Thanks Grumpy. I had it done at the dealership but I think I'll take it to the tire/suspension shop in town to see what they say as I don't know enough to insist on something specific.
Get a before and after printout. Look at the last few post in my build thread to see what the Hunter reports looks like. Grumpy Bears 2015 Silverado 2WD Start getting a feel for what changes do what and how it feels driving. I'm very happy with mine.
Edited by Grumpy Bear
Thanks again Grumpy!
Still needs more low
Yeah I know and it will get there!
Marv if I read right you currently have a 3.25" back half drop, right? Did we adjust the pinion angle? If not, any vibration issues? Thanks. I really love this current stance.
That is correct Grumpy and I was told I shouldn't have to adjust the pinion angle with that small amount of lowering however I did end up with a low speed vibration that was cured with 2 degree wedges. I like the amount of rake I have right now but I do want to go a bit lower.
Glad your wife approves and you're welcome! My wife thought I was nuts when I started modifying a brand new truck but now she likes most of what I have done!
Same thing happened with me wife got pissed I lowered my truck. But now she drives it more than me you.can tell because my front valance is chewed up
My wife says mine is too high for her to drive!
Finally got around to installing the BedRug kit (actually its just sitting in there). Biggest benefit I have found so far is it no longer hurts my knees when I have to crawl around inside the bed however after a week the imprints from my hand truck are still clearly visible.
I wanted to get one but my problem is my cover leaks. It's a tonnopro loroll. It was cheap and the rug out of my 95 is prettymusty. Does your cover leak at all? I had good luck with the tri-roll from tonno pro but like the bed rails being visable
We had torrential rains the night I put the cover on and not a drop of water got inside the bed as I had read which is the main reason I wanted this type. Drag is there are 2 locks and you have to open the cover to open the tailgate which has quickly become tiresome so I am now considering a tri fold cover if I can find one that doesn't leak.
Edited by Marv88
Marv88, I like what you've done so far looks great!
Thanks!
    • I think the answer is it's a stock 5.7 Hemi with a 3.0L blower bolted onto it 😉   Practically, because a blower introduces a lot of high pressure, severe thermal stress, and extreme mechanical loads on an engine. Things still need a little time to seat and get used to moving under load.   Sarcastically, because it's a Stellantis/ 5.7 Hemi and those things need all the help they can get!!
    • It's been a little over three weeks since my second knee replacement.  I can now walk around the house without a walker or cane but still have a lot of healing ahead.  This morning I was able to bring a cup of coffee to my wife in bed.  A few days ago, this coffee would have ended up on the kitchen floor!  Knee replacement surgery is very common and will typically enhance the recipient's future quality of life. However, the recovery process can present significant challenges, pain and discomfort. I encourage anyone facing a recommended total knee replacement to welcome the opportunity.  Just be aware that your body may take several months to fully welcome the new parts!
    • The Germans basically didn't make the list. There aren't a lot of shade-tree mechanics who work on them in general. At some point the economic equation of keeping a car alive favors junking it. Anecdote/experience tells me this is the case versus actual bad engines/engineering. Not that there isn't any, but there are definitely notable excellent examples. The 2.0 diesels will go forever and ever if one keeps the car around it running. The 2.0 gas cars eventually wear out their turbos but the block below it is usually still solid as a rock. BMW inline 6's same thing. Mercedes diesels of yesteryear, not uncommon to see 250k out of those engines, easy.     Link to the synopsis of the study: https://www.iseecars.com/longest-lasting-cars-study
    • 0w20 is recommended in the Sequoia. 0w16 in the Highlander Hybrid.   I think you make a compelling case for both the quality and frequency of maintenance but I wouldn't go so far as to plot a linear relationship between longevity and oil weight 😉   The list is interesting and leaves me with some questions. The Silverado 1500 is 12.9% likely while the GMC Sierra 1500 is only 10.8% likely. Arguably, they're the same truck, so other factors must be influencing the outcome.   The Honda Odyssey ranks #12 at 13% likely. Great. Rest assured we'll never stop hearing about the dang thing LOL.   There's a bit of a spread between the 4Runner (32.9%) and Tacoma (25.3%). Both overlap on the same 4.0 for many years although the Tacoma used a 3.5 for the last 10-12ish. I wonder if that's related to use-case or if it's suggesting the 3.5 isn't quite as up to the task, or maybe something else fails mechanically.   Ram at 3.5% overall likely, but the Ram 3500 holds the top spot on the Heavy Duty Models at 39.7%. One might say the Cummins is a ringer and provides an unfair advantage. I don't think it's fair/accurate to pit the GM Fullsize 1500's in a list with HD's which are basically medium-duty wearing a 3500 badge.   The Tahoe and Suburban hold spots #15 and #8, respectively, on the longest lasting SUV's list. What's the difference? One's got a shorter butt, unless they're also counting the 2500/3500 Suburbans in those numbers.   The GMC Canyon gets a 1.4% increase over its twin brother Colorado. Why, because it's prettier?   SO many questions...
    • Have the aftermarket system removed an re-test.  Its pretty much the only way to know if there is still an issue that is the truck and not from that.
