I just wanted to post that the hose clamp fix worked for me too, and my seat had some pretty good movement in it before it. Very surprised it was such a simple fix!
Edited by RBSilvy85
If you are running with the seat all the way down then it will rock front to back. I found this on mine after the really tall service tech drove it and 4 trips trying to get them to fix it. It will also sink if not raised far enough. The problem is in the 4 link seat suspension, if it is too low the links do not have the mechanical advantage to keep the seat from rocking back and forth.
Does this issue only affect manual seats or does it apply to the 10-way adjustable, too? Just curious.
I believe it only affects the power seat option. Mine is power, not sure if it is 8 or 10-way though.
I just his clamped mine and said f it
Do you have a picture so I can see where you are clamping it? I have the same issue.
I also just clamped my 2016 (Ya my 2016 still had the seat shifting and clunk issue) and it worked like a champ! No more shift, the seat stays in place when making a turn. #JUSTCLAMPIT
Do you have a picture of where you clamped it? I am having the same issue.
I broke down after dealing with the movement for the last 8-10 months and had the dealer check it out today. Started doing a lot of squeaking here the last week or two along with more noticeable movement side to side and front to back and I was fed up. They said they had to order a new frame and it will be in sometime tomorrow. Not sure how long this fix will hold up as I have fallen way behind on reading this thread; and don't know of anyone else has went this route. I imagine if it uses the same parts everyone is replacing with the hose clamps, then not long.
-Skeet
Awesome work here guys! I've been trying for the last month figuring out what was moving in my seat. Came across this thread. Didn't believe this was going to fix it...but it seems to have! My dealer thought I was going crazy and why would this be that big of a deal. I told them this $53,000 brand new truck felt like sh!t driving it (also the tranny is really annoying as well). Many thanks guys for figuring this out!
Most Dealer service "ADVISORS" are pretty well trained to try to deflect any warranty claims. I had the seat track replaced on my 2014 at around 5000 miles due to seat movement issues. It started doing it again at around 61000 miles and 2.5 years later and I traded it in for 2016 Denali 6.2 problem solved "SO FAR"
I have purchased a 2016 Sierra SLT and only had for a month and a few weeks ago i have started experiencing this exact movement clunk sound when turning corners. Anybody have any luck with the dealerships solving this issue?
I have not brought the truck in yet but would like to arm myself with some information before I go. I know how much the dealership is unwilling to admit when there is an issue.
Very disappointing considering the price of these vehicles and the fact this issue is still happening.
I am in Canada but that shouldn't make a difference.
Edited by Darrin89
If you'd read this thread, the cheapest, easiest fix that works is the hose clamp fix. You don't need the rubber underneath the clamp though. Many have insisted in going back to the dealer with the problem only returning. The clamp fix is the permanent solution. Save yourself time, headache and aggravation from the dealer.
Well I am gonna see at least what the dealer says. I also have a friend who is a GM mechanic and going to get some inside info on any bulletins issued.
To each his own. This is what I'm trying to tell you. The TSB they have for the seat doesn't last. They practically take your seat apart and some who have had it done say it became worse after the dealer fixed it. This thread has the TSB listed. Just trying to help bud and save you hassle. You can fix it for $2 and it will never move again. But if you feel you need to go to the dealer then get you some :dunno:
I really only noticed seat cover movement and had that worked on under warranty. Said they secured it and had the seat cover move on the way home from dealership. They ended up replacing seat bottom cover. It does not seem to move as badly as original so far, but it does move. Anybody come up with a fix for that? I have looked at how it is mounted and really not much holding it from sliding out of place. Whole seat started moving, as others have described on here, only after seat cover was replaced. Going to try hose clamp fix.
I wanted to add a bit of info here. If I had a do over I would have tried the clamp fix and most likely lived happily ever after and maybe still been driving my 2014 SLT. However I decided to MAKE them fix it and right after they FIXED it with a new seat track the bottom seat heater quit working. Then the side of the leather on the bottom came lose at the threads (most likely from them messing with it) and they replaced that and then the seat cooling became intermittent AND THE BOTTOM HEATING WENT OUT AGAIN. Out of warranty of course so my suggestion is to try this simple fix before you allow the dealership monkeys to mess your truck up. Why take the chance on the monkey boys screwing other things up PUT THE CLAMPS ON MAN
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
