I made a post way back when on this thread, probably 6 to 8 months ago when the dealer fixed mine. It's been about 6000 miles since the fix I think, and the click is coming back now.
Just ordered a retainer off ebay...worth the $3 to not make a trip to the dealer. Thanks guys for the info, hoping it fixes my seat movement!!
Did my install the other day, took ~10 minutes. You do not need to use any sort of 'death wheel' to cut this. Pair of snips and done, the material is soft. Solved my issues, we'll see as a rack the miles up if its a long term fix.
I know this is mainly a topic of the seat moving, but mine has a creaking noise that comes from the back right corner of the seat when driving. I think it has to do with the springs in the seat. It is absolutely annoying to drive. It is a 2015 crew cab with 39,000 miles. Does anyone have any idea what is causing this and what can be done to fix?
After my return to the dealer after the part came in, they replaced the entire seat track(clips wouldn't work they said) and I haven't had an issue for a couple weeks. We'll see.
Sent from my SM-G935T using Tapatalk
How long did it take them to do it? Dealer ordered my seat track replacement, just waiting for it to come in.
My appointment was at 7:30 AM. I didn't get out of there till almost 11 AM. Might be better to drop it off.
Mine would stop moving laterally if I lowered the seat all the way down but then it was too low for my liking. My solution (so far) was to raise the rear of the seat by installing 5/8 inch thick shims/washers and longer bolts where the seat bolts to the floor and leaving the seat powered all the way down. Much better than having the dealer jack around with it.
Just at dealer (here in Michigan) to get my 2014 done - $235 labor and a $5 part........they had to keep the truck overnight to inform me of costs. No thanks, I'll do it myself!
WHAT!! $235 in labor only to do the retainer clip?!
Drop my 2016 off at the dealer for the second seat frame replacement in 18k miles.
save yourself $230 and do the hose clamp trick...
I did this a long time ago. No more issues.
Bootleg but effective.
Whats the hose clamp trick?
Sent from my SM-G935P using Tapatalk
Just a question so the black retainer one per seat, goes on the white clip that is on the side without the seat motor, by the door?
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
