I know 3 is a small sample size but what, if any, differences are there in configuration of the three ? All Z71 ? Or all CC ? All 4x4 ?
All crew cabs. The 14 is a 2wd chevy LT. The 2 15's are both GMC crewcab 4x4 SLT. mine is a z71 my buddys is a max tow with the 9.76 rear end.
Another update: I got my truck back this past Thursday. When the driver dropped it off he told me he had it up to 85mph and it was smooth.
I THINK ITS FIXED!!! I waited until today to post as I wanted to drive it several times. The dealer replaced my ring and pinion {rear end} and then put on new tires and wheels. I drove it several times on the interstate, max speed of 83mph and it was smooth. My 14 year old said "wow this is what is should feel like. Very excited right now and hope it doesn't return. Only issue now is they put black wall tires on and I like white letter. They are going to correct it this week.
I don't want to publish the name on my dealer on here but if anyone else's dealer is unable to fix their truck I will be glad to give you the name of my dealer and the service managers name so your dealer can, if they wish too, contact them. Want to help others hopefully get their trucks fixed. If I can be of any assistance please let me know.
A full rear axle replacement [brake rotor to brake rotor] eliminated the vibrations in my Yukon as well. Mine were not nearly as bad as some of the videos I have seen in this thread.
My dealership also replaced several tires and getting them to RF balance under 15lbs eliminated the 'buffeting' that many of us have reported in the Yukon/Tahoe/Suburban thread.
The last noise was the "booming" that could be heard when driving over bumps and snow/gravel covered roads. This was resolved by welding 6 dampers to the exhaust.
Nice to see another one get fixed.
Glad to hear yours is fixed as well. Mine was fixed with the ring and pinion and new tires all the way around at 25000 miles. I just turned over 40,500 yesterday.
I test drove a 2016 today and it had a noticeable vibration at any speed above 40mph. The odometer had 4 miles on it and it's build date was in February, so I'm hoping it's just from flat spots or out of balance tires from sitting so long. I asked if they could rebalance them or swap the tires with another truck on the lot, and I will re-test drive. We'll see what they do. The 8-speed shifted fine though from any speed or gear.
It's not the tires. this has been mentioned many times on this forum. Try another truck instead?
In my case it was the tires, unless other parts start losing their tolerances and the truck starts to vibrate again
You are one of the lucky ones then. In my case, and many other postings on here many also concluded it was not the tires. In my case, they replaced all four tires. It still vibrated. Then they Road forced and had to replace one of the new ones they just installed. Yes, when they replaced and RFB's the tires, the vibration was better, but it time, the vibration came back. I still have a vibrator. Been a GM guy all me life, but I think I may need to bend over and get a Ford. I cringe when I say this!
GM seems to be dragging their feet with getting me the updated trade assist letter.... last week i git an email saying they would get in out in the next couple days. its now over a week later and still no letter. they have been using fedex 2 day, so I don't know whats going on.... getting really annoyed and thinking they may be playing games until I can no longer file lemon law
The Chevy dealers are not charging for all the time and work spent in the shop, correct? What if you purchase the truck used and the issue shows up? Is it still under warranty to where they will still try all the above mentioned troubleshooting?
I would say run and try another brand instead. To me, this game of finding a truck that does not vibrate and hoping that the vibration does not start around 2500 miles, would be acceptable if they were giving them away free.
I had question for you guys. I was watching YouTube on the vibration issue and I'm sure you know there are tons of videos. I came across this one. Seems like just another of many "who thought this design was good" engineering. I drive usually 20 min a day on the highway and don't seem to have a severe vibration like some. I drove from Mass to Fl and back (3k miles) and was fully aware it vibs. I do have it though at the same speeds as everyone else and a resonance, low hum I guess, associated with it. My friend has a bone stock Silverado that he said shook severely and had the tires rfb and that fixed it. I've already tried the clamps on the rear springs which may be hookus pookus but seems to have slightly helped but gonna try my hand at the rfb.
My question..has anyone seen this or tried this and able comment on it...video below
Sent from my Nexus 6P using Tapatalk
Edited by Jeff5347
Something all should look at is the transfer case. On mine sitting and idling it has quite a bit of shake. With the transfer case hanging off the transmission with no brackets attaching it, could this be our vibration issue? The case has spots for mounting brackets but nothing's attached. Just an observation I've seen on my truck. I have the E brake cables rubbing on the body mounts and they are cut pretty good with 8000 miles on truck. My rear end is noises as well. I just completed a tire rotation and my truck is actually 10x worse than it was before.
Well add me to the list I guess. Just bought a 16 crewcab Z71 LT on Friday and had vibes on the highway on the drive home. Brought it back next day, they did RFB and tire rotation. Didn't help much.
So picked it up today, after 3 hours in the shop. Was told it drives 100 times better now. I asked what the problem was, turns out that 3 of the tires were about 5 psi too high. That's actually what they told me. That the over inflation "made me feel every bump in the road" and that the Z71 package is stiffer. I guess the Z71 also has the drink mixing feature as well.
At any rate I am going to get documentation of the first two visits and take the tech out for a ride tomorrow. Wish me luck.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
