1 minute ago, tanner709 said:
custom = cheap = lowest model available. it doesn't mean it was a custom built truck
I agree it is a piss poor decision to remove it, but that's why the truck was so cheap.
I'm personally more upset, or baffled there is no cd player in a 2019 truck. I understand CD is an "old" technology now, but they are still very present today.
I recognize that the custom model is a lower model, I wasn't interested in the majority of the upgrades that came with the LT. My thought is that storage in a console shouldn't be an "upgrade" it should be standard. For close to 40k out the door with the options I did select I find it unacceptable.
On 8/4/2019 at 8:23 PM, Chad's Trail Boss said:
Did my swap this weekend. It's so nice having the storage now in the arm rest. 5ec0b77004ec2a5c1c1e4e75e845ac0c.jpg57c97a4a6ea245f52ae688dcc54fd8f9.jpgbc4eb1157ea1dac8c8d263b8e57d1836.jpgc71fbe6745a48afbdbbc48af90090ece.jpg
Sent from my SM-G975U using Tapatalk
I suspect this is a stupid question but how did you get the cup holders/storage area on the floor?  The pictures on the Chevy website don't show it.  I was considering a 2020 SLE so I can have the 5.3/10-speed combo without a bunch of other features (and added cost) that I don't want but I don't know if I can live without the centre console.  However, what you have there looks like it would work for me.
Edited by Cpl_Punishment
Look back a few posts, he ordered it aftermarket, he posted a link for it.
41 minutes ago, Chad's Trail Boss said:
Yes, emoji3516.pngis what I bought!
You like it?  Fits there well?  Doesn't slide around on you or anything?
If you don't have the door to door floor mats it will fit fine without modification and the front part of it will go up under the dash.
It you have the door to door floor mats as I do, you will have to trim the bottom front half to get it to fit. No big deal.
Even just sitting on the rubber floor mat and up under the dash a bit mine hasn't moved.
It's great. I highly recommend.
On 3/12/2019 at 8:47 PM, dctackett10 said:
That middle console makes the truck look so smoother.  I’m waiting for something to.  I found one on eBay. But I’m not paying 800 dollars lol
I would trade you console out of my LT Trail Boss for a center seat?
