Or maybe the spring mounts were welded to the frame slightly off?
So my truck shudders during acceleration when towing. The dealer did a fix in the transmission pump bolt that was loose, that didn't fix it. Now the engineers are telling him that he needs to try a two degree shim between the leaf springs and the axle. He was told that some of the trucks had the leaf springs welded wrong which created the wrong angle on the rear-end. He took measurements from mine and a 2015 and sure enough my truck is off. They can shim all the way up to four degree according to GM. If that doesn't fix it the will try the next random fix. My feeling is they should be buying my truck back if my entire rear-end is welded on wrong.
OK just got my truck back. First took it in, they told me to drive 500 miles. Second time in, they found that 3 of the 4 stock tires were bad.
"Road Force balanced on tires LF LR RR all failed, LF ok, 13 LR 28 RR 24 LF 31 (im assuming the tech messed this up because he didn't mark which value was for the RF tire) replaced all 3 tires drove vehicle felt better still feel vibration in gas pedal as customer advised. Drove vehicle on drive hoise felt vibration swapped rear prop shafts from stock vehicle no change removed rear tires no change removed rear rotors no change called TAC instructed to measure backlash or rear ring and pinion if out of specs replace complete rear axle assembly removed rear axle cover measured backlash ranged from .007-.011 out of specs for runout ordered rear axle assembly through Partech TAC caseXX-XXXXXXXXXX Tim B 2.90 OLH for repairs and diag. Road force and and force match, checking rear axle runout and back lash between each tooth of rear axle. 2.9 OLH excessive labor and diagnosis. 5 days loaner and etc...etc..."
So that's word for word what was written on my copy of the service report.
The vibrations feel the same as when I dropped it off. Expected so, as all they did was install 3 new tires and get my new rims all dirty.
Parts should be in soon and I will provide another update once the rear end parts have been installed.
It very well can be the axle had the mounts welded on slightly off too. This explains why after they completely replaced my rear end and nothing happened... This might be like Nissan had back in 04-05 on the Titans. People have checked the angle though and said it was OK...?? Keep us posted on the shims... If it fixes it, please report back here.
Did Nissan take care of it?
4 WEEKS straight in the shop for a steering wheel vibration between 40-50mph and still no fix. Engineers now want to do do another vibration analysis this time mounting their tool under the truck not on the steering wheel where they did their 1st test 3 weeks ago. New rear end parts did nothing , RF balancing did nothing. My service dept is good at doing nothing. I am in Canada where we have no Lemon law just CAMVAP anyone else in Canada having issues. Owned truck 10 weeks been in shop for 5 weeks BRUTAL
I had exact say issue, had a vibration starting at 40mph to 55mph they did song and dance and sent me on my way! I went through camvap full buy back after they could not fix this shudder, shake, vibration. I referred to it always as a shake for legal reasons....
GM tried to deduct for mileage use, I did not agree to any loss on my part, I had my hearing with arbitrator and GM and allowed them one last attempt to fix which they could not fix. Full refund and left GM behind and bought a ecodiesel ram.
List all issues with your truck like radio signal loss, tranny ect.. when you apply for hearing.
hope this helps you some.
Also, had rear end replaced, 2x driveshafts, tires, also had steering noises from front right side while backing up with wheel turned to full right clunking sound like hammer hitting solid metal thunk sound.
In conclusion this shaking shuddering vibration problem I believed to be transmission/torque converter related.
Damn GM for not caring and treating me like sh*t while they sent me away with "preforming as designed" nothing else we can do.....!
Good luck to everyone. The dealer brought in a "field engineer" to look at mine. He lowered the tire pressure to 30 then took it for a ride with the vibe analyzer. Service Manager called to let me know that there would be no buy back, the vehicle is "operating as designed" and there was nothing else they could do for the truck. He did offer to let me trade in my truck on another Chevy. They all had some type of vibration and it would be at my expense........Don't know what else to do except take a hit on another brand. YAY
That, my friend, is the way GM does business, unless you are lucky enough to have the dealer on your side.
There is no reason for you to take a huge cash loss. Saying that all the trucks do it is NOT a defense in court.
1. Send GM a certified letter offering one last chance to repair your truck. Address to send to is in your warranty book.
