1 hour ago, ltdmstr said:
Does anyone have a photo of this part (84647286)?  Just want to confirm it's the right thing before I order one as there's a 20% restock fee plus shipping costs if returned.
Sure the guys that have ordered will post them once they get their parts installed. Thanks to everyone figure this out, and taking the plunge on ordering the parks! Looking forward to the install photos.
Well, I want ahead and ordered the part anyway.  Will post photos when it arrives.  Also ordered the fog lamp kit (84125494).
what did each of these run you $?
YES PLEASE! TY
Where are the pic's for the arm rest.  Surely some one will share so we all can have it.
Please post.
I purchased the upper part of the armrest from the dealer for $490 Cdn$.  The bottom part apparently is multiple part and was super expensive (i think about $1000).
Anyways, it was a bit of work, but at least I have a bit of storage.  I can deal with that issue now.
You need to remove the driver seat and will require a T50 and T55 bit.
  • Like 5
1 minute ago, Brutus230 said:
Looks good.  DO you have all the part numbers you ordered to make this work.
Its that #8464-7286.
There are 5 clips that hold the two plastic side pieces on.  You could probably take the old ones out and use them, but I just got new ones.  Was worried that I would squish them. I'm a bit impatient sometimes.  The clips are #8426-3801 if you want.  They were $3.76 CDN.
I thought 84647286 is the top part.  and there was another for the bottom.  when I take the top off mine it fill of foam.
It is the entire upper section.  It includes the seatbelt. Here is the old one to see what you get.
Thanks I think this will help us all.  we all want to fix this terrible thing chevy has done.
I can deal with the other missing things, but the storage drove me insane.  Worth the money for my sanity.
Ok I just ordered it cant wait to have a normal truck.  Just got the fog light in and getting it flashed tomorrow so they work. Thanks for taking the time there not many helping.
Of course. It was a bit difficult to order the parts initially.  My dealer is good to me and sourced it out, basically just one from the LT models.  I would have liked to change the bottom section too, but they gave up once they started adding all the parts. Not worth that money.
Though about the fog lights. Let me know, maybe I'll do that someday..
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
