I had the tsb done on my 15 a month or two ago and it's been rock solid since. No movement at all. This is the tsb with the shim kit and the extra clamps (black) next to the white factory ones. Seems to working so far. I didn't have a bunch of left-right movement before, but it was there and i didnt want it to get worse.
So far so good.
Do you have a digital copy of the TSB?
I just got my truck back. they replaced (so they said) the actuator and adjusted rails and re-tighten the bolt on the seat. It doesn't make clicking noises any longer but we'll have to see how long this lasts.
Is this the fix for 2016's? Mine is doing it pretty bad. Well bad enough it is bothering the crap out of me. Is your seat still good?
The tech tried to use the same method on the 14's and 15's but that didn't apply to this so they tried this method. it's holding up so far. I've taken a 300 mile trip and there's no noise yet, doesn't mean it won't happen. It might take another 4000 miles before the symptoms creep up.
Edited by cs2016lt
I have alot of up and down movement of the bottom cushion. It rubs on the plastic trim as I drive over bumps. It makes a creak/ rub sound that I can feel. It is worse around the lane departure sensors in the driver seat. I can also feel it in the passenger seat if I push down on the bottom cushion.
Will the hose clamp thing fix this? Or is this another poor design flaw that the dealer will dismiss?
Had my 2014 repaired under warranty, they killed the seat heater doing the fix and the cooled portion of the seats never worked the same (as well) after the repair then it started shifting again after about a year. After about 4 trips back to the dealership monkeys I just gave up. Finally traded for a 2016 and it is doing well so far but disappointed to hear that some 2016 owners are having the issue. Come on GM its been almost 3 years since launch of the new platform lets get these bugs out man.
Jennifer, Is there a way for you to get in touch with someone who can tell us what the lead time for these seat assemblies is? I have a meeting with my dealer tomorrow morning and I am guessing that is the situation I will be in...waiting for a seat to be found. As a customer who currently owns the vehicle, I believe I should get preference over vehicles going down the line, but unfortunately GM already has my money and the ones on the line only earn them more, so I am likely lowest on their list.
In my personal opinion this is a big miss with GM due to the fact that this part is 100% related to the customer's experience, not to mention something that is fundamental to every car on the road today, so what makes this one so difficult to do correctly?
I am sick of feeling like I am sitting on a snow tube on a cold winter day as I go around corners in this truck. At first it was once or twice, now all the time, so there is a definite wear out mode here. The rear of the bottom portion of the seat just seems to clunk from side to side. I took a look under the seat to see if there was any noticeable slop in the bracket without digging too far, but I cant seem to find it. I can feel it and hear it under the seat, but cant seem to pinpoint the direct area.
I love the truck, but this experience is making me wish I would have never got rid of my 2011 Ford F150 ecoboost (which was a new model year also for all of you people that tend to use that as an excuse).
Has there been any resolve to this issue? I have had the same thing happen. The first time i had an issue they found a service bulletin on it and ordered what they called a rail? Supposedly it had welded points on it. This fixed the issue for a few months. I dont even drive the truck every day. It started again this fall. So far ive had it there 4 times. They just looked at it and said that everything is tight in there as. The part that they replaced is tight and not broke. Even the head guy of the dealership sat in it and drove it and I know him personally. He said he couldnt feel anything. On mine it doant do it all the time just periodically. Im about to tear into it myself.
Its so annoying and uncalled for with a truck that has a $50,000 price tag. I think my next truck will be a Toyota or Nissan with tje Cummins
I've recently started exp this issue on my 2016 Chevy, heard the fix is some kind of shim, but also read it's more like a temporary fix. The seat adjuster assembly had to be ordered and replaced. I will be taking it in to the dealer for popping/ seat moving around left, right, foward and backward. 2016 with 8k miles!!!
Just picked mine up from the dealer and it's fixed! Hopefully it lasts.
2016 with 5500 miles on it and the 10 way power drivers seat. Started doing it last year sometime.
The service dept knew exactly what it was when i stopped in to ask about it last week. I dropped it off at 9am today. They called at 10:30am and said they were waiting on parts still. Called me again at 1pm and it was done already. Just picked it up, no more seat noise.
Idk when the bulletin came out for it, but there is a bulletin for it. Pic of service paperwork below.
Second time in for the exact same problem... had my entire driver seat track replaced. Snug and solid now, no seat movement or clicking noise. Will this still be the case in six months or a year? "Clip fix" I had done first time around, didn't last a year before the problem re-appeared.
There's a document numbered PIT5542, (Don't think its a TSB) that corrects noises, movements, clunk/pop/clicks, It was performed on mine and corrected the issues I was having. They install GM Part# 13405675 along with modifying a bracket.
The dealership did whatever they did to my seat and now it's doing it again so... yeah. I'm gonna take it right back.
They did that on my 2015 at 6,700 miles. Since that time I had the clips poking me in the ass til the day I traded the vehicle. The seat didn't click but my rear was pinched pretty bad. I'll chalk it up to a dealership issue more than a vehicle issue?
Same issue on a 2016 with 4600 miles. Physically showed the tech after he couldn't hear/feel anything. Hour went by and they concluded they couldn't reproduce the results...
It's literally bad enough to move the seat with your hands pushing left and right at the base. I mentioned the PIT5542 document and he said that wasn't the correct format for their TSB.
He's going to research it and let me know if he finds anything...
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
