up with a resolution.
I'll keep everyone updated as my final repair attempt/ buyback/ whatever it ends up as proceeds
I see a lot of people stating they went the lemon law route. For those of you that went that route, how was the outcome?
MY truck has been at dealer for a week. They have now ruled out tires and drive shaft. Last week they changed two rear shocks as one was leaking and other was weeping. Still vibrates. They thought they had it fixed after breaking tires down and doing a road force balancing, but when I went for a drive with service manager he even indicated that at 120 km/h he could fell it in his chest even. They are not denying I have an issue at all, but sure is frustrating. I have a rental, a 2016 silverado quad cab. Does not vibrate a bit. Makes me feel even worse about my truck because I am sure they are not going to be able to fix it.
I said that and I was partly wrong, they built a bunch in Argentina.
If the '16 doesn't vibrate that means it CAN be fixed, since it's "the same truck" with... something... different that has fixed that. At least, that's my hope. My '14 vibrates at 70+ BAD and has done it for 40,000 miles. Posts like yours, that document what has been changed and what has/hasn't worked are very helpful. Keep us updated!
Today they are checking the pinion. ( I believe) hoping to have an update later today. The rental has 10,000 kms on it. Mine was vibing at 4000kms so...thats a good sign ;)
I started going the Lemon Law route in my state (Georgia) and once I started asking the dealership questions regarding information needed, they mysteriously were willing to do a swap from my 2015 LT to a 2016 LTZ. There is a little vibration in the steering wheel as the truck reaches 73 mph, but after less than 10 seconds, it seems to dampen itself out and even though the speed and road conditions don't change, the vibration disappears. I will say that the 2016 that I have has restored my love for the truck.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
