your posts prove otherwise
Thank you. Never touched that crap in my life.
So what is your advice for those who are serious about buying a new GM truck? Cross their fingers and hope that for $ 45k they will get a good truck that does not vibrate?
::shrugs:: life is about choices and risks.. There are no guarantees in life, there is just life. personally though, I no longer buy new.
Well another week without my truck :nonod:
It's not the Dealers problem it's a GM PROBLEM in three day's the GM engineer had spent
with my truck, I or the Service Director really have no clue as to what Mr. engineer
did or anything as far as an idea as to what's causing the vibration issue :mad:
[Violent rhetoric removed to ensure reader safety]
I just got my truck back on Monday, VIBRATION FREE!!! Ive put just over 150 more miles on it (760 on it now) and no problems. I will say my dealer had recognized a problem with the vehicle and kept me informed with how they were going to fix it. They had to put some mileage (60 miles approx.) on it to run the Vibration Analyzer on it, which didnt make me too happy. Im just glad they repaired it and did it whithin a reasonable time. I wasnt happy that this happened right out of the gate from purchasing the truck BUT Im glad they were able to FIND AND FIX the problem.
They ended up putting a new ring, pinion, bearings and yoke in the rear diff. The truck drives smooth as glass now and I couldnt be more happier. This is how a warranty repair should be done. Out of all the posts Ive seen on here Im surprised at how many people havent had the same luck as me. Im glad it didnt go the way so many here have had it. Thanks, H!
It has been 6 weeks in the shop and the dealer has run the list of parts. I filed another BBB claim 3 days ago and today I began negotiating a trade. If you get any BS from the dealer go on-line to the BBB. GM has responded within 2 days and both dealers involved have JUMPED on the issue.
My local dealer is now saying they won't trade outside their own network, another call from GM should fix that.
Their network? Tell them you want to trade for a Ford. Can you get a buy back so you can buy what you want where you want?
If the vibration does not return in the next 10k miles i will believe that they fixed it.
Edited by pm26
Hi Guys, I bought a 2014 Silverado double cab z71 back in June. I First noticed the vibration about 3 months ago but it was very slight. This was only around 45 mph. Now the vibration starts at 45mph and goes to about 65. I have my first appointment with the dealer next week to look at the issue. Does anyone think it could be the passenger rated good years that cause the problem? I have read on a few other forums that LT tires reduced if not fixed the vibration. Im tiring to gather up as much info as I can before I head to the dealer. Thanks for the help
yet you are here on this site making light of the problems these trucks have, so by your own admission you don't know what you are talking about.
simply amazing, lmao
Son, I've been comming to this site off and on since a few months after this place was created, I've been a member of this site thru 4 GM trucks i've purchased and owned, each with their own set of problems, GMT-800s, and GMT-900s, yet there is always someone like you who pops up every once in awhile and cries and cries and cries about how bad their issue is and all that crap about paying $40,000+ for a vehicle and blah blah blah. Was I happy when I had issues with my trucks? No. Was I mad at GM? Sure. But when everything was said and done, it was my choice to purchase the vehicle and accept the concequences of doing so. Having annoying little things that pop up that may not be easily repaired, or even repaired period is one of those concequences. The only thing I am making light of are the cry babies like you who keep on crying and crying and crying and crying foul this and foul that and woe is me and all that other stupid childish crap. Give it a rest already.
:nopity:
:nopity:
And, yet I've been a member since:
Colossus
Member Since 05 May 2014
mm hmm. If i told you some of my previous names the Mods would certainly recognize me and could vouch for that. But seriously! nice try!
:tear:
:tear:
Well congratulations on using multiple names.
  • Hold the drive pinion stationary and move the ring gear back and forth.
  • Repeat the measuring procedure at each tooth around the ring gear.
  • The difference between the backlash at all of the measuring points should not vary by more than 0.05 mm (0.002 in).
  • If the difference between the backlash at all of the measuring points varies by more than 0.05 mm (0.002 in), inspect for burrs, a distorted case flange or uneven bolting.
  • If the difference between all the measuring points is within specifications, the backlash at the minimum lash point measured should be 0.08-0.25 mm (0.003-0.010 in) with a preferred backlash of 0.13-0.18 mm (0.005-0.007 in).
Checked it last night, measured between .005-.007". Had 1 tooth that was right at .008", the rest were right at .007" or alittle less.
Thanks for the advice.
So, you dont even have a dog in this hunt then. No 2014 silverado with or without problems?
Just couldnt resist coming into this thread and sharing your dissenting, uninformed, opinion?
To what end? Argument? Conflict? Are you a troll?
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