2. At the same time, file a complaint with BBB Autoline. Look in my sig for a link.
3. Contact a lemon law attorney.
4. If GM wont repair your truck or buy it back, SUE THEM and MAKE them do it.
That's freakin terrible. BBB, lemon law, atty. Hey Eddie A. with Customer care, can you help this guy now???? If Customer care is so eager to help and ya'll are so sorry to hear of the problem forward all these complaints to Mrs. GM herself. Forward to upper management. Engineers??? Can you not do that??? Geez GM this is horrible! My truck doesn't vibrate but reading all this makes my stomach turn and GM is leaving a really bad taste. I'm really loosing confidence... Un F**I<**G believable!
GM cust care (oxymoron) reps? Useless fake apology wanks.
Yesterday I looked at some new GMC trucks on the local dealer's lot. I saw a new 2014 All Terrain crew cab with a $ 50k+ sticker and it did not have the sunroof or the navigation.
Even with the heftiest of discounts, you still will pay close to $ 45k for this truck once taxes and other fees are figured in. You would expect good quality for this kind of money. We already figured out where the problem is. GM produced a good design but dropped the ball on the manufacturing quality control which determines how each individual truck will behave. So buying one is a hit and miss proposition. You can get a good one or a lemon. Not a good gamble when paying this kind of money for it. This is why it is so inappropriate for those who have good trucks with few problems to attack those with legitimate complaints.
Edited by pm26
Hello Everyone,
We're here if you'd like us to look into your vibration concerns. We can certainly understand your frustrations with this situation. Please send us a private message referencing this thread if further assistance is needed. We'd be happy to help!
Kristen A.
GM Customer Care
Hello Everyone,
Kristen A.
GM Customer Care
Apparently you and the other customer reps don't care. If you or GM would care y'all would put more effort in the matter. Just coming on the forum and stating the same repetitive posts and being a 3rd party between the dealer and customer doesn't make these guys feel any better. Can't you see this? If you work for GM, why don't you send this link to the upper GM management and let them read these 3500 + posts and see how these customers feel about how GM is treating when buying a $40-$50K truck. Loyal GM customers are really hurt by what GM has done to them and how a fix hasn't been found for the shaken, vibrating trucks. Surly someone with GM cares somewhere but no one steps up to the plate. Customers are switching brands, the word is getting out, some have bought GM all their lives and will never buy another GM again. Professional grade? Really. It's really sad, pitiful, awful, and horrible what's going on here. Is this what GM wants? Do they care? Apparently not. Do they not care about all the customers wanting buy backs, filing lemon laws, BBB etc? Do you not have other contacts in the chain of command or upper management? You must have. This goes for all the customer care reps hanging around on the forum not just you. Does Mrs. Barra or Mr. Ammann really care about 237 pages of complaints??? How about Mrs. Davis with quality and customer experience? If you care and want to help please find the right person to fix this mess and web that GM has created. It would be nice for one of you reps to come on and say "I've forwarded these complaints to the proper management and will stay on it". When will the madness stop? GM won't be known as the leader but the shi****st in the auto industry. GM's bread and butter are Silverado/Sierra trucks. Not Caddi's and Vettes. Take care of the customers that took care of them and who believed in them. Just terrible GM!! Terrible....
Mrs. Barra's mission statement:
GM is driving to become the global industry leader in automotive design and technology, product quality and safety, customer care. Really???
  • Like 7
Go easy on Kristen. These "reps" are merely minimum wage employees hired to monitor the forums to help GM maintain an image of customer service. Go to the facebook page of any company and its the same thing. I dealt with this on Verizon FiOS's facebook page. Go to enough facebook pages or forums and you'll start seeing the same pattern of responses from these "reps." That's why all of these customer care responses are nearly identical. It's scripted. They're here to take and pass your information along to a dealer local to you. Or you can just contact GM and a dealer yourself and accomplish the same thing. But using these reps usually will open a case in your name starting the documentation process you'll need if you want a buy back, lemon law, or whatever so they can be helpful. Bottom line is they're not here to provide you with any answers. They're like the receptionist at an office and your problem lies with their boss (GM).
You should've looked underneath. For 45 g's I'll bet it comes complete with a rusty frame.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
