Whats the hose clamp trick?
Sent from my SM-G935P using Tapatalk
Really? Have you not read this thread?
Sent from my LG-V495 using Tapatalk
There is 946 posts, trying to be spared reading through 946 posts
look under your seat from the driver side footwell... put a piece of rubber (mine cut from rubber hose) and a hose clamp TIGHT to each side where the white "dodad gadget" is...
seat fixed!!!
seat fixed!!!
Thank you
Ok, lets do this.
First, acquire the retainer part. I got mine for $5.08 to the door.
For 2014-2015, just pop the retainer on the seat bar and put a zip tie around it like the last picture in the PIT5542 doc posted above (post #910).
For 2016+:
Use some painters tape to outline where you will cut to make the retainer look like the modded one from the GM doc:
You'll see the molded seam mentioned in the doc.
Clamp it lightly into a vice or hold it with vice grips. Either way, be sure that it is stable so you don't F yourself up. I used a towel around a small vice so as not to damage the retainer when clamping it:
Use a grinder or cutting tool or even a sharp pair of dykes or razor knife (Without cutting yourself. always cut away from your body). I used a small cutter wheel attachment in a drill:
At first, I wasn't sure if I was to cut only one side until I tried to put it on. The "welded" bracket tabs mentioned in the PIT5542 will most contact the rear of the retainer. Cut both sides the same way and trim away the slag.
I had to trim mine back a little bit after the initial cut as the retainer wouldn't sit flush. You'll know what looks right and what doesn't when you go to fit it on. Trim back little by little until it fits nice. Move your seat up or down until the retainer sits even with the white guide block (you'll know it when you see it).
Install a zip tie (I used two since they fit) and trim the tail(s).
That's all there is to it. I haven't had time to test it out yet, but that's the full GM dealer fix right there so if this doesn't work then we'll have to figure something else out. For me it was worth the five bucks and doing it myself so as not to waste time and have a dealer monkey crawl around my truck or have them tell me "couldn't replicate problem".
Cheers.
thanks for the post made it really simple quick fix parts from the dealer 3.23 finally fixed !!
Drop my 2016 off at the dealer for the second seat frame replacement in 18k miles.
UPDATE:
I dropped off the truck, dealer called me a few hours later giving a strange conflicting story about how the tech who replaced my original seat base "forgot to put the bolts back on, which is why it was rocking back and forth. We replaced the bolts and that tightened it right up". That makes absolutely no sense to me because after the original seat base was replaced, I had complete rock solid zero movement for a couple thousand miles. The forward rocking was a progressive sensation that got worse over time. The service writer also that tech was no longer employed there. Then, in a stumbling confused explanation he said the new tech on this job wasn't heavy enough to reproduce the 'complaint' so a heaver tech had to road test my truck. He said they drove a brand new truck off the lot and mine back to back and the seat rocking is normal expected movement from the power seat base. Wait....whaaaaat? The movement that I initially brought the truck in for, is unchanged from when I dropped it off. And when I initially brought up the second seat base movement issue during a regular service appointment, the service writer and tech both agreed the seat base was broken and needed to be replaced.
My service invoice says "TORE DRIVERS SEAT APART AND FOUND NO VISUAL EVIDENCE OF ANY CAUSE FOR CONCERN. TEST DROVE SEVERAL TIMES AND HAD SHOP FOREMAN RIDE IN TRUCK. COMPARED TRUCK TO ANOTHER NEW TRUCK ON OUR LOTAND BELIEVE THE MOVEMENT IN THE CUSTOMERS SEAT IS COMPARABLE TO ANOTHER TRUCK WITH AN AUTOMATIC SEAT. DO NOT FEEL AT THIS TIME TEHRE IS ANY REPAIRS TO BE MADE."
No mention of the missing bolts.
I also asked them to check my transmission. I am having frequent very hard downshifts with loud clunks. It downshifts so hard it throws you forward. I am also having hard up shifts with a harsh bang and lunge sensation. The service invoice was noted "CUSTOMER STATES THE TRANSMISSION SHIFTS HARD - ALMOST AS IF IT BANGS INTO GEAR - ANY UPDATES AVALABLE? - CHECK AND ADVISE"
"TEST DROVE SEVERAL TIMES AND BELIEVE THAT THE NOISES RELATED TO THE SHIFTING ARE NORMAL DRIVE LINE CLUNK. DID NOT FEEL THE TRUCK BANGED INTO ANY GEARS AND IT SHIFTER RATHER SMOOTH. COMPARED TO ANOTHER TRUCK ON THE LOT AND FELT THEY WERE DRIVING THE SAME. CHECKED AND THE TRANSMISSION HAD THE LATEST CALIBRATION AND THERE WERE NO TECHNICAL SERVICE BULLETINS. RELATED TO CUSTOMER'S CONCERN"
So there goes that. I am at the point where I feel it is time to start shopping for a different brand of truck.
***2nd update***
Seat movement has progressively gotten worse and I've had enough. So today I went to the dealer and without explaining why I was there, I got a sales consultant to show me a brand new Silverado. He seemed somewhat confused as to why I was only intrested in the driver seat so I explained why I was there. I drove the new truck and try to reproduce the seat movement. I asked him to watch the seat back for movement, it did not move. Then we went to my  I asked him to drive my truck, he opened the driver's door, grabbed the seat and moved it back and forth and said in in disbelief said "I don't even need to drive your truck this is not right and we're gonna make it right today." He went straight to the service manager and brought him out to the truck and show him what I was referring to by seat movement.
I drop my truck off next Tuesday they promised to have it fixed.
"No visual evidence of any cause for concern"....who the F was the tech???? Hellen Keller????
I didn't go back and read all of this thread, but there are updated parts available from GM to correct issues of seat moving side to side during slow speed turns.
There is also a bulletin on the issue.
Maybe this has been posted before.
#PIT5542 - Front Seat Lateral Movement
An updated seat frame design  that incorporates welded bracket  to the seat frame pivot bar on each side of the white block.  This helps reduce the excessive lateral seat movement.
Mine was doing the side-to-side movement everyday.
Since the PIT was applied  about 4 month ago the the problem has not recurred.
Yes, mine was doing the side to side movement and the dealer replaced the seat base frame. Then the forward/rearward movement started....
2016 1500 Silverado LT2 with 15,000miles equipped with leather power seat(s). Drivers seat bottom shifts side to side and makes noise when turning and also the back part of seat doesn't tilt up and down evenly. when i try to adjust the back (tilt forward or back) the rightside will tilt further forward or back until i tilt it all the way forward or upright than i have to tilt it backwards. it also seems where the back meets the bottom of seat the gap isn't even. i.e. ether the bottom part of seat is shifted or the back shifted.
before i go to the dealer and they tell me "we cant replicate the problem" or its normal (just like my shake @ idle- learned to deal with that one) i would like to know if i should be push for new seat or ask for a specific fix? i really dont care what they do as long as they can make it right.
any help appreciated. i tried to find the PSA but had no luck.
Edited by Maritime1
They most likely won't replace the entire seat, they replace the frame or install the replacement parts as stated in previous posts. I guess it depends on what the find or admit to finding.
My fix with the new P/N clip back on page 62 worked good for a few thousand miles, but started loosening up again like some predicted. I bought a #20 1 3/4'' hose clamp from Home Depot and put it around the GM clip and synched it down. Much tighter than the two plastic zip ties I had holding it in place before.
I'd have to image a GM clip and a hose clamp combo is the ultimate fix here apart from a redesigned seat frame.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
